RL Calipers Fit behind 05 TL 17" rims!
GO RANGERS!!!!!!!!!!!!!!!
Waiting for fluid to do full flush and then these will be on the car, this was a test fit to be sure the wheels cleared.
Thanks for the brackets to Civicdrivr!
P56 (04-28-2023)
Yup. Brackets that make it possible to attach the calipers.
Disks are EBC 13" '05 350Z Nismo.
Civic grabbed them!
Whats up with RDX owners?
vaymoon (07-26-2011)
Wow.
11.4 vs 15.1 including the bracket RL vs stock.
OEM rotor is long gone but the Z rotor is bigger & wider so I am sure it is heavier
No problem, the stock calipers I got stuck with have come in handy recently.
Ill weigh everything, I know you still want me to weigh the stock clutch assembly as well.
I may have to look into having those brackets made. I like!!!
Huh? These are for the front.
If you want a BBK for the rear, you have to look at what rotors are available. Remember you have the parking brake, so that comes into play.
Then you need a bracket made.
B A N N E D
but try Rotora, they have rear BBK's for our cars
to kinda expand on that; the parking brake is not part of the caliper, they are a sepearate drum inside of the rear rotor, so the parking brake is mainly what is holding back most of the BBK's out there from doing the back
Calipers cleaned, seals checked EBC red stuff installed.
Russell Stainless Lines ready.
ATE TYPE 200 Brake Fluid is all that is holding up my install.
