Disconnect Battery Before Brake Fluid Change?
Some car requires disconnecting the battery during brake bleeding process. This is to avoid ABS activation during bleeding but does the TL requires the battery disconnected? I think not but just wanted to confirm.
Thanks in advance.
Mike
Thanks in advance.
Mike
Does ABS turn on when your car is off
justnspace (08-19-2015)
Confirmation-ception.
It's supposed to be off when doing any brake bleeding.
you can bleed the car while it is off. it is easier when you have 2 people but you can use a 1 man bleeder kit and get it done.. I bleed each wheel until clear fluid comes out.
The following 2 users liked this post by MikeTC:
justnspace (08-24-2015),
YeuEmMaiMai (08-25-2015)
mada51589
05-03-2022 08:54 PM
ulrblitzer
09-24-2015 07:42 PM
