New owner CLS6
Old 01-20-2017, 10:39 AM
  #81
3.5 psi
gnuts's Avatar
2ndgentl recently put them on (post 109): https://acurazine.com/forums/2g-cl-p...-949436/page3/
the 6speeds also had a torque damper at the front and rear that the autos didn't have. Since you swapped I doubt you have those. I don't know of any upgraded trans mounts, but I've never searched around.
hitek9 (01-20-2017)
Old 01-20-2017, 11:41 AM
  #82
j35/6 Speed Swapped
hitek9's Avatar
i swapped the 2 subframes so I have those dampers. The one that holds the rack I bought new 1+ year ago. I forgot about those. Will replace those too.
Old 01-20-2017, 12:10 PM
  #83
3.5 psi
gnuts's Avatar
ok good you have them! you can replace them with NRG dampers for a civic/integra...I can't remember the year. They said it really helped with wheel hop.
Info here: https://acurazine.com/forums/second-...talled-484603/
Old 01-21-2017, 12:15 PM
  #84
j35/6 Speed Swapped
hitek9's Avatar
thanks again, will replace all that and report back
Old 01-22-2017, 03:25 PM
  #85
Eurotrash
Tosh's Avatar
Thanks for livening up these forums!
Old 02-02-2017, 11:37 PM
  #86
j35/6 Speed Swapped
hitek9's Avatar
Just did the valve adjustment. Followed Eric the car guys YouTube video and it turned out good.
Attached Thumbnails New owner CLS6-20170124_210632.jpg   New owner CLS6-20170131_193056.jpg
Old 02-03-2017, 09:46 AM
  #87
mattcl-s's Avatar
Did you notice a difference after the adjustment?
Old 02-03-2017, 03:27 PM
  #88
6mt swapped..smart
AnthraciteTypeS's Avatar
Hitek you really need to dyno that thing. I'd love to see the numbers.
Are you running j32a2 cams or j35a3?
teh CL (02-10-2017)
Old 02-04-2017, 12:05 AM
  #89
j35/6 Speed Swapped
hitek9's Avatar
Yeah, mine were long overdue. No misfire, but definitely heard ticking and had a rough idle. She purrs now, even when it's cold. I'm in the Midwestand it's been around 20 degrees lately so I see some cold starts.
J32 heads. Was alot easier than swapping over cams, valves, springs, lmas, sprockets, sensors...
Yeah I will before I do anything. Will be nice to see some base numbers. As soon as it gets warmer and theres a cheap dyno day I definitely will
Old 02-06-2017, 08:48 AM
  #90
mattcl-s's Avatar
Good to know im at 208xxx no valve adjustment, but I do have a ticking noise and does idle a little bit rough at times, about how long did it take you?
Old 02-22-2017, 07:44 AM
  #91
Received 1,736 Likes on 1,392 Posts
J32 heads. Was alot easier than swapping over cams, valves, springs, lmas, sprockets, sensors...​​​​
hitek9,
When you swapped the heads from the J32A2 to the J35A3, did you have them checked out first by a machine shop for damage/warpage before you bolted them up to the J35?
OR
Did you just do a straight transfer directly to the J35?
Thanks,
teh CL (02-22-2017)
Old 02-26-2017, 09:19 PM
  #92
j35/6 Speed Swapped
hitek9's Avatar
It was my first time so about 3 hours. I'm confident I can do it in 2 or less now.
Originally Posted by zeta
hitek9,
OR
Thanks,
I checked them myself at work with this big metal block. Cleaned up the surface with a few different kinds of sand paper. Got lucky.
The following 2 users liked this post by hitek9:
teh CL (03-03-2017), zeta (02-27-2017)
08KBP_VA
10-22-2019 01:55 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
Jimmy_D
10-07-2015 11:52 PM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: New owner CLS6
