"My seat won't move/recline" thread
Old 05-30-2009, 09:07 AM
  #41
5th Gear
kehnee's Avatar
hey topher, heres my email okstcks@yahoo.com I can be reached quicker here! Thanks!
kehnee is offline
Old 05-30-2009, 09:08 AM
  #42
5th Gear
kehnee's Avatar
Originally Posted by Ron A
Welcome to the forums.
Since you can't PM, you should leave your email address so topher can give you his phone number so you can call him.
kehnee is offline
Old 05-31-2009, 04:36 PM
  #43
TOPHER33884's Avatar
^^ Sorry, I have been busy as hell with a few projects and work I am doing.......I will send you an emial with my contact info in a little!
TOPHER33884 is offline
Old 06-02-2009, 02:32 PM
  #44
5th Gear
kehnee's Avatar
Hello Topher, didn't get any email from you yet? Did you try to send me an email? Just checking!
kehnee is offline
Old 09-18-2009, 04:00 PM
  #45
9th Gear
littleferris14's Avatar
topher! i am in need of your services. .i would love some help with my passenger seat. thanks in advance!
littleferris14 is offline
Old 09-21-2009, 09:47 AM
  #46
9th Gear
do i need to take the whole seat out to fix the passenger seat? when i press it one way it makes a slight click but doesnt go anywhere, and same if i try to move it the other direction. it is just the passenger back portion that wont move. just wondering if i need to take the whole seat out to fix..
Old 09-21-2009, 02:26 PM
  #47
Former Sponsor
rondog's Avatar
lol, I had this happen twice a few months apart in my old 2001 CL, first time, I got down and dirty taking the plastic off, screwdriver, etc. Second time, I was so pissed, i just sat in the seat, leaned back real hard, I mean REAL hard and pressed the seat back button while doing it, and it got unjammed, never had the problem again.
*disclaimer: if your seat breaks, it's not my fault.
rondog is offline
Old 09-21-2009, 03:23 PM
  #48
lowrd on tein CS biatch
CL-S progression 01's Avatar
^^^^ now that's a story. Finally using excessive force has gotten the job done
CL-S progression 01 is offline
Old 09-22-2009, 01:25 PM
  #49
9th Gear
in taking the plastic off were you able to do it without taking the seat out of the car????
Old 09-24-2009, 08:38 PM
  #50
fblackston's Avatar
Drivers seat will not recline, Acura 03 CL
Can you help me too TOPHER33884 ?
My drivers side seat will not recline. I hear a clicking when i move the switch, and when i pulled back the plastic cover, i can see the gears move like a millimeter when i move the switch. can you help me with the rest?
my email address is fhblackston@gmail.com
thanks
fblackston is offline
Old 09-26-2009, 07:23 AM
  #51
DURAN007's Avatar
Wouldnt be easier just to post it. It could be put in our hall of fame DIY!
DURAN007 is offline
Old 10-01-2009, 11:48 AM
  #52
9th Gear
I got it figured out! Here are some more detailed steps to help:
1) Remove 4 bolts holding chair in the car.
2) Remove the 2 screws from the plastic molding where the switches are on the side of the seat
3) Pull back the cloth from the side where the motor is.
4) There is a little window on the side metal frame that is facing the door. In this little window you will see the back portion of the gears, this is where you use the flat heat. You stick it in there, while hitting the switch back and forth position the flat head under one of the teeth and against the metal frame. Going back and forth a few times should unstick the gears.
5) Put it all back together!
-I will post pictures as soon as I can. Thanks for everybody's previous posts. It took me 2 hours, but if I would have known the exact place to stick the screwdriver it would have taken only 25-30 min.
Old 10-05-2009, 04:02 PM
  #53
9th Gear
Hey all, here are the pics I promised. Good luck to everyone!
https://acurazine.com/forums/members/littleferris14-273906-albums-non-reclining-cl-seat-fix-4062/
Old 12-30-2009, 11:24 AM
  #54
5th Gear
pasavage's Avatar
I too have the same issue with my 2003 CL Type-S on the passenger's side. In addition to the above - which was VERY helpful, thank you - I removed the motor (three screws - easy) and that allowed even more access to both the 'back' of the main gear and the front. However, I am unable to see your pictures (new member I guess). I would love to see a schematic of what's IN behind the rivited cover plate.
Another point that arises in my mind is that after lubing the hell out of the gear(s), what then about proper grease? If none's applied then the same issue is likely to arise again, right?
This issue seems to be directly related to corrosion on the main gear - rust! I live in Florida and the humidity must've taken its toll...
pasavage is offline
Old 12-30-2009, 11:28 AM
  #55
5th Gear
pasavage's Avatar
When I said "lubing" I meant with WD40... Doesn't that deteriorate the grease?
