Puppetmaster's 2011 TSX Wagon
Old 01-22-2015, 11:29 AM
  #41
2012wagon's Avatar
THank you sir!
Old 01-29-2015, 11:32 AM
  #42
dhuynh's Avatar
Thank you for not getting reps! CE's are a classic.
Puppetmaster (01-29-2015)
Old 01-29-2015, 06:03 PM
  #43
jeroplex's Avatar
thinking about some CE28n..whats specs are you running
Old 01-29-2015, 06:07 PM
  #44
2012wagon's Avatar
Written in first post of this thread, page 1
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 242KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 297KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 3KB.
The car is lowered on Eibach Pro-Kit springs, with Koni Sports (Yellows). Rims are Volk CE-28N in titanium gunmetal, 18x8.5 +30 ET. Got some bald 245/40/18 Falken Azenis RT-615 on now
Old 01-29-2015, 06:15 PM
  #45
jeroplex's Avatar
whoops missed that
Old 01-29-2015, 08:16 PM
  #46
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Hey puppetmaster, was curious. I read that you rolled the rears and haven't touched the fronts while running 245s all around. Anything change? Also, have your fronts rubbed at all (including heavy compression of the front suspension)?
I'm thinking of running 18x9 +30 in the front next, which is very similar to your setup (0.5" wider in wheel width). I think I'm going to need a front fender roll as this would mean ~6mm more poke than your setup.
Thanks!
Old 01-31-2015, 09:54 PM
  #47
Puppetmaster's Avatar
Thanks!
No rubbing as far as I can tell. My front camber IIRC is very slightly negative with the Eibachs and I bet if you had issues you could get a front adjustable ball joint to dial in a little negative camber to eliminate any rubbing. Or just use less tire than my 245/40.
xtcnrice (01-31-2015)
Old 02-11-2015, 09:13 PM
  #48
SQUEEZY83's Avatar
Hey PuppetMaster really like the wagon. I have the same color wagon as you its really rare in NOVA I've only ever seen two other wagons in this area and both being driven by grandmas. Maybe one day ill see you driving around id like to see your setup in person.
Puppetmaster (02-16-2015)
Old 02-16-2015, 03:25 PM
  #49
Thanks. Just look for the lowered GLM wagon crusted with salt...
Had a little bit of cabin fever today and drove around a little, including stopping for a few pics despite the negative temp wind chills. Just to say that I did it, I guess, lol.
The following 2 users liked this post by Puppetmaster:
MC MiYoung3269 (02-24-2015), xtcnrice (02-16-2015)
Old 02-17-2015, 08:36 AM
  #50
Bchester6's Avatar
That looks cold from here!
Old 03-03-2015, 02:27 PM
  #51
2012wagon's Avatar
Originally Posted by Puppetmaster
The car is lowered on Eibach Pro-Kit springs, with Koni Sports (Yellows). Rims are Volk CE-28N in titanium gunmetal, 18x8.5 +30 ET. Got some bald 245/40/18 Falken Azenis RT-615 on now, but those will be replaced by Conti ExtremeContact DW this week, along with a much needed alignment and fender roll.
Puppet,
If you do 18x8.5+30 but on a 225/40, do you think you can get away without a roll?
Old 03-09-2015, 12:43 PM
  #52
I think so. I saw a pretty big difference test fitting some 235/40, so I'm guessing 225/40 can only be "better", if you're talking about preventing rubbing. You guys know how I feel about using undersized tires.
Old 03-09-2015, 12:48 PM
  #53
2012wagon's Avatar
I rather have the wider/meaty tires, so just wondering playing with offset vs tire size. I want to keep rolling fenders to a minimum if possible.
Maybe time for you to get some new shoes, and sell the ones you have
Old 03-31-2015, 09:29 PM
  #54
3rd Gear
tildowns's Avatar
Love the wagon. Just started on an '11 TSX wagon myself. You've showed me some good ideas. Thanks
Old 05-19-2015, 08:40 PM
  #55
Here's my usual cell phone picture in bad lighting. Just washed (not that you can tell) and summers were only reinstalled last weekend.
Old 05-19-2015, 09:39 PM
  #56
BROlando's Avatar
Received 1,166 Likes on 877 Posts
Originally Posted by 2012wagon
Puppet,
You want a 225/45. 40 is too short.
High performance 225's run wide. I have 225's on 8.5 + 38....and my wheel set clears my 100% stock rear fenders by about 1/4" (6mm). The front is probably a bit less at full bump.
The 8.5+30 is 5/16" (8mm) more agressive than a 8.5 +38. They *might* fit and they *might* rub with stock fenders. With a roll, they'll fit with tons of room to spare.
I wouldn't say 225/45 on a 8.5" wheel is alarmingly undersize...if at all undersize.
