dashboard bulbs
Old 08-07-2015, 03:50 AM
1999 Acura CL 2.3
Gigolo's Avatar
dashboard bulbs
hello
can somebody tell me the bulbs needed to replace the ones in dashboard??would like to have them all ready to input before the cluster is pulled out to save time
thanx all
Old 08-08-2015, 08:33 PM
normaspirated's Avatar
2721/T5/74 bulbs:
Turn signals
"Brake"
High beam indicator
SRS
Check Engine
Seat belt
78181-sf1-612 <--Honda part no.
Low oil
'Battery'
Cruise Control
ABS
Low fuel
P, R, N, D4, D3, D2, D1
Door/Trunk/Brake light out indicator
Old 08-09-2015, 12:06 AM
1999 Acura CL 2.3
Gigolo's Avatar
thanx mate
cheers
p.s..are these for a 99 acura cl 2.3?
Old 08-09-2015, 03:58 PM
Sure thing. These were the bulbs I changed on my '97 3.0. I believe the main differences are that yours has a dash light indicator for a key immobilizer and that the font style of your mph/km/rpm are italicized.
Old 08-13-2015, 09:33 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
The backlit bulbs are all 194/168 wedge bulbs, the ones up top that illuminate down are #74's
Old 08-17-2015, 04:12 PM
1999 Acura CL 2.3
Gigolo's Avatar
thanx mates!
Old 09-04-2015, 07:14 PM
1999 Acura CL 2.3
Gigolo's Avatar
hello again
ill check ebay for em all...i found the 194/168 ones but not sure about the 74s..is there a full name for those vertical ones?
oh yeah..how many bulbs are needed for the entire dash??
even the vertical/down ones...
thanks
Old 09-07-2015, 01:18 AM
stupifye99's Avatar
If I remember correctly, it's two #74s up top and 4 168's in the back. If you decide to go with LEDs, I'd suggest you go with wide LED to spread the light throughout the dash.
97BlackAckCL (09-10-2015)
Old 09-10-2015, 10:35 AM
(Mid-Atlantic)
Originally Posted by Gigolo
hello again
thanks
They're just #74
https://www.superbrightleds.com/cat/...ber,74,21,203:
Correct, the two #74's are in the top aiming down, there are 4 168 wedges, and yes, definitely do the wide angle LED's or you'll have hot spots
Old 09-15-2015, 10:30 AM
pstomps's Avatar
So to make sure, 6 of these 74 LEDs and 15 of these 194 LEDs should cover all of the cluster bulbs?
Or is it +2 of the 74 and +4 of the 194 to cover backlighting as well?
EDIT: This thread helped. 4 168/194 bulbs + 1 74 (blue incandescent recommended by Musulsa) for back lights only.
Old 09-15-2015, 07:54 PM
Randy99CL's Avatar
Just to add some info, those two 74s at the top illuminate the needles on the gauges.
Mine both were out when I bought the car. It was weird the first time I drove at night.
Old 09-15-2015, 08:53 PM
stupifye99's Avatar
You'll want 2 bulbs of #74 not 1.. unless you only need 1, of course.
Old 09-21-2015, 12:05 AM
Randy99CL's Avatar
I've got the service manual on CD and it shows 4 3W bulbs and one 1.4W for backlighting, and two 1.4W bulbs at the top front to light the gauge needles. So 4+3 is 7 total.
Haven't taken mine apart to know for sure.
Old 09-21-2015, 12:27 AM
Randy99CL's Avatar
Never tried to upload a pic before:
Gigolo (10-16-2015)
Old 10-09-2015, 12:33 PM
1999 Acura CL 2.3
Gigolo's Avatar
great thanks for all the info!
hashbrown
02-18-2022 11:20 AM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
h22lude
09-27-2015 06:22 PM
ripit
09-26-2015 06:19 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: dashboard bulbs