Also, as of right now, nothing's happeneing and I am afraid that whacking the flat head screw driver too hard might damage or break a tooth on the gear. Any thoughts, anyone?
Thanks in advance!
pasavage is offline
Old 12-30-2009, 01:33 PM
  #56
5th Gear
pasavage's Avatar
OK, chaps and chapesses! Topher and LittleFerris14 are da bomb! It worked - with a little time and patience.
If I may, I'd like to offer some tips.
Place lots of rags under and around the bottom left corner of the seat before you go at it with the WD40 - it'll drip onto your carpet and make an unholy smell you'll never remove (nope - it didn't happen to me as I managed to think of it before having at it).
Remove the sill covering (it pops off with care) before starting - it allows better access to the side panel screws.
Be careful when removing the covers from the retaining screws for the side panel: one side has a tang that lies horizontal and the other vertical. You need to prise it out gently ensuring that you've got the side that pops out perpendicular to the side panel and then remove it by pulling sideways.
Have at hand a long Phillips (cross head) screwdriver bit - you'll need it for the rear-most retaining screw.
Move the chair all the way forward - it lifts it up relative to the sill and makes access a little easier.
If you remove the motor (and I don't think you do, actually) then unplug the connectors from the switch assembly on the back of the side panel. It'll make it easier to later check the motor funtion, if that is something you decide to do. I did... No reason but better to be sure before proceeding.
It was impossible, I found, to rotate the gear using just the screwdriver so, leave the WD40 to do its work for a good while (I left it two and half hours). Then (after replacing the motor and switch connectors, if needed) and before using a good amount of leverage force as described by Topher and littleferris14, hit the switch. Go back and forth a coupla three times first then, looking at the direction the gear moves (it will a little bit) when hitting the recline. Then, place the wide bladed, flat headed, long shafted screwdriver in place, press hard, levering in the direction the gear ought to move when the seat back is reclining, hitting the recline button at the same time.
Bob's your uncle - works now just like a bought one!
Thanks again for all your input and saving me a boatload (more) on this Acura.
pasavage is offline
shamal (02-14-2015)
Old 02-02-2010, 01:27 AM
  #57
StreetKA's Avatar
just happened to me couple days ago... will check that tomorrow... i am complaining about bc my gf she is small and skinny she doesnt need to do anything but its annoying if seat on the pass side seat is straight up... also my friend was complainging about it today
StreetKA is offline
Old 05-21-2010, 05:35 PM
  #58
7th Gear
bigdonuno's Avatar
topher can you email me bigdonuno@gmail.com, i want to fix my drivers seat and you seem to be the man at this. thanks in advance
bigdonuno is offline
Old 05-21-2010, 06:00 PM
  #59
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,144 Likes on 4,811 Posts
I dont think Topher is around here anymore since he sold his CL.
civicdrivr is offline
Old 05-24-2010, 03:50 PM
  #60
7th Gear
bigdonuno's Avatar
littleferris i cant see the pics, must be because i am new, is there anyway you can email them to me?
Old 09-11-2010, 06:41 PM
  #61
favtbg's Avatar
I am having trouble seeing the pictures too. Littleferris, can you send me those pics to my email? @ favtbg@gmail.com
favtbg is offline
Old 09-13-2010, 01:05 PM
  #62
504P_CLS's Avatar
My driver seat had been exhibiting signs of being "stuck". It would move slower and slower, sometimes not at all. After a couple months, I had to do something. I thought it was the same as this thread and was going to try it until upon closer inspection of the hinge area, 2 pennies had somehow gotten lodged into the area. (Driver seat, hinge area right below seatbelt buckle). It took some creative jostling to get them out. Once they came out, I could see how the pennies were all mangled because they had been caught in the hinge. As they moved deeper into the mechanism, they finally got the seat jammed. Who knows how long they had been there.
So before you take the hinge apart, check to see if there is anything obvious holding it back. You may find a couple pennies!
504P_CLS is offline
Old 09-28-2010, 07:32 AM
  #63
3rd Gear
terribleone's Avatar
Topher you are the man!
i did just what topher said and it freed the gears up and worked instantly...i really appreciate it! i was so uncomfortable sitting straight up cuz i recently broke my back.the screwdriver broke it free and wd 40 helped too. thanks again!
terribleone is offline
Old 09-28-2010, 07:38 AM
  #64
3rd Gear
did you fix your seat on cl yet? it was pretty simple, i can explain if not.
Old 09-28-2010, 07:47 AM
  #65
3rd Gear
thanks alot for the thread on the cl type s seat problem. it took me 5 minutes and im so happy now, my back is broken and i was in pain driving straight up and down...you fuckin rule!
Old 09-30-2010, 06:52 PM
  #66
Bonki Ehrite!
MIKE8898's Avatar
My driver seat moves fine forward and back but the back wont budge. Obviously the motor is working since it moves so i will try this tomorrow. Hopefully it works. Thanks for posting this info.
