Battery voltage lowering - with no parasitic draw when parked.
Old 08-30-2015, 02:47 PM
adreano17's Avatar
Unhappy Battery voltage lowering - with no parasitic draw when parked.
I will go from 12.8 to 12.4 in 8 hours or so. Add that up for a couple of days, and my battery will go dead.
I ran the amperage from my DMM on the 10 ADC setting. I will get about 0.03-0.02 (I believe that is normal).
I went out of the country for a week, and my battery was DEAD @ 6V. I had to buy a new one. This is doing it again with a brand new battery.
Thoughts and suggestions.
Old 08-30-2015, 07:32 PM
WDPanda's Avatar
Check the spot above your rear view mirror for heat. It could be a malfunctioning HFL.
Old 08-30-2015, 07:55 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Swap the setting on the DMM to milliamps. DO NOT TURN ON THE CAR WITH IT HOOKED UP. Make sure the meter is in SERIES and not in PARALLEL with the battery.
It should be around 20 milliamps with the car off after 10 minutes of locking the car.
Pull the fuses one by one until you can get it to drop! Also are you locking the car? Do you have an Ipod adapter installed?
Old 09-16-2015, 02:54 PM
adreano17's Avatar
That did the trick. I removed the fuse under the hood and it still did it, so I thought it wasn't the HFL. Completely disconnected the HFL, and the heat stopped as well as the drain. Thanks for the insight.
MetalGearTypeS
08-29-2016 08:28 PM
MrHeeltoe
09-29-2015 10:43 PM
San Yasin
09-29-2015 10:52 AM
MrHeeltoe
09-28-2015 05:43 PM
rhdune16
09-28-2015 11:31 AM
Quick Reply: Battery voltage lowering - with no parasitic draw when parked.
