2005 TL automatic whining when accelerating
Hey Everyone,
Need some help. I'm an Assistant Service Manager at a Lexus dealer in Montreal. We got a 2005 TL with 144,000 kilometres (100,000 miles) as a trade in and I jumped on it. Clean, all maintenance done at Acura dealer, no major issues at all. Only thing I'm getting a whining noise when accelerating, mainly 1st and 2nd gear. Some of the mechanics I work with say its a tranny issue, others say it isn't. Gears change smooth, no delay or slipping. When I put it in neutral noise is gone. Noise is there as soon as I barely touch the pedal. Parts manager buddy of mine at Acura says may be the tranny, but I'm not too sure. Anyone else had this issue?
check your front wheel bearings
I had the whine and it turned out to be driver's side bearing took a crap. replaced it and no more whine. There is a TSB that indicates some differential noise is normal on these newer transmissions.
hopefully it is not a torque converter coming apart as that means new transmission
Hey Everyone,
Hey OP, you sent me a PM but I can't reply, apparently your inbox is full. Delete some messages or message me your phone number. I'll be glad to help.
It shouldn't. If you are worried, look into the 3rd and 4th transmission pressure switches. Apparently the failures we see on our trannies are related to those, I don't think heat is the biggest factor. It's not costly and you can even DIY replacing the switches, good preventive maintenance.
I haven't done the pressure switches. I DIY'ed the PS o-ring, go to luciani Acura on jean-talon near Decarie. They have the o-ring in stock at all times if I recall correctly. Plus Steve (the parts guy) is a pretty knowledgeable guy when it comes to those cars.
The o-ring replacement takes about 5-15 minutes to do, pretty simple DIY. Only thing is you have to make sure you get the old one out and it tends to stay inside when you take the hose out. I could explain it better to you in person cuz my memory is a bit fuzzy.
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
