Seafoam Install
Old 07-06-2005, 11:38 PM
klepto's Avatar
Seafoam Install
Disclaimer: by using these guides, you are removing me from any liability that is related to any injury that might occur. I would suggest having a friend help you on these installs, if you are unsure about your abilities for any of these projects, get a professional to do it.
Credit goes to EPS CL for the original write up and pictures
Hey Guys,
I just finished doing seafoam on my 3.0 with a friend and thought that I would share a couple of pics of what went down. Basically, we did 1/3 in the PCV valve, 1/3 in the oil, and 1/3 in the gas, then went straight for an oil change afterwards. Anyways, here are a few pics of it all:
The bottle itself. I picked mine up at O'Reilly for about 6 bucks.
This is the tube we used to suck it in. You can see the little 'T' connector we took it off of.
A closeup of the actual 'T' connector.
Now some videos:
Vid One: us sucking it into the car. Always important to do it a bit at a time.
Click Here
Vid Two: smoke shooting out. Lots of fun here.
Click Here
All in all, it was a lot easier than I thought it would be. Within 30 minutes, we had done everything, including an oil change. Hope this has helped all. Feel free to ask any questions and I'll try to answer them the best I can.
Old 07-15-2005, 07:18 PM
DaInFaMMuS1's Avatar
can this only be done on 3.0's ?
Old 07-15-2005, 08:34 PM
SSM Accord V6 6 Spd
EPS CL's Avatar
Nope, it can be done on the 2.2/2.3 models as well, you just have to find the same hose on your car. Same concept, different engine.
Old 07-19-2005, 12:47 PM
sittinwithedog's Avatar
From : https://acurazine.com/forums/showthr...hlight=seafoam
OK, here you go step by step...
1. Park the car in a well-ventilated area.
2. Get a small cup and poor 1/3 of a pint of SeaFoam into it.
3. Disconnect the brake booster vacume line from the bottom of the brake booster.
4. Adapt the hose down to a smaller size... The booster hose is rather large.
5. Start the engine.
6. Slowly suck in a little SeaFoam at a time...Note, your engine malfunction light is going to flash, the ECU gets a bit upset. Your engine is going to smoke, stumble and sputter.
7. Now try to drown the engine. Let it suck in enough to kill the engine. Mine would not die... You may have to shut it off.
8. Let the engine sit for 5 to 10 minutes. Druring this time, reconnect the vacume line to the brake booster.
9. Start the engine and rev it a little... No more than 3500 rpms untill the engine nolonger stumbles. NOTE: the engine may be a little hard to start. Don't fret, just keep cranking. It will start.
10. When the engine is nolonger stumbling, turn it off and reset the ECU. If you don't have access to an analizer, you can disconnect the positive battery terminal for about 30 seconds.
11. Now take 1/3 of a pint of SeaFoam and put it in you crank case. Start the engine and rev it a little... No more than 3500 rpms.
12. Turn it off and let it sit for about 10 minutes.
13. Drain engine oil, remove and replace filter, replace engine oil.
14. Poor the last 1/3 of a pint of Seafoam into 1/2 full tank of gas. Drive around for a couple of mile. Your car will smoke a little.
15. Top off your tank, and you are done.
16. While burning the first tank of fuel, you will notice a smell that is similar to a radiator leak. It is the fumes from the burning SeaFoam in you fuelk system.
that is it. You are done.
Should I suck through the PCV valve or the brake booster vacuum line (or are they the same thing)?
Old 07-25-2005, 12:10 AM
Ahhhhhhhh
LLWesMan's Avatar
Can we get a step by step of it being done on a 2.2?
Old 08-03-2005, 03:26 AM
1997 2.2CL black on black
UTsmokey14's Avatar
whats the point of this?
Old 08-03-2005, 08:08 AM
VB87's Avatar
Cleans the internal part of the engine.
Old 05-19-2008, 01:51 AM
Custom User Title
Gnate's Avatar
Has anyone seen any positive difference after using seafoam, aside from the entertaining smoke show?
