Honda/Acura Mechanic in North NJ
#121
Made the three hour hike back down to Paul a couple Saturdays ago to have him do the 105k (about 8k late). He replaced the TB, tensioner, idler, adjuster, and water pump (Aisin kit), oem drive belt and tensioner, thermostat, upper/lower radiator hoses and clamps and also sway bar end links.
Car's running great! Thanks Paul!
acrdr (12-09-2015)
The following 2 users liked this post by acrdr:
DeathMetal (02-08-2016),
The Dark Knight (12-27-2015)
The Dark Knight (01-02-2016)
#126
hello Paul .
i have a 2009 acura rl i did some collision repair and mechanic as well
my vsa and sh-awd lights are on !!
i took the car to dealer thinking they where going take care this problem they did NOT. i tried erasing the code and they come right back ! can you please help me !!
mechanic told me i need to do AFS memory and steering angle sensor reinitialize, and neutral switch too.
can you help ??
can you help ??
#127
But I know someone that knows Audi inside out. He work for Audi .
The Dark Knight (01-05-2016)
#128
hello Paul .
can you help ??
can you help ??
#132
Throwing in a kudos for Paul. He just completed my AV6 swap in my 02 TLs and did a great job. He's thorough, honest, very fair on pricing and very flexible. He even did some extra things like my rear engine mount etc.
acrdr (04-04-2016)
#134
Met up with Paul last week for a few things on my Accord. As everyone in this thread has already stated Paul is a great guy, really cool and an easy going dude. You can tell he really knows his way around these cars, and this is from someone that has owned and worked on Hondas/Acura for a long time. No one in the Tri-state area should hesitate one bit in bringing their car to Paul for work on their Honda/Acura; it's well worth the trip.
Now, on to looking for an AV6 for my TL for paul to do the swap.
#135
2005 V6 Accord Transmission
Hi everyone
my name is Paul and i have been working for Honda and Acura as a mechanic for over 10 years
I am located in Clifton NJ
If anyone here needs any work done to their Honda/Acura .
I will be more than happy to help you out
I have a nice size garage at home that i work out of
Anything from Maintenance to Upgrades.
And if i cant do the work i will try to point you in thr right direction.
My car's trainsmission are broken, do you do the replacement, or can you please point me to any specialist? How much will it cost roughly?
Tnx, my contact is 9734627851, Cliff
#136
105K service...
Paul,
My mother lives in Clifton and I am interested in linking up with you in the near future to schedule the 105K service along with a general inspection of my vehicle. Just purchased a 2008 TL Type-S. It has about 95k on the motor. Everything is stock and from what I can tell the car was meticulously maintained. Based on the feedback I'm am interested in doing business with you. Thanks.
Alex G.
Alex G.
#138
Hi Paul my name is Tony. I got ur name from a guy here on the forum. I leave in jersey and I have an 01 TL that I want to do a av6 swap. All these guys say you the best in the game. I want to get in contact with you to make this happen. My granny is already slipping. Thanks, hope to hear from soon.
#139
Hi, Paul
it seems you have done transmission swap for TL ? I have 2001 TL (black that you worked on once for brakes) that it happens a few times that D5 mode can't engage that driver (my father in law) had to shift between N/D4/D5 to get it going. so I would like to swap in a Honda accord 06/07 AT ? please let me know whether you do it. If yes, it would be great if you could source AT and I will just leave the TL to you for the swap ?
James (973-368-3328)
#140
Very knowledgable
I've used Paul on a couple occasions and wanted to say that I'm extremely happy with his work. He defiantly knows what hes doing and also takes the time to explain and recommend things that need to be done, or what should've been done (i.e. alignment after getting new tires).
His prices are also very reasonable.
I'll be going back in a few months for the 105K service.
