Acura CL Fog Light Bulb Replacement,
Learn to swim.
Hey guys, I just bought a set of Platinum Super Whites to replace my fog light bulbs with and am having trouble replacing them. I took a look at and under the front of my car and it seem the only way to get to the back of the light housing is by removing peices of the front facia and I would rather not if at all possible. It all comes down to I have no idea what I am doing so if anyone out there has done this or knows how, I would greatly appreciate and explanation of the procedure....ThanX
try FAQ it can be done in five minutes as reported by several members
'01 3.2 CL typeR
Sundance Platinum
Llumar platinum plus
tint 20% all around
'98 ACCORD V-6 sedan
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
'01 3.2 CL typeR
Sundance Platinum
tint 20% all around
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
Learn to swim.
<font face="Verdana, Arial" size="2">Originally posted by typeR:
</font>
</font>
If your referring to those two driving lamps already in the lower front then the whole deal is described in your owners manual. Although the man. says to remove all three plastic anchors I was able to put them in by removing only two anchors. Some have said they've installed some by removing only a single anchor. So anchor's away my boy …
01 CL Type-S, White\Black\Navi\Comptech Springs+Sways\Burl Shifter\Guards\Smokers Package
<font face="Verdana, Arial" size="2">Originally posted by Al Uminum:
</font>
</font>
You can just stick you arm in in there and twist and pull it out. I didn't use any tools or take anything apart to install mine.
2001 Acura 3.2 CL Type-S
San Marino Red/Ebony/Navi/Spoiler/Nose Mask/Mud Guards/Wheel locks/
Comptech Springs & Filter/PIAA 1969/20% Tint/Acura lettering removed/
12in Sub with AMP/Dynomated Trunk/Sub control under dash/
Clifford G4 Solaris Alarm
ACME sucks!
I removed two of the anchors on each side and installed them in about 10 minutes. And, I did use gloves!
2001 Acura 3.2CL Type-S
Satin Silver/Ebony
No Navi
Wheel locks/35% tint/Splash guards/PIAA 19169 bulbs/K&N 33-2178 air filter/Mobil 1 5W-30 oil & filter
Satin Silver/Ebony
No Navi
Someday pigs WILL fly!
You don't have to remove anything. Just put your hand between the plastic cover and the bumper from underneath. Believe me it sounds difficult but once you look at do it yourself, it's very easy. Okay back to Las Vegas on Discovery channel.
01 CL-S NightHawk Black/Ebony Bowling Ball Interior
Learn to swim.
Yeah, it was quite a bit easier than I thought, feel kinda dumb for asking now but I didn't want to start prying until I knew where I was trying to go first. Thanks all....
I replaced mine with Polarg M-6's yesterday. The 2 M-6 bulbs don't quite match in color(to each other,not the headlights.). Anyone else had this problem? I'll be trying to take them back to where I bought them for an exchange,but right now,for a $6 bulb, 75 miles (one way) is a ways to go.
Mike
Mike
Satin Silver CL Type S
Mike
Mike
Adult Supervision
CRAP CRAP CRAP!!!
I just broke a bulb trying to get the burned out M6's out. Its broken and stuck in the hole. Now its 9:30 and I have to take the light out. I wish it was 20 degrees warmer, I am sure that it would have fit out without breaking.
CRAP CRAP CRAP!
CRAP CRAP CRAP!
fog light bulbs
I have a 2001 cl, i am having the same problem, i have the HID bulb that matches the stock headlight bulb in terms of the color, i am not sure if its the right size, does anyone know what the bulb number is?
New here, just got my 01 CL a few days ago. My fog lamps don't come on, or both of them are burnt out. I'm assuming they come on with the headlights because I haven't found a switch that activates them. Is there one?
TIA
TIA
Acura CL type s bulb
Alright guys I am new here trying to get some answer I just got my fogs for my 2001 acura cl type s and yes they turn on when u turn your headlights on the bulb size from oem is 194 small bulb so I want to know has anyone put hids on there cl fogs
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