Old 05-19-2008, 08:26 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,414 Likes on 3,024 Posts
With less carbon build up you should see increased gas mileage and less hesitation
Old 05-19-2008, 09:43 AM
98 2.3 CL
jameswbl's Avatar
cleans the internal engine plus choke and kill your cat earlier in the process too
Old 05-20-2008, 11:36 AM
Custom User Title
Gnate's Avatar
haha, brilliant.
Old 10-11-2008, 10:13 AM
Old School Ridin Clean
WineRed2.2CL's Avatar
what happened to the pics
Old 10-13-2008, 06:18 PM
7th Gear
weaponx5's Avatar
anyone have updated links with pics ? i'm mechanically challenged and need pics.
Old 10-23-2008, 09:53 AM
man this sounds good but also risky at the same time. I am not a big fan of putting things into my engine to clean it. aside from Lucas Fuel cleaner or Lucas Powersterring fluid.
Does anyone really suggest this as a must do?
Old 10-23-2008, 11:33 PM
xdaex's Avatar
yes its worth, it as long as you put in 1/3 throught the vaccum and follow the instructions, your car will feel a little better but expect to be taking off like a rocket either.
Old 10-24-2008, 07:45 PM
its going to make me take off like that no way!!!
Old 10-25-2008, 07:02 AM
Gregyz's Avatar
I am doing this today since I have nothing else to do but i have some questions...
1) Do I have to change my oil? If so whats the weight? 5-10w (97, 3.0)
2) Where/ how much is seafoam? Can I get it at like AutoZone or Pep boys?
3) Where/ how do I get into the crank case? (the pictures didnt work)
Thanks guys, sorry for being a noob.
Old 10-25-2008, 10:58 AM
(Mid-Atlantic)
You should be able to get seafoam at autozone of pep boys, I got mine at advanced auto. It's like $7 a can, and you need one canm You should def change your oil after running seafoam through it
Old 10-25-2008, 08:45 PM
'99 2.3 CL
iansanderson's Avatar
There is also something called "Honda Top-End Engine Cleaner" that you can get from your Honda or Acura dealer. It is essentially the same system as seafoam, except you do not put any in your fuel tank. Should cost around $6 to 8 bucks. The instructions tell you to feed it through the brake booster line slowly as well. I built a feeder from vinyl tubing and a lil valve in the middle from Home Depot. It allowed me to control the amount of cleaner that was being sucked in so I wouldn't keep stalling the engine. (the Honda instructions say to avoid stalling)
I used the Honda Cleaner and noticed an increase in fuel mileage and the car is a lil peppier, so I would highly recommend it. There was a ton of smoke at first, and the engine sounded horrible. Once the can was near empty, there had been definite improvement.
If you are concerned about Cat Converter damage or whatever, don't be. The cat is usually damaged by allowing unburned fuel to enter it, burn up and overheat/melt the cataylist over a long period of time.
Doing this once every so often will have no effect on your converter.
Old 01-13-2009, 05:24 PM
N00berator
MoSp33d's Avatar
Justins video doesnt pop up, does anyone have the exact procedures on how to do this...i need to seafoam the shit outta my car.
Old 01-22-2009, 02:23 PM
tman89544's Avatar
Is there anyway you can re-up these photos? They aren't working for me..
Old 02-16-2009, 11:16 AM
Dan3952's Avatar
I used the GM combustion chamber cleaner fed through the PCV line before last oil change and that created a lot of smoke. My blowby is so bad that I always get oil drawn into the intake manifold. Does the Seafoam or like products clean the air intake and all the sensors in there as well as the combustion chamber? Is it likely that these products are removing the oil that keep collecting in the manifold?
Old 03-25-2009, 08:20 PM
Skuuuurrrrrt!
GhettoNinja06's Avatar
There was some confusion on which tube to use so I thought I'd post up a pic since the main pics are down.
Old 05-02-2009, 02:05 PM
Josh99CL's Avatar
Does anyone have pics of what to suck it through on a 2.3?
Old 06-22-2009, 12:14 PM
HovaIsHigh
TopGunEV's Avatar
Wow.... All I gotta say is it looked like I killed Casper and everyone single 1 of his family members! My 97 is runing like a champ these days. Thanx for help.
