Intake manifold swapers(questions 4 u)
Can this manifold be use on my clp? What about the throttle body? What type of gains would I see if compatible.
here's the info about the setup.
Year : 2004
Model : Pilot
Engine : 3.5L 6cyl
Interchange Info below :
01 02 MDX 3.5L Manifold
03 04 Pilot 3.5L 6CYL Manifold
GY91A Throttle Body
OEM US Model
Used & Excellent Condition
Pictures is the actual product for sale
Year : 2004
Model : Pilot
Engine : 3.5L 6cyl
GY91A Throttle Body
OEM US Model
I got the Shifts
here you go https://acurazine.com/forums/search.php?f=50
Well I remember reading in that CL Info page that a conversion from a 03 MDX fits on a CL. It's also a 3.5L V6, apparently. I'd say try to get info on that one as well, see how the specifics compare.
I did do some searching before posting this thred,but I did not find any answer that a 3.5 pilot intake would bolt on a J32-1 lower intake,nor did I find anything that said linkage or tps and everthing else would be a direct fit since the search does work a little skechy.
Thanks for your additude and your GREATLY appreciated help too.If you were trying to help"like you should"then maybe you should try to helping me with some answers and not give me a poor response.
Besides being a mod you should know where the poor response came from,and that type of response person"is what starts a lot of threds from them being locked or users being banned".But I dont need to tell you that,Or at least I should'nt.....
I dont think people should help me at all.I offer help to others anyway I can.Since it feels good to help the next man.Its easy to laugh at some one give them a bad answer just because you really been down that road many times so the additude comes off with arogance.
But a mod from my stand point should be a go to person for answers when you dont know something.Also for the people that get picked on to be a peace maker,and make reposting a thred where it belongs once in awhile.thats it thou.I help so there for ,I would like some too.
And like I said he comes the cycle of the thred getting locked.I'm not new to this.Now my thred is cludered with no topic nonsense
Using phee's search suggestion, I found this (rather quickly):
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/3-5-liter-hybrid-build-information-714305/
https://acurazine.com/forums/showthread.php?t=714305
Moderator Alumnus
The only way to really verify if it fits is to check the part numbers of the intake manifolds between the 3.2 and the 3.5 engines.
Since the 01-03 CL Outlaw Engineering thermo spacers work hand in hand for the 03+ Pilot give it a shot. Might as well be a swap and play. BUT, if you do the swap you'll need a tune.
http://www.outlawengineering.com/hondajframe.html
These spacers work for all of these manifolds. It's hard to say that all of the intakes are swappable though.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Same ones I have for my j30
As for the intake i really dont think there is any real difference between that and the CL-P and you wont see any gains. Now if you add the Riser that goes under it you may.
No difference in power between the the clp intake/throttle body and the one I showed,that is definitly false.Since the type s intake/throttle body will give me 8-10 whp.This intake looks very simular and the throttle body look as if it may be bigger.If thats what you beleive then your right,I should not be trying to get help from you.
Thank you Biglizard,for some real help.
Its the VSA throttle body
slow tl..
cycdaniel
12-17-2019 10:58 AM
mrkingstonvi
02-22-2016 01:53 PM
