2013 ILX,synthetic oil or synthetic blend oil?
Old 01-25-2017, 10:00 PM
Juliasdad1990's Avatar
Old 01-27-2017, 06:33 AM
hondu's Avatar
Either will work just fine in your ILX. Just follow the MM.
Full synthetic oils are pretty cheap to find nowadays, so why not go full synthetic?
Pennzoil has a $2/quart rebate going right now on their full synthetic oils, so probably even cheaper than a blend.
justnspace (01-27-2017)
Old 01-27-2017, 06:39 AM
Received 16,260 Likes on 11,971 Posts
^I concur
Old 02-03-2017, 07:00 AM
edcygan's Avatar
In the maintenance guide Acura doesn't recommend synthetic oil! Just saying I'm new to the Acura family
Q: I use synthetic oil. Should I expect to get more miles before the Acura Maintenance Minder indicates that I need an oil change?
A: Acura does not recommend the use of synthetic oils in models that do not require them as your Acura was designed and engineered based on the oil recommended in your owner’s manual. The Acura Maintenance Minder calculates your vehicle’s needs based on the oil recommended by the Acura engineers that designed your engine. The use of synthetic oil will not extend the oil change interval.
edcygan's Avatar
Old 02-03-2017, 08:18 AM
Received 8,585 Likes on 6,631 Posts
don't matter.
Old 01-05-2019, 07:56 AM
acuraada's Avatar
My MB came with full synthetic off the factory. ICE is ICE, as others have pointed out, full syn is cheap, there's is no reason to go blend.
Great info on the oils specs but when was the last time you you saw your engine temp meter go up to 240 F? You would have b bigger problems before worrying about oil meltdown
Old 01-05-2019, 08:12 AM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Uhhh, you do know there are areas inside of engines which are WAY hotter than what the coolant temperature is inside your engine, right? Said another way, on a hot summer day with the A/C running while climbing a long steep grade, it wouldn't surprise me at all to see localized temperatures inside the engine of an ILX reach or exceed 240°F.
SoL_TeK
4G TL Photograph Gallery
49
05-01-2023 04:32 AM
theredia92
5G TLX Problems & Fixes
14
03-22-2021 07:32 PM
KaMLuNg
12-01-2016 11:48 AM
2Quik
11-14-2016 12:33 PM
Quick Reply: 2013 ILX,synthetic oil or synthetic blend oil?