Pilot SS's tend to run a little bit narrower compared to other tires...FYI. Or maybe it just seems like that to me I'm just used to 225 width track oriented tires....which almost definitely run wide.
Old 05-19-2015, 09:45 PM
  #57
xtcnrice's Avatar
I actually felt like my 225/40/r18 PSS run a bit wider than expected. I think comparing them to other street summer tires, they're considered "wide". But maybe comparing them to track tires they're considered "narrow". This I wouldn't know since I've never owned track oriented tires.
Old 05-19-2015, 10:09 PM
  #58
Yumcha's Avatar
Received 22,653 Likes on 13,892 Posts
Nice car.
Puppetmaster (05-20-2015)
Old 05-20-2015, 05:32 AM
  #59
BROlando's Avatar
I've experienced a few sizes of SS on a couple different cars.
To me, it looks like 225/45/17 or 245/40/18 sizing for the SS is narrower than other tires. I think even Continental or Goodyear all season tires in the same size run wider. Dunlop or Bridgestone "max performance" (same category) street tires seemed to be wider as well.
But maybe its different for 18's.
Old 05-20-2015, 07:14 AM
  #60
Couple more in low light. I don't know why I have such trouble remembering to take pictures when it's bright out.
Old 05-20-2015, 08:59 AM
  #61
xtcnrice's Avatar
Wagon looks great Puppet
Old 05-20-2015, 09:44 AM
  #62
Thanks man.
I honestly don't know why I bother blurring out my tags (I do it out of habit). How many TSX wagons are there out there lowered with rims, let alone around where I live? Haha.
Old 05-21-2015, 07:37 PM
  #63
2012wagon's Avatar
You block out tags so we can't steal your wheels ?
Found your wheels in 19
Diff offset
Trying to figure out if too sunk or make the leap
Where did you get your center caps
Old 05-26-2015, 06:54 AM
  #64
My center caps came with the rims.
I really wanted the black and red GT ones, but I like mine enough that I'll keep them for now.
These are the ones I would have loved to have:
Old 05-26-2015, 04:04 PM
  #65
2012wagon's Avatar
aHH
gorgeous
thank you sir
Old 05-28-2015, 02:08 PM
  #66
It's amazing how quickly dark cars get dirty. I didn't even get a chance to take proper pictures in daylight and now it looks like it needs another wash.
Yumcha (05-31-2015)
Old 05-28-2015, 02:09 PM
  #67
2012wagon's Avatar
Yeah I do a quick detail after every drive
Though having sunny
And garages at work and home helps
Old 05-28-2015, 02:49 PM
  #68
xtcnrice's Avatar
Beautiful
Puppetmaster (05-29-2015)
Old 05-29-2015, 01:36 PM
  #69
Though having sunny
My car is garaged at home and work too, but quick detail?
urbanstereo (07-20-2015), xtcnrice (05-29-2015)
Old 05-31-2015, 11:37 AM
  #70
2012wagon's Avatar
Takes me 7 minutes
Old 05-31-2015, 01:43 PM
  #71
Yumcha's Avatar
@ pics...
Old 07-09-2015, 07:06 PM
  #72
Off roading! Had to park/drive through a muddy field... almost got stuck, lol.
Old 07-09-2015, 10:07 PM
  #73
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
<pic>
Marks of honor right there! Shiny paint pictures are nice, but this is the money shot.
Nice.
Puppetmaster (07-10-2015)
Old 07-10-2015, 09:24 AM
  #74
I'll say that the Conti DW (not DWS) held their own in the mud until I hit an area that was puddled and torn up with deep tracks from SUVs and larger cars. That was the struggle. Admittedly, I felt a slight urge to find a spot in the field to do some mud donuts, but didn't, probably for the better.
Old 07-18-2015, 08:04 PM
  #75
Playing around with a new camera (and clearly have not learned how to use it well) and thought I'd post some pictures.
Old 07-18-2015, 08:09 PM
  #76
Oh and guess what? I washed all the mud off my car last week, only to end up in the rain, and in another unpaved parking lot. No traction issues in this one though.
Old 08-04-2015, 11:24 PM
  #77
2012wagon's Avatar
Nice pics
Sell your wheels
and go offroadingn with the stockers
What is the new decal by the pillar on the rear hatch area?
Old 08-10-2015, 02:06 PM
  #78
Nice pics
Sell your wheels
Kids' sports teams magnets, those come off when the seasons are over.
Old 08-13-2015, 11:34 AM
  #79
2012wagon's Avatar
Ah makes sense.
Been without wagon for 3 weeks. Stuck in TLX. So looking at your pics to make me feel better
(warranty work)
Old 12-14-2015, 01:54 PM
  #80
Winter mode engaged...
The tree is not a permanent mod though.
My last picture from the summer:
xtcnrice (12-14-2015)
Quick Reply: Puppetmaster's 2011 TSX Wagon
