Shifter stuck in park (need help)
Old 05-09-2006, 08:40 PM
u2vex's Avatar
Recently everytime I start my car and try to take it out of park into reverse or drive the shifter is stuck and I gotta turn off the car take out the key and put it into the unlock shifter slot and take it into neutral and then restart the car in order for me to drive off...have this happen to anyone and can you help me with this problem....this only happened recently it worked fine before...
Old 05-09-2006, 09:07 PM
CTS-V Import Slayer
MichaelBenz's Avatar
It has an autolock mechanism on the transmission which requires you to PRESS THE BRAKE before taking it from park or it will lock it in park until you do. This keeps it from lunging forward when you go to drive due to possible high RPM's like the Saabs had a problem with. Actually...it was right around the time the Saabs had this lurching problem when these things came about.
Old 05-09-2006, 09:16 PM
Ken1997TL's Avatar
Received 2,328 Likes on 1,308 Posts
Basically the sensor that detects that the brake has been engaged is not working.
Old 05-09-2006, 10:30 PM
TexasHonda's Avatar
Keyswitch also enables the shift interlock. A faulty keyswitch could cause the same problem. A faulty or misaligned shift-lock solenoid could also cause this problem. It may take a lot of fault tracing to get to the bottom of your problem. An Acura shop manual is essential, or some good shop diagnosis.
good luck
Old 05-10-2006, 02:53 AM
CTS-V Import Slayer
Damn dude....didnt realize I was not in a 3G forum...(my bad)....disregard anything I said cause I dont know if this generation works the same as ours. Sorry.
Old 05-10-2006, 09:53 AM
u2vex's Avatar
Yeah I know you gotta press on the brake to release it out of park and it worked fine before, but now it's just being a pain in the A**. but i'll take it to my local honda/acura specialist (not a stealership) and see if he can diagnose it and see what's up, I really don't have the time lately to get down and dirty. I'll let you all know what's up as soon as I do.
Thanks for all your replies!!!!!!!!!
Old 05-10-2006, 10:19 AM
Ken1997TL's Avatar
Actually your advice applies to just about every Honda and Acura made since the early 90's
Old 05-10-2006, 10:44 AM
CTS-V Import Slayer
Cool....this being my first Acura or Honda (car anyway)...I was not sure!
Old 06-07-2006, 04:48 PM
lcamacho123's Avatar
Shifter Stuck in Park
I have 208,000 miles and well it runs alright but recently at my Grandfathers house it got stuck and wouldn't go into gear so we pushed it forward and backward and it worked but now none of that crap even works and it's getting on my nerves that everytime I have to use the key and sometimes it doesn't work does anyone know how much this is going to cost me!
NanceInWA (11-02-2014)
Old 06-12-2006, 07:59 PM
u2vex's Avatar
well I didn't get the diagnosis on this issue...been so busy and after I posted the last time, it started working fine and it has since then, I push on the brake a lil harder than before, I guess like some ppl said the sensor might have something to do with it. but best of luck with yours...
Old 06-14-2006, 10:26 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
i just had this problem on a Vigor i just bought... you need to chekc the shift lock solenoid and also the brake switch at the pedal...
clifton17 (05-18-2014)
Old 07-06-2006, 12:02 AM
vishnus11's Avatar
An obvious suggestion here, but one we might all overlook: are you parked on an incline when this happens. If you don't properly apply the handbrake when parked on an incline, the car's weight will rest on the transmission, and thus make it harder to shift out of park. I believe in old Pontiacs, you were actually advised to get another car to "bump" your car slightly up the slope so that you could get the tranny out of gear if this happened!
Old 07-07-2006, 06:17 AM
TexasHonda's Avatar
This just happened to my 97 2.5TL. I confirmed the brake switch was the problem by observing that brake lights would not come on when brake was pressed. Last Sat. morning, I got under the dash to examine the brake switch. It is extremely difficult to reach, although it could be seen easily. How you remove it is a mystery, but may be possible w/ enough determination. I finally decided the switch must be sticking in the open position when the brake is pressed. I got a can of WD40 and a spray nozzle and doused the switch movement w/ WD40. So far the problem has not returned. I'm hopeful, as I really don't want to try to replace that switch.
regards
Old 08-20-2006, 12:03 AM
AznImports602's Avatar
You know, I recently had the same problem, but I started to press the brakes rapidly to get it to move. At first I thought it was my transmission acting out, but I guess its not.
Old 08-20-2006, 07:57 AM
TexasHonda's Avatar
regards
So far my "wd40" shower has worked.
regards
Old 10-08-2007, 08:20 AM
DiegosAnotherR1's Avatar
I just started having this problem this morning. But everytime I press the brake light, the parking brake indicater light on the dash turns on(the one on the gauges that says "BRAKE"). Its still dark outside, so I dont want to try getting at it yet till the sun comes out, but you guys think this is just the sensor, or will I have to go over my whole brake system since the brake warning light keeps comming on? help ASAP please. Thanks
Old 10-09-2007, 08:53 AM
nevermind. fixed it!
Old 03-20-2009, 06:03 PM
cvzillest's Avatar
HOWW? I ALSO NEED HELP! thanks
Old 03-20-2009, 07:26 PM
Khmer Pride
KrayzieDxC's Avatar
what wrongs with ur shifter, stuck in park? if so u need a break switch
Old 03-10-2011, 05:27 PM
belljam's Avatar
Ancient thread but....
regards
I love this place! Had this problem today and was trying to figure out how much the garage was going to gouge me in order to fix this problem (shifter stuck in park). Thanks to TexasHonda and the other folks of this good forum - I just broke out the can of WD-40 and all is well!
Can't thank you guys enough!