#141
Mechanic Feedback
Vehicle Info: Stock 2008 TL Type-S, automatic transmission
Mileage: 96,000-ish
So I just had work completed on my car with the assistance of Paul Sobstyl. His shop is located in Clifton, NJ (Northern NJ). Based on the positive feedback from other customers, I decided to do business with him. Without a doubt he is very knowledgeable (Acura & Hondas are his specialty), courteous, and takes the time to explain everything to you in full-detail throughout the entire process. It was definitely a great learning experience for me. His shop is very clean, he's very skilled, and only utilizes top-quality parts. His prices are also very good and he does not compromise quality of service by doing so.
Completed Preventative Maintenance Repairs:
Timing belt kit, drive belt, valve adjustment, compliance bushings, sparkplugs + seals, PCV valve, radiator hoses, and engine/tranny mounts, throttle body cleaning.
***Please note, these repairs were all done at once. The goal is to address these parts in advance prior to them failing. Additionally, we addressed common items that needed to be replaced based on my current mileage.***
Performance Review:
The car runs very smoothly now. It was running well before but the difference was more noticeable to me after I picked it up. The car shifts like butter when changing if from park to drive. I attribute this to the new motor mounts. It doesn’t have that jerking reaction as it did before. The ticking noises also went away and the belt no longer squeals. I also feel an improvement during highway driving – less vibration. Normally, the motor would be much louder in colder weather (ticking) but it’s no longer an issue. This morning it was 37 degrees by my house and the car was very quiet during idle – a very good improvement. The car is more responsive in the lower RPM range. I attribute this to his tune-up. Paul, the good guy that he is, threw in free radiator hoses and inspected my rear brakes out of courtesy. I certainly appreciated the new hoses!
Paul is the man, worth doing business with, and he will not disappoint. I’m very meticulous when it comes to mechanical repairs on my car and he exceeded all of my expectations. Worth the drive for those outside of the state.
Mileage: 96,000-ish
Performance Review:
DMZ (02-26-2019)
#142
Paul is THE GUY!
I too went to him based on the great reviews on Acurazine forums and he did a great job on my 3g TL Type-s for water pump, engine mounts and stuff.
Paul knows his stuff!
We should start a go fund me and get him a shop or something (haha)
I know I will be returning with ball joints and tie rod jobs to him in the future
#143
Thank you for all the great reviews.
I will not be around for few weeks .
If I don't respond to text or call.
I'm sorry.
I will be back after July 21st.
Thanks and everyone have a great summer.
I'm sorry.
#144
Hey! how much to switch motor and Trans mount on 2006 acura tl automatic including parts?
#145
Av6 swap in a 2000 Acura TL
Hey paul im new to the forums and have been looking into the accord trans swap into my TL because the trans is going bad. I heard good reviews about your service and wondered would you have the time to work on my car ?
Acura11 (08-06-2016)
#146
Hi Paul!
I'm in Jersey as well and looking for a reliable mechanic. Would you be able to install any of the the following on my 2007 RDX:
-New brakes and rotors
-stainless steel brake lines
-BC racing coilover struts
-top mounted ETS intercooler
If so how much for these each services? Appreciate it! Thanks!
#147
Appointment Request
Paul,
Are you back in the area?
Alex G
2008 Acura TL Type-S
Alex G
Hi everyone
#152
Hey Guys.
I try my best to help out everyone .
I know you guys probably see amsoil everywhere on here, but i figured i give it a try .
I will be using amsoil in my cars . But if anyone is interested in getting an oil change or even just oil from asmoil ,i can supply you with it for a great price .
Thank you
Paul
Thank you
Paul
#153
Your Contact Info (Name, Phone, Address)
Hi Paul,
I have some problems with my 2002 CLS, would like to consult with you. How do I get your contact info?
I live in Secaucus.
Kindly reply back.
Thanks,
Rick
I live in Secaucus.
Kindly reply back.
Thanks,
Rick
Hi everyone
#154
I know I have not active to much on here.
Wanted to share some things with you guys .
This is what happens when you install non type-s rotor on a type-s brembo brakes .
#155
Did a couple of av6 swaps .
And I did a rear main seal on everyone of them since it's right there .
Surprisingly the actual seal didn't leak but the o-ring above it .