MIKE8898 is offline
Old 03-05-2012, 01:07 PM
  #67
Noobie1Kenobi
jondee5179's Avatar
Originally Posted by arp408
TOPHER33884
Is the man!!! My seat finally reclines!!! Thanks to this guy. Damn dealerships and shops said the motor was busted and I havd to get a new motor. But all it needed wa some wd-40 and some lub to loosen the gears. Thanks again bro! You just saved me a few hundred's!
hi - would you mind to share how you fix the issue ? - I had this issue since 2007 -
jondee5179 is offline
Old 03-05-2012, 01:28 PM
  #68
civicdrivr's Avatar
Remove the plastic cover on the side of the seat. Youll see the gears that move the seat back and forth. You can remove the motor and test it off the seat to verify it still works. I used a flat head screwdriver to get the gears on the seat itself to loosen up, then apply grease.
Old 03-26-2012, 08:04 AM
  #69
Darnell Morris's Avatar
Having this problem my self I'm going to try and fix this now
Darnell Morris is offline
Old 04-07-2012, 08:42 AM
  #70
CL-S 6Speed is rarely in
Beavisboots's Avatar
I had this problem about a year ago. When i tried to recline the seat it would just click in either direction. I used the lever on the side of the seat to push the seat foward. With the seatback foward, I pushed to button for the recline and heard the motor engage. Seems the gears or whatever ( never opened it up) had become off or misaligned somehow. Before pushing the seat back, I pushed the power recline button all the way back. After returning the seat to driving position, it went all the way back and has worked fine ever since.
Beavisboots is offline
Old 04-10-2012, 09:04 PM
  #71
Jawwad786's Avatar
Power Seat Recliner Broken
I have an 04 TSX and the seat is stuck in the down position and wont come back up. I took it to the dealership today and they stated that Power Seat Reclining Motor may need to be replaced. Any suggestions, experiences, DIY? Please advise.
Jawwad786 is offline
Old 04-11-2012, 12:40 PM
  #72
Dspr_02's Avatar
I had this problem with both recline and raising the back part of the seat up, I fixed the recline part by football tackling the seat-back while holding the recline button ( X-Direction of tackle--> / -Direction button was pushed-->). The seat rising part I pushed the seat up as hard as I could while holding the seat up button (did this while in the back driver side seat, lifting up from the base of the seat).
I don't recommend jumping straight to tackling your seat, but it sure as hell beats blowing $300+ at the dealership...
Dspr_02 is offline
Old 06-08-2012, 04:12 PM
  #73
IAPECC Member
piro91's Avatar
Just happened to me today.
The seatback dose not recline and when pressing the memory buttons there is just a click.
The recline button does nothing as well.
With my closed fist i beat on the seat back approx where me shoulderbladeas were. This rattles the seat mechanism. It worked fine after doing this twice. If problem persists just hit the seat and the button at the same time or sit in chair and push back hard and hit the recline button back.
If still dosent work then disassemble it.
piro91 is offline
Old 06-12-2012, 10:49 AM
  #74
an asshole from florida
invisiblewar's Avatar
My seat reclines but will not move forward or back. I was vacuuming under the seat and somehow ripped up the wires in my seat. I spliced them back together but the seat doesn't move anymore. I have tried replacing the fuse but that does nothing.
Any advice? I'd tried looking for solutions for 2 years now and nothing.
invisiblewar is offline
Old 06-12-2012, 09:43 PM
  #75
IAPECC Member
piro91's Avatar
Perhaps you altered the resistance on the wires and the moduel is now responding to the signals, or the moduel itself is burnt?
Hard to tell...
piro91 is offline
Old 06-14-2012, 07:52 AM
  #76
Yeah Its getting me bummed since I have no clue what it is. Everything else on the seat works except for moving forward and back. Luckily I'm tall enough to where having the seat back isn't much of an inconvenience. Still would be nice for those rare instance someone sits behind me or when I'm driving a 12 hour drive from Miami to Atlanta and have a ton of stuff in my back seat (It was a terrible drive).
Old 06-17-2012, 09:08 PM
  #77
captivahach's Avatar
So, this worked great. Thanks a ton
captivahach is offline
Old 06-18-2012, 10:20 AM
  #78
cleptosis's Avatar
i just beat mines yesterday bad chair
cleptosis is offline
Old 07-05-2012, 04:19 PM
  #79
kc1337's Avatar
Can someone please send me the procedure to my e-mail??
My seat has been stuck for a while. I've taken the motor out and it does turn, so something is stuck.
kennethcho1337@gmail.com
kc1337 is offline
Old 07-05-2012, 05:24 PM
  #80
civicdrivr's Avatar
Its just the gears that are binding. Use a screwdriver to break the gears free then grease them.
Quick Reply: "My seat won't move/recline" thread
