Block heater
Old 12-15-2016, 08:19 AM
mattcl-s's Avatar
Block heater
Hey everyone so its -15F here in Minnesota and its only going to get colder. I am wondering where on the block the plug is for the block heater and if it hard to get to? car is not like this cold of starts in the morning I had one on my old car 2000 ford contour and it worked great in temps like these. let me know guy thanks
Old 12-15-2016, 09:03 AM
mattcl-s's Avatar
I searched on google and came up with nothing
Old 12-15-2016, 09:31 AM
3.5 psi
gnuts's Avatar
I think it replaces the coolant drain plug. info is hard to find on this.
Old 12-15-2016, 09:33 AM
mattcl-s's Avatar
I am having a tough time too just trying to find out where its located on the block
Old 12-15-2016, 10:56 AM
mattcl-s's Avatar
I guess its called a "freeze plug" not drain plug
Old 12-15-2016, 05:08 PM
teh CL's Avatar
I've been thinking about the same thing as it's getting pretty brisk around here & the car sits outside all night
Old 12-15-2016, 05:13 PM
teh CL's Avatar
Did some searching & there's no oem option for the CL..
Found the install for a 04+ TL though.. ​​​​​​​https://www.acurapartswarehouse.com/...ock-heater.pdf
mattcl-s (12-16-2016)
Old 12-15-2016, 11:20 PM
Eurotrash
Tosh's Avatar
Do they still offer those generic oil pan heaters? They're flat and you attach them to the underside of the pan, so a bit less invasive than a freeze plug heater.
Old 12-16-2016, 01:53 AM
'03 ABP YA4-S 6MT
rp_guy's Avatar
08T44-S5B-100 generic honda block heater. follow the instructions for the TL. canadian cars already have one installed. was on my j32a2 and now j35a3
if you're worried about it cranking get a battery warmer. if you want it to start slightly easier use a block heater.. otherwise an oil pan heater is best for the engine since it's heating the oil and not just the coolant.
Old 12-16-2016, 10:41 AM
mattcl-s's Avatar
called the dealership and the part is discontinued
Old 12-16-2016, 10:43 AM
mattcl-s's Avatar
I am not sure if they have those for the cl ill have to check. I did find the block heater from advance auto parts its about 35$ and have to special order it not too bad
Old 12-16-2016, 10:45 AM
mattcl-s's Avatar
main reason is just so it starts easier I found block heater works pretty well In my previous car since its about to drop to -23f here this weekend I wanna have her plugged in
Old 12-16-2016, 10:48 AM
mattcl-s's Avatar
I can only imagine, this damn polar vortex sucks!!! mine sits all night outside too poor thing
Old 12-16-2016, 10:57 AM
mattcl-s's Avatar
so this should be pretty much the same for the cl right?
Old 12-20-2016, 11:07 AM
I Wanna Beer
TheWeez's Avatar
I've had my CL-S6 in Minnesota for 6+ years and haven't had issues with starting even when it's crazy cold. Worst was leaving it at the airport for a week and coming back to it after it sat outside in -20º a couple years back. Started right up but the power steering was frozen. Even after idling for over 30 minutes it was frozen. Drove home having to strong-arm the steering but after it sat in the garage overnight it was fine again.
The engine block heater for the CL is 08T44-ST7-200 but it's been discontinued.
mattcl-s (12-20-2016)
Old 12-20-2016, 11:19 AM
Received 8,612 Likes on 6,651 Posts
like the fluid was frozen? damn that can't be good for your PS system Was it really old or something? It's also hygroscopic like brake fluid so maybe just needs a new flush.
Old 12-20-2016, 11:22 AM
I Wanna Beer
TheWeez's Avatar
Fluid wasn't old and everything checked out fine. Shop said it's common when left outside for a few days in the -20º continuously. It may have hit those temps here on Sunday but only for a couple hours. Not day after day like it did a couple years ago which is what froze things up.
Old 12-20-2016, 11:52 AM
mattcl-s's Avatar
mine started right up Sunday morning but it was not happy. I ordered one should be here soon then going to take it to a shop to install
