Cruise Control easy to fix? Cost?
Old 10-19-2003, 04:15 PM
3rd Gear
jshort's Avatar
I am planning on doing an 8-hour drive next month... and I currently do not have cruise control - hasn't been working for about 6 months.
Does anyone know if fixing the Cruise Control is a "simply/easy" process... or do I need to bring it into an Acura dealership? If I need to get someone professional to fix it, about how much would it cost?
Thanks,
Jeff
Old 10-20-2003, 12:16 AM
Liem's Avatar
well it all depends on what the problem is, diagnosing the problem will probably be the hardest step. The hardware that is required to run cruise control is straightforward, the main part would be the actuator with the throttle cable attaching to the throttle body. If you have some electrical background, you can test the circuit from that actuator, if the actuator is not at fault, then it could be anywhere between the wiring leading to your cruise control switch and the switch itself. If you have some electrical background, let me know and ill post some diagrams from my service manual for a 2.5TL, and you can fiddle around with it if you have the time.
rockyboy
12-06-2022 02:29 PM
peti1212
ILX
22
01-05-2022 05:14 PM
cycdaniel
12-17-2019 10:58 AM
PortlandRL
09-14-2015 12:01 PM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
Quick Reply: Cruise Control easy to fix? Cost?
