windshield wipers...ours suck!
What, me drive fast?
I have had my car since October last year and the the windshield wipers are already streaking on the drivers side and not working on the passenger side. The passenger side wiper clears a 1-2 inch strip on either end of the blade leaving the middle totally untouched. I have fiddled with the a few times thinking maybe they were frozen or a pebble was caught or something but the look fine. WTF? Anyone else have similar problems? Do you think I should ddeal with the dealership or just buy some better blades and skip the hassle? If the latter, which blades do you recommend?:angry:
I don't think that it is a problem with the widshield. I am guessing that whatever spring or tension is used to keep the blade against the windshield is shot. Probably just a bad wiper.
www.drippinwet.com
ahh, guys, all wipers suck and wear out quickly, think about it. - its soft rubber that is always exposed to the elements, plus dust, ice, sap, pine needles, leaves, of course they will wear out, i use rain-x - all you need with that on your windshield is something to push the beading droplets off
Where is my super sauce?
All rubber windshield wipers suck. Like acura_service said, they're exposed to the elements and they degrade. End of story.
I think I'll get the silblade when the time comes. Siliconized rubber/plastic is a much more durable product.
Black is a ***** to Clean
1 Post
LOL, out wipers do suck and sometimes contribute to poor visibility in rainy conditions. When I took in my '03 in for an oil change at my dealer, they check a bunch of things, including the wipers. The tech informed me that I might need to replace my blades, but he did not even realize my car only had about 3K miles on the clock! He sprayed some solution on the blades and said it should be fine! If your blades really wear out though, don't get the OEMs!
boshe micro edge are good. your blades will last longer if you spray some window cleaner on a cloth and wipe down the blade till the the black smuge becomes a light black and your blades will wipe like almost new.
try it you'll be supprised how much crap builds up on your blades and how that the main prob.
www.drippinwet.com
I just buy the oem inserts, they are cheap enough, i don't have to worry if they don't fit exactly right, i just change them a few times a year
If the glass is dirty or pitted, the results are not going to be too great.
PIAA Super Silicone Wiper blades and Bosch Micro Edge Excel blades are both made to help with streaking and chatter.
Rain-X and other people have windshield washer additives that will help "lube" the window.
303-Protectant has a product that can be wiped on the blades.
And, one of my favorites:
(I use this to clean and protect my glass and hide some of the smaller pits. I also put Zaino on the top too...
http://www.diamondite.com/welcome.htm
The Diamondite has three parts: glass cleaner, suspended clay (foaming cleaner) and polycarbonate protection layer.
Glass can look clean and not be.
The TSB replaces some of the washer fluid hoses which were dissolving with washer fluid and causing windows to streak. They replace with silicone and give you new blades. See my next post for a list of all tsb's
I saw a bulletin on the NHTSA site about problems with the wipers streaking. You may want to do a search on their site. If your cars still under warranty have the dealer fix it.
Cajun Gumbo Man
Hey Eric ! Happy New Year ! Your windshield solution looks good. Make in Louisiana ! Which one of the 3 products do you recommend ? All three ? Is this like "rain X" ?
thanks !
thanks !
Since my CL-S is garaged, I still have the originals and still works great. No streaking or chatter. But I hardly use them since I DRYWASH the whole car and it works like RainX on all the glass.
thanks !
thanks !
I ran into the owner from a contact with another vendor.
It's not really like rain-x, it's more a cleaner and protector (if your talking about the Diamondite "kit").
I use the "WHOLE 3-part/step kit" and then put Zaino on top.
If you only had water spots or crud in the glass, you could just get the spray clay.
Have a great year!
Plz help.
Loosen the nut that holds the arm on, reposition and try the wipers to see if they hit or not.
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
