Type S turbo build, remote mount
#562
J-series addict
Sorry to hear about the punk ass who stole your equipment man, that sucks. I know when my car is on boost, just driving one day without the ability to datalog or tune would drive me CRAZY!
On another note, progress is looking good. I didn't have a chance to read all the posts but how are things going with the meth injection setup?
UTAH Type-S (10-01-2015)
#565
Been playing with the launch control settings on the flashpro for a mean sounding rev.
[URL="https://www.youtube.com/watch?v=JPicFmTqSdI&feature=youtu.be"]https://www.youtube.com/watch?v=JPicFmTqSdI&feature=youtu.be[/URL
Also had some issues with the engine cutting out at higher boost levels.
So i re-gapped the spark plugs down to .022". Once the boost controller learns the duty cycle, ill begin tuning the high boost setups.
Once thats done ill be going back to my low boost with the scramble boost button for the high boost. Low boost will be about 10 is lb and 14 for the scramble button. After that ill have to put performance on the side burner, im starting school and wont have time to rebuild the engine or transmission if something goes wrong. But once im through with schooling and got my career on the right path. its on
Heres my last edyno at 11 lb
I know the accuracy is questionable, and when its ready and at its prime ill get a real dyno. But still not bad I think
#566
#570
#571
Well the kids car is getting fast, I'm going to have to step up the game, in the last pull (2nd video) if he didn't let off at 135-140 MPH he would have quickly pulled ahead of me.
sorry I cant figure out how to edit my sjcam and make one shorter combined video ?
http://api.viglink.com/api/click?for...%3DUU7fjUFC9xU
http://api.viglink.com/api/click?for...%3D2Z-DQSylXlI
http://api.viglink.com/api/click?for...%3DtWakGgJo6nI
sbuoy (04-21-2016)
#572
bump
#573
I see the bump.....Any new info? Was hoping for an update on all the radiator mods done, but that won't be possible now with utah, and everywhere else for that matter freezing.
#574
than my TL
#575
06 Acura tl Turbo
Wassup you guys i was just wondering if any one knows where i can get a turbo kit set up for my 06 acura tl and how much it would cost me on the set up and all really been looking for a turbo kit for it but cant seem to find one please help me thanks much appreciated you guys
#576
I broke out the spoon for you in your other thread, but I don't know if you'll eat from it since it appears you haven't read anything yet. Please try not to take offense to this, tone doesn't come across on the internet, and I say this partially in jest. It might be a generational thing, but I know many here get frustrated when people ask a question that has been answered many thousands of times and its obvious no prior investigating has been done.
#580
#581
10k is still pretty cheap when you think about it too i got mine done for about 6500 but had a lot of help from my dad. Otherwise i would have about another 2500 worth of scrap metal and wrong parts laying around too.
#582
#585
It's still running he is working full time and going to school at night, he is wanting to build a new engine with super low compression, anyone have a j35a8 short block for sale cheap ???
#593
Yeah its turbine side. My turbo seized up on me a couple days ago and when i got it off and took off the turbine housing i saw that. I was hoping it was heat related but when i took off my O2 sensor i noticed there were signs of something hitting it. Got my spark plugs off and stuck a borescope down to get a look i saw this
This was the left side of #6. The right side has a crack in the same spot.
#5 also has a piece missing. 4 looks good and i haven't looked at 1 2 or 3 yet so im in the market for a block and saving up for new pistons.
#595
Ill let you know in a week or 2. I think my piping should be long enough to carry away all the heat and pressure away from the cylinder heads. Also doing the HFPC so let see how well they hold up
#596
Well.....got the head off this morning. And this is what i saw. This is definitely what killed my turbo. You can see where the piece of piston broke off and got smashed. If you look at #5 you will notice that there is a second piece that had to have broken off a while ago on the right side. You can tell by the carbon buildup on the ring, and that leads to another question. My motor was running just fine. How the hell did the motor not fail? Thats the piston rings you see exposed.and judging by the black buildup. The right side lost that piece some time ago. So where did that end up?
#598
I was running about 6 lb on a regular basis and 10 ish lb every now and again. This was the custom set we had made. The back bank was the k24 pistons. The front bank was the same as far as specs go just backwards
#599
Hmmm so all damage occurred within cylinder 4-6? Or did cylinder 1-3 also sustained some damage? Its soo sad to see this happen . I think I am going to keep my boost around 5-6psi now
Do you think that having the piston be backward could have cause some P2V contact? The intake side is much larger than the exhaust side.
#600
Sorry to see this.
In both cases, the failure appears to be at the point where the top of the ring gap to the crown is the thinest.
What did you run for the end gap on the top ring?
Did u also kill the valves?
When my stock piston gave up, it also stayed intact. When I pulled it out, large chucks fell out.