Old 03-25-2011, 12:25 AM
5th Gear
defaceone's Avatar
Possible bad brake light switch!!
Old 04-07-2011, 09:03 PM
5th Gear
LilBigWheel's Avatar
This also is my Stuck in Park problem
--this happened to my wife while driving home with my child at a gas station at the same time that the Main Fuel Relay went out...initially thought it was a fuel pump cause i couldnt hear it...then talking to the service guy said relay rarely pump...anyway troubleshooting stuck in park....brake lights work fine so i ruled out break switch...thought shift lock solenoid took it off gave power works fine...whats my next step here its killin me cuz wife thinks this problem is sooo big we should sell the car.....btw its a great car, highly technical, but a great car....could anything near the MFR affect the park lock mechanism electronically??
Old 04-07-2011, 09:37 PM
5th Gear
sorry
its a 1996 3.2 TL
Old 04-08-2011, 09:26 AM
tempetom's Avatar
I think I would still change the brake switch. It's cheap enough to give a try. It worked for me. I don't recall if my stop lights worked or not when I had the problem. I got the switch for around $35 I believe from Auto parts warehouse.
Old 04-10-2011, 07:45 PM
jperdoch's Avatar
mine just went bad on my 03 TLS. same symptoms. Bought the switch at the local Acura dealer for 38 bucks, took 10 minutes to install...
Old 07-22-2011, 11:01 AM
clabberty's Avatar
every summer!
This has been happening to me every summer for four or five years. It's stinkin humid here near the Great Lakes right now and my shift lever sticks constantly. I discovered that on a normal hot, slightly humid day parking in shade makes it go away. I guess it gives my car a bit of personality.
Can someone give me a heads up where to look for and what the brake switch under the dash looks like? I have a can of WD40 and I'm not afraid to use it. If it's really hard to find I might call my mechanic and ask what he'd charge to replace it for me.
Is there any benefit of WD40ing the actual shift lever itself?
Thanks. I love my car and hate degenerating in a lot of swear words when this happens. I don't want to upset my Primrose in case she decides to get back at me. Always be nice to machines.
Old 07-22-2011, 03:46 PM
Khmer Pride
KrayzieDxC's Avatar
follow your break pedal ..and there you find a switch
Old 07-23-2011, 09:38 AM
clabberty's Avatar
Thanks. So I follow the brake pedal and I then WD40 the first thing I see under the dashboard? Have you ever also WD40'd the shift lever?
Old 08-13-2011, 01:16 PM
clabberty's Avatar
Problem was solved with new shifter cable. Thanks for all the assistance.
Old 11-20-2012, 09:59 PM
02Acura02's Avatar
Red face stuck in park
Goodevening,
So with me being a single eoman/parent. I slightly paniced, when my 02 Acur would not come out of park this evening when i came out of the grocery store. So i read my manuel to at least utilize my shift lock feature. Thank God. BUT i am figuring that using that lock everytime is not the best result. So my question is?? Is the WD40 the best solution or will i have to replace the switch, OR do i keep pressing on the brake?? All honesty is appreciated!! ;D thank you all
Old 11-21-2012, 09:32 PM
jperdoch's Avatar
It is so easy to replace, just go to the dealer and buy the part...forget the wd40
02Acura02 (11-21-2012)
Old 11-21-2012, 10:02 PM
02Acura02's Avatar
I actually did have the brake sensor replaced today. It took all of 7 minutes to seitch out. Even though i. Did not do it myself. My brake lights were also out. So by switching that part out. Everything operates as designed. I was also told that, that concern is something that happens more often with Acuras. Thanks for yhis informative site.
Old 12-13-2012, 11:06 AM
zypkode's Avatar
When this Happened to my Car. I was just Low on Transmission Fluid.
Old 01-05-2013, 09:23 PM
Fr3shAcuraTL's Avatar
just happened to mee today they told me is not the sensor
Old 05-18-2014, 10:12 PM
clifton17's Avatar
I'm looking into the shift lock solenoid now.
Old 11-02-2014, 09:19 PM
7th Gear
NanceInWA's Avatar
I tried this and it didn't work on my 2001 MDX. Recently several more functions stoppped functioning as well as the stuck-in-park issue.
Old 11-02-2014, 09:22 PM
7th Gear
NanceInWA's Avatar
My brother told me about this issue. My driveway is at an incline and I try to switch parking head-in vs tail-in, but unfortunately the stuck-in-park happened to my 2001 MDX recently. Hope it's not too expensive to fix.
Old 11-04-2014, 07:53 PM
Str8 Home built
bigwerm187's Avatar
Am try that WD40 first and see if that works =) cuz right now I have the same problem.. And its pissing me off lol....
My problem is I cant shift out of park too. but what I noticed was the light on my dash with the "P" will flash and turn off when this stuck in park issue happens. And if I wiggle my shiftier the "P" will flash again and sometimes am able to get it out of park like that.
Also when I shift into reverse my back up lights will not come on... and on the dash the "R" will be off.. but as soon as I wiggle the shifter the "R" light will come on and my rear reverse lights will come on.
What could this problem be..?? This doesn't happen every time it will happen randomly..
jerrytsx (12-06-2021)
Old 01-28-2015, 05:56 PM
9th Gear
Str8-Ownage's Avatar
TexasHonda is my hero!!! wd-40 fixed my issue .
Old 12-05-2015, 07:20 PM
gtrr4's Avatar
08 tl
So my symptoms are the same, shifter stuck and no brake lights. My additional symptom is the vsa light is on, cruise does not work and the #13 20amp fuse continues to blow. So will a faulty brake switch cause all these things?
Quick Reply: Shifter stuck in park (need help)
