Teh CL's.... CLS6
Old 03-23-2015, 09:30 AM
  #121
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
Originally Posted by 03 tls nc
I have 3g types wheels 17x8" +45 offset and 225's are tight, but I also don't have adjustable upper arms in the front so know camber help either.
I was wondering if there was a difference in fender clearance between the CL and TL.
What kind of tires are you running. Also after having a second gen tl and a cl the fender clearance is much better on the cl. With the same wheels and tires I have plenty of room on my cl but on my old tl they would rub.
Old 03-23-2015, 11:07 PM
  #122
03 tls nc's Avatar
Originally Posted by brian6speed
For comparison, your wheels have 16 MM more inner clearance and 1 MM less outer clearance than my current wheels with 255 tires.
If your wheels were on my CL, I would have room for 255 tires, but 1010tires.com recommends atleast 8.5" wide for anything 255 or larger. I have always stuck to their recommendations.
With those wheels I would go for a set in 245.
I would recommend a front camber kit. Even at -2.4 camber my tires are wearing well. Toe is what you need to focus on for tire wear.
How low your car is can also affect fitment. I am at about .5 to 1 finger gap.
No idea about cl vs tl fender clearance. You will need to ask TL owners about that one.
Lowering car will also give you negative camber without a camber kit. My Ingall's arms originally didn't offer much adjustment. I extended the slots to allow a little more adjustment. That got me to -1.7 camber roughly. Then lowering car got me to -2.3 to 2.4.
That is about all the camber I can get with available camber kits. I am pretty happy with that camber setup for autocross. No worries on street also. Good thing about double wishbone suspension is you don't need as much static camber as a Macpherson strut setup.
Lowered with eibach's on bilstien's have .5 to 1 finger gap all the way around. Tires are 225/50 17 that's how I got them and they just barely clear the fenders. The front has stayed in spec so no need for adjustable arms.
Old 03-23-2015, 11:10 PM
  #123
03 tls nc's Avatar
I've got a cl setting here for my 6speed swap might have to uses the front feeders as well.
Old 04-17-2015, 02:10 AM
  #124
'03 ABP YA4-S 6MT
rp_guy's Avatar
something happen to your car?
Old 04-27-2015, 11:11 AM
  #125
teh CL's Avatar
She's officially off the road. It's been an eventful 10 months to say the least but I had to make the decision. After I pulled the motor to replace the rear main seal/oil pump and everything else I did, the car was fantastic. No issues at all, then I noticed oil spots on the driveway again from the oil pump area. Did a quick investigation & noticed a touch of coolant in the oil, sad to say that was the last straw.
She's officially being parted out. Haven't posted it on here yet, trying to see if I can get rid of most things local. If there's any interest, shoot me a PM.
Old 06-05-2015, 03:21 PM
  #126
CL REASON's Avatar
I have recent fried my valve train and looking into a new engine and I'm slightly leaning to the j35 because I feel it's going to be the same amount of work to just swap a j32 as is a j35 but I have a few questions for you! What ecu did you use and what caused it to leak so much that you pulled it and dismantled it? Thanks hope to hear from you soon
Old 06-08-2015, 10:13 AM
  #127
3.5 psi
gnuts's Avatar
there's no reason you shouldn't use a J35. He kept his CL6 ECU.
Old 06-08-2015, 10:16 AM
  #128
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,414 Likes on 3,024 Posts
Parting?
Old 06-08-2015, 07:52 PM
  #129
teh CL's Avatar
Definitely go with the J35 over the J32. Both need the same amount of work to be converted to a true manual motor & the stock 6 speed ecu is reused.
I never got around to investigating this current oil leak but I suspect it was a porous block or a headgasket.
Old 06-08-2015, 08:02 PM
  #130
teh CL's Avatar
Parting?
It was unfortunate but always on to bigger/better things :wink:
Old 08-20-2015, 04:36 PM
  #131
teh CL's Avatar
Swap has been pulled and the car is off to greater pastures tomorrow..
Old 08-20-2015, 05:50 PM
  #132
3.5 psi
gnuts's Avatar
you still going to mess with the first gen?
Old 08-20-2015, 06:17 PM
  #133
teh CL's Avatar
That's the long term plan. For now the swap/CL are going into hibernation.
Taking anything semi useful off the CLS before she goes. Fuse boxes, harnesses, cluster, shifter box, shift linkage etc etc.
When the time comes it'll be legit..
Old 08-27-2015, 10:27 AM
  #134
JDMCRX's Avatar
You gonna drop the J32a 6 spd into the 1st gen ?
I still have a 1st gen 3.0CL dumped with 3" and headers cleanish car. i was debating on this at times.
Old 08-28-2015, 06:11 PM
  #135
teh CL's Avatar
More like J35 6 speed .. but ya that's the plan, would be such a fun car swapped.. time will tell
Oh and pics of that dumped CL
Old 08-28-2015, 07:23 PM
  #136
JDMCRX's Avatar
Old 05-17-2016, 11:35 AM
  #137
Derek
SykVSyx's Avatar
Had my TL project been completed a lot sooner, it would have been an interesting match up with your CL build and g-nuts S/C CL.
Would have been a pretty varied field with the setups to see how they all performed.
Anyway, I know you moved on with the RL....which is coming along great.
Nice work with the CL, while it was up and running though.
Old 05-18-2016, 11:41 AM
  #138
teh CL's Avatar
That would've been magical & it sucks we never got around to squaring off
As for the RL, I can't complain at all but man do I miss that CLS6. The autotragic is slowly eating away at my soul but the AC seats are a nice touch with shorts
Hopefully this thread will live on and help folks moving forward..
Cliff notes: J35A3 > *
drillzzz
07-28-2019 06:30 PM
mporris
1/2G MDX (2001-2013)
09-13-2015 01:58 PM
Tsov Tom
09-06-2015 07:56 AM
DDT-TypeS
09-27-2003 07:05 AM
Quick Reply: Teh CL's.... CLS6
