Squeaking belt
Old 02-18-2012, 04:18 AM
teohenwhy's Avatar
Squeaking belt
My 02 TL-S has this problem where when I start the car when it's cold there is this loud squeaking noise coming from the passenger side where the belts are at. After the car warms up the noise goes away. What could it be? Thanks in advance.
Old 02-18-2012, 10:32 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
a worn out belt, the main belt tensioner failing, the ps belt not tightened correctly
(caution: it does need more play than a normal belt)
teohenwhy (02-18-2012)
Old 02-18-2012, 10:39 AM
AznWay's Avatar
try showing us youtube video so we can help you out better.
Old 02-18-2012, 06:35 PM
teohenwhy's Avatar
Could it be the timing belt? I will try and upload a video soon.
Old 02-18-2012, 06:44 PM
teohenwhy's Avatar
The funny thing is that this started after getting my oil changed at Jiffy Lube. Could something they did while doing inspections cause this? I know they inspected the belts.
Old 02-18-2012, 06:52 PM
teohenwhy's Avatar
http://www.youtube.com/watch?v=8JrX4...ature=youtu.be
Old 02-20-2012, 01:16 PM
6th Gear
almightycrunch's Avatar
No, a timing belt cannot sqeal.
Old 04-07-2012, 12:38 PM
Ronmarr1's Avatar
I am having this issue on cold mornings as well - sounds like either a belt or maybe a bearing squeal - I had all belts/ idlers/tensioner, water pump, seals, etc. changed out when I had the timing belt service done 2 yrs ago @ 101k mi. Now at only 113k miles.
Ideas?
Old 04-07-2012, 03:43 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Ideas?
Miles mean less than age. Was the belt a honda belt or a autoparts store belt?
Old 04-07-2012, 07:36 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
It doesnt sound like a Belt Tensioner problem... By looking in the video the PS Belt looks like the "Mitsuboshi" OEM.. but I dunno about the ACC belt.
IMO Use only OEM I had a Gatorback in there sometime ago and It did squeal alot...
Old 04-07-2012, 07:57 PM
Ronmarr1's Avatar
All parts for the timing belt replacement, including all belts, idler(s?), tensioner, seals, water pump, etc, were Acura OEM - only 2 yrs ago and about 12k miles since the install. Belts look fine and tension "appears" correct. Wonder if it might be alternator or power steering pump bearing? Noise is only when cold.
08KBP_VA
10-22-2019 01:55 PM
brboy
10-05-2015 11:34 AM
Jboat
09-30-2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: Squeaking belt
