Rpm drops to 250 with a\c on when coming to a stop
Old 05-25-2016, 11:24 AM
RVARGAS64's Avatar
As title states, with a\c on will be driving with say rpms around 2500 , when slowing down, to a stop rpms will drop to 250, engine starts to shake like it wants to die, for say a second then will climb back up to 750 rpms ... only with a\c on... any ideas??
Old 05-25-2016, 01:13 PM
Sean_CLS6's Avatar
Do you have any check engine light codes?
Old 05-25-2016, 01:49 PM
RVARGAS64's Avatar
No check engine light codes....
Old 05-25-2016, 02:02 PM
Received 8,584 Likes on 6,630 Posts
how's your alternator, battery, idle air control valve?
Old 05-25-2016, 02:22 PM
RVARGAS64's Avatar
have not checked battery/ alternator, plan on cleaning iacv...
seems to happen when there is a load on engine, when the compressor kicks in , now that I think about it...
Old 05-25-2016, 02:23 PM
yup hence the battery/ alternator check
also check your all your grounds.
RVARGAS64 (05-25-2016)
Old 05-25-2016, 02:32 PM
RVARGAS64's Avatar
will do thanks....
Old 05-28-2016, 03:07 PM
YeuEmMaiMai's Avatar
clean idle air control valve. that will fix the issue if not, it will need to be replaced
smarty666
5G TLX Problems & Fixes
02-01-2016 03:29 PM
Quick Reply: Rpm drops to 250 with a\c on when coming to a stop
