2002 radio issue
Old 02-28-2014, 09:45 AM
9th Gear
kwall65's Avatar
2002 radio issue
Hey Y'all,
I just purchaed a 2002 tl that was just a lil dirty and needed tires the radio lost power but right before was showing an error on the screen and would not eject the CD's I checked the fuse and replaced in case I could not see the break ..
Now i have seen posts in here have gone unanswered so as a newbie I guess I will wait and see..
anything I could try would be helpfull
thx in advance
Keith
Old 03-03-2014, 12:57 PM
acutee's Avatar
Did you give it power so it can continue to eject the disc?
Old 03-03-2014, 09:26 PM
tubesock700's Avatar
I have had issues with the CD changer ejecting the discs if I used burned CDs. The disc will try to eject, and you can see the disc barely peek through the dust guard. The radio will error out then fail to operate. This is what I have to do in order to get my discs out (this may not be your issue):
1. When the disc comes partially out and the stereo errors, turn the key to "off".
2. Turn the key back to ACC mode and then press "eject" again.
3. While the disc is peeking through the dust guard, you can hear the stereo attempting to eject the disc. Take another disc and stick it over the top of the disc that is stuck and press down on the stuck disc with the new disc. This puts more pressure on the ejecting rollers that are trying to grab the disc and push it out.
4. Grab the disc when it comes out and the stereo should be asking to "Load" a new disc.
I have since replaced my stock stereo with a 7" DVD player, but I used that method over 50 times without issues.
Old 03-04-2014, 10:09 AM
9th Gear
kwall65's Avatar
as of now there is no power to the head unit I had planed to take the unit out this weekend but had ta watch the kiddos but almost had it done (out) before they woke up from their naps to no avail .. will check power going to the head unit .. is there an inline fuse behind the head unit? when I contacted the previous owner they said they have replaced the head unit w. factory unit for the same issue before So i am thinking bad ground maybe ?? lose plug? will post findings and and other help is appreciated
Old 07-31-2015, 04:22 PM
8th Gear
sharkwaters's Avatar
NO JOKE.....Hit it harder while ejecting the CD...I didnt believe it either till it worked!
Sorry DEALERSHIP...no $400.00 for you today!
Ol'Dave
09-05-2020 02:56 PM
vanderveen44
ILX
09-16-2015 10:51 AM
02tljj
09-11-2015 12:37 PM
kuzdu
09-10-2015 08:42 PM
ellisd03tls
09-08-2015 04:17 PM
Quick Reply: 2002 radio issue
