How hot does your car run with the AC on.
Old 07-03-2015, 07:20 PM
Sounder's Avatar
I'm not sure my radiator fans are working right. The temp creeps up in traffic with the AC on and sometimes with it off. Also, the fans don't stay on when I turn off the car.
Old 07-05-2015, 09:23 PM
OhaiOh's Avatar
Mine never goes past about a third no matter what I'm doing. Last time it did my coolant was almost all gone and I had air in the cooling system, so Id first check your coolant levels, then run your car with the AC on and off with the hood open and visually inspect the fans to see if theyre functioning properly.
Old 07-05-2015, 09:44 PM
Ken1997TL's Avatar
Received 2,328 Likes on 1,308 Posts
Yep, get a coolant flush and likely a new thermostat as well just to be safe.
Old 07-06-2015, 11:17 AM
jaydubz's Avatar
Mine sits like 1/3, no matter what, these engines are very bulletproof.
Old 07-06-2015, 07:54 PM
El-Baz's Avatar
The fans don't run once you shut the car off.
My gauge points to the middle of the "D" in "D3" normally. Never much higher.
I had to replace my radiator last winter because it started to come apart where the plastic and aluminum clamp together. Did the thermostat & hoses too. It did just fine in stop & go at 100* last month.
Old 07-06-2015, 08:04 PM
5th Gear
rlineberg's Avatar
Mine sits at 1/3 as well!
Old 07-20-2015, 10:44 PM
Sounder's Avatar
Turned out to be a stuck thermostat.
Ken1997TL (07-22-2015)
Old 08-07-2015, 12:48 AM
RL-R0ckst/\r's Avatar
Never goes higher than 1/3 of the way up, ill be replacing that thermostat and radiator though at my next timing belt job likely, just to get the most out of the labour cost
SpraykwoN
ILX
09-23-2015 11:44 AM
kuzdu
09-10-2015 08:42 PM
jfman55
09-05-2015 02:55 PM
NSolace
09-03-2015 08:02 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: How hot does your car run with the AC on.
