Advance package really needed for heated seats?
mrgold35
You need the Adv model for cooled seat.
Everything is simple there, for maximum comfort, you need to unscrew the 2 front and 2 rear seat bolts, stop the seat in the middle, lower it to the lowest position, and bend the back 90 degrees, disconnect the negative battery terminal, disconnect the main seat connector, and the SRS connector. Then it is advisable to wrap the sharp ends of the frame with rags (so as not to scratch the threshold and door trim), and then carefully remove the seat. Put the seat on the table, take a picture of the bottom, remove plastic trim and slowly detach everything in the way, step by step, until you get the hooks that hold the cushion, remove the cushion, carefully remove the leather upholstery from the cushion, I had small latches, you can have metal staples (in this case, you come to cut all of them with the help of cutters and install ziptai in their place). This work should take 3-4 hours. If you've done this before, you'll be done in less than 3 hours.
bsprinker
01-31-2016 02:16 PM
