Noise
Old 02-01-2017, 03:19 PM
6th Gear
Aaronh615's Avatar
Noise
I have a 2008 Acura tl. It has 140,000 miles on it and I purchased it at about 120. No mechanical issues since I've bought it but recently it started making a noise when I reach about 40 miles per hour. It doesn't happen all the time but when it does it sounds almost like I'm going over rumble strips. It doesn't last long maybe a second or two. Other than that my car seems to be in great condition any ideas what it could be?
Old 02-01-2017, 05:51 PM
srg818's Avatar
Sounds like torque converter shudder. Automatic transmission? Does it happen at light acceleration and low rpm? If so, have you done a 3x3 ATF drain and fill? AT pressure switches replacement is also a good idea with the ATF change.
Old 02-01-2017, 05:57 PM
6th Gear
Aaronh615's Avatar
Yes automatic, and yes at low rpm. Do you know the cost of something like that? I haven't done a 3x3 but I am going to take it into the Acura dealership soon. The pressure switches sound expensive. But at least it's not a major fix!! Thanks for your response, I'm very relieved to know it's not a transmission problem!!
Old 02-01-2017, 06:09 PM
srg818's Avatar
How long has this noise been happening? It's a good idea to do the 3x3 drain/fill and change the pressure switches even if they are not the source of this noise since it's a common problem on 04-08 automatic TLs. The pressure switches are around $30 each so not too expensive. I would also ask the dealership to rule out the axles and/or engine mounts causing some sort of resonance vibration at the speed you mentioned.
Old 02-01-2017, 06:17 PM
6th Gear
Aaronh615's Avatar
I'm definitely going to do all of that!! Seeing as how it's not going to break me, I can do it this week! Thanks alot for your input. I feel so much better about it now!