Old 06-22-2009, 12:35 PM
(Mid-Atlantic)
Casper
Old 09-10-2009, 06:56 PM
Your Girlfriend is in my
RemieGino14's Avatar
Thinking about doing it to my car, but I know nothing of what to do (Aside the fact some info is up there) I wanna seafoam the car cause I'm getting crappy MPG (Don't know if thats what fixes it, but my car kills a full tank in less than 4 days.)
Only thing I'm most cautious about is having the check engine light come on. If it does, I'm screwed. LOL. Mind helping a noob out?
- RemieGino14 -
Old 09-10-2009, 11:05 PM
1998 CL 3.0
Polaris573's Avatar
- RemieGino14 -
What specifically do you not understand? We can't just throw information at you and hope that it's what you need.
As for the CEL coming on, just disconnect the positive battery cable as stated before or pull a few select fuses (read the noob guide).
Old 09-11-2009, 01:33 AM
Like where everything I'm suppose to put the stuff in and what not. Like...when you put everything in, is there a specific time I'm suppose to wait for the fluids to go through and seep in or just turn on the car and see that stuff come out and what not? Just kinda lost...sorry for sounding like a noob.
- RemieGino14 -
Old 09-11-2009, 10:49 AM
1998 CL 3.0
Polaris573's Avatar
Ghettoninja has a nice picture up a few posts of where you can put it. Warm your car up to operating temperature. Pour 1/3 of a can very slowly into a funnel and through the tube he circled because you don't want to stall it and some people worry about hydrolock. Once you're done pouring it through the vacuum system turn the car off, or pour enough in to stall it, I prefer just turning it off. As for waiting, some people say 5-10 minutes and others say 30 minutes. Your choice, just wait some time. Put another 1/3 of a can in a half full tank of gas while you're waiting. Go for a drive. WOT once or twice if you can.
The check engine light will come on so don't panic. I told you read the noob guide not because you're a noob but because it tells you which fuse to pull to clear it and I couldn't remember. So don't apologize.
You could disconnect the battery to reset the CEL since the ECU will probably be confused as hell from the seafoam anyway.
Old 09-15-2009, 12:23 AM
Shadoh's Avatar
Seafoamed my car today, messed up.
Put 1/3 into crankshaft, 1/3 into fuel tank at 1/4 tank, then 1/3 into the wrong vacuum hose >>
Hose i used it marked in red.... Car started and ran fine, when i noticed the car wasn't trying to die i knew i was putting it into the wrong hose but said F it ill keep doing it.
Bought more seafoam today... changing the oil tmrw.
Can someone show me where the hose is? Please
Old 09-15-2009, 11:40 PM
Shadoh's Avatar
Did some looking around, asking around to friends, and figured it out
Heres pictures of where to do it on a 1999 2.3cl hope it helps someone, didnt feel like running out and buying a hose so i rigged up my PCV to do the job.
Old 09-17-2009, 11:29 AM
5th Gear
napajcl22's Avatar
I should probably do one of these since my engine has very high milage...
Old 09-24-2009, 02:39 PM
Out of curiosity, how come you do have to do an oil change right after?
- RemieGino14 -
Old 09-24-2009, 02:42 PM
(Mid-Atlantic)
To clear out all the gunk and carbon that this stuff breaks up
Old 09-24-2009, 05:55 PM
Shadoh's Avatar
From my reading on it, since you're mixing 100% petrol with your oil... it thins out the oil, too long in there and you're running on watery wannabe oil :p
Old 09-25-2009, 01:55 AM
So I did with Nate (switchfootvz) Today. I guess it works...but not alot of White smoke came out. My guess was just that I had too much gas in the tank when we put the seafoam in the gas tank. Question in mind: is it bad to leave seafoam in the gas tank?
- RemieGino14 -
cycdaniel
12-17-2019 10:58 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
pistacio
09-26-2015 09:45 AM
IlliniAcura
09-19-2015 09:31 PM
TxRzrBk
09-17-2015 01:07 PM
Quick Reply: Seafoam Install
