2005 Acura RSX Type S, hearing a sound...
I'm hearing a sound when I'm accelerating through gears. It kind of sounds like a high pitch grinding noise, or kind of like a chain that is loose. I'm not too sure what it is, or if it's something serious or expensive to fix. I hear it usually through second, third, and a little in forth gear.
Any suggestions? Thanks!
Phil
Phil
That type of attitude won't get you shit around here. The RSX side of Acurazine is dead, most don't come over here the only way this post will be seen is if people are browsing New Posts.
Hence why I said most have ventured over to CRSX. I was going to assist you with your post, but now, fugg it.
Received 7,772 Likes
Your post didn't help. I had a genuine question, and you found it more important to comment on the fact that I drive an RSX. So what? I'm asking if anyone knows what this sound might be, and no, your post did not help. There is no attitude, but there's no need to comment about something that has nothing to do with my question.
Think of Flipster23's reply as a free bump to keep your question at the top of the new posts. Because, like he pointed out, there aren't many of you RSX guys around anymore.
In fact, this reply will do the same thing. I'm not being helpful, but I'm being helpful.
Sort of helpful in a malicious manner. See?
Now, I'll fully expect a "no attitude" reply from you pointing out that I'm not helpful. Which I'm not; so that's true.
Welcome to AcraZeen.com
ps. a little bit of additional unhelp: where is the sound coming from? Front? Back? Side? (-to-side?) Does it change with clutch in/out? Additional info will help.
pps. sorry for not being more helpful. I'm sort of the runt around here.
Bye.
There might have been a *little bit* of attitude.
Bye.
Bye.
The sound seems like it's coming from under the car, in the middle, or a bit closer to the front. But, that could just be the sound reverberating down and out both sides while I drive.
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
