Honda Accord ATF Help
Old 03-11-2007, 09:50 AM
Tennisjon2002's Avatar
I need to do a drain and fill on my 97 Accord LX Automatic. The owners manual says use Honda Premuim Formula ATF or you can use Dexron III as a temporary replacement. I was wondering if this would be a good fluid for the drain and fill and if it would be a compatable with the honda stuff. I picked some of it up at walmart yesterday.
http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
Old 03-11-2007, 12:09 PM
saiko_cl_duck's Avatar
of course it says use Honda ATF, they want more money. The stuff you picked up should work just fine.
Old 03-11-2007, 07:09 PM
SodaLuvr's Avatar
Well, it's going to shift quite a bit firmer as the fluid isn't of the Z1 type. Dexron-III(H) fluids have different frictional characteristics than Z1 type fluids. If you really insist on using Mobil 1 ATF (Walmart generic will work fine, save your money), go to Napa Auto Parts and pick-up Lubegard HFM Supplement. It comes in a black bottle. Add 1 oz/qt and it will be fine.
I just used Walmart branded Dexron-III(H) and Lubegard HFM supplement on a 01 CL-S and it worked just fine.
Old 03-12-2007, 07:23 AM
On the way!
fla-tls's Avatar
^^^ What he said.
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
csmeance
09-10-2018 09:15 AM
RobbDizzle
10-15-2015 11:16 AM
Dman00tl
2G TL Photograph Gallery
09-25-2015 10:34 AM
Quick Reply: Honda Accord ATF Help
