Supercharged 2010 TL-SH-AWD 6-speed
Old 05-21-2011, 07:24 AM
  #321
Pseudomaniac's Avatar
Originally Posted by HeartTLs
I don't want to come off as having a negative demeanor as I'm already crazy about the possibility of a SCer, but is there anyway we can safely up the power to more than 90 whp to better justify this?
Any of these S/C kits they've released in the past use an air/water exchanger to cool the air. Obviously, cycling 200 degree water through the pre-charge pipe isn't ideal, but it does help considerably over a direct feed.
Dropping a smaller (thicker), more effiecient radiator in place of the stock, you could probably find a way to put a a decent intercooler in the chin, and drop the intake temps 20-30 degrees cooler than a heated up air/water unit. This is normally a noticeable gain in power, and weight savings - but you're also going to have to do all the plumbing to get the air out of the blower and into the T/B. If they relocate the throttle body onto the blower or cooler housing with this kit - might not even be an option.
If you boost your otherwise un-upgraded car, here are some (experienced) expectations:
1. It will feel like a rocket in comparison.
2. You're going to beat the eyeballs out of it more frequently than you realize.
3. You're going to find the weakest link in your system, probably in less than 5,000 miles. If you're lucky, it's an axle or a C/V joint. If you're unlucky, it's the connecting rods, valvetrain, fuel system, or transmission/differential. On the 6 speed especially; if your clutch holds, you're going to break something launching it.
4. Comptech running gear is generally pretty top-notch. These Eaton blowers are pretty much maintenance free (change the oil every 100k in them or something). If it works like the rest of their J boost setups do - it does basically makes changing the spark plugs impossible and serpentine belt a complete PITA. I've always wondered why they didn't just go whipple style and build an integral upper intake manifold out of a blower instead of running a driveshaft across the top of the front cylinder head.
5. Tires. Buy stock in them.
6. Insurance. Better be in good standing with the DMV and circuit Judges; you might have your county's finest sending you there with enough frequency that they'll know your name.
That said; if it's your daily driver, and you're going to boost it; Spend your first $3000 on a late 90s civic so you have something to drive when you break things.
Pseudomaniac is offline
Old 05-21-2011, 07:36 AM
  #322
I feel the need...
Fibonacci's Avatar
Originally Posted by BoostLover
7) Audi dealers are wankers. Bye bye Audi.
Audi is teh new hotness. They have the thinnest dealer inventory on hand so they can afford to be wankers.
Fibonacci is offline
Old 05-31-2011, 08:34 AM
  #323
Tannis's Avatar
Excellent advice
Tannis is offline
Old 05-31-2011, 09:25 AM
  #324
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Good advice indeed!
Majofo is offline
Old 06-01-2011, 01:27 AM
  #325
7th Gear
3-2-1MUSIC's Avatar
Nice nice nice nice nice nice
3-2-1MUSIC is offline
Old 06-16-2011, 11:41 PM
  #326
I_m_TL's Avatar
How is everything going?? Seem like the post is dead!! Plz update how is the SC going
I_m_TL is offline
Old 07-17-2011, 03:37 AM
  #327
I_m_TL's Avatar
Does CT give up this project?? It been a month haven't update anything.
I_m_TL is offline
Old 07-17-2011, 12:13 PM
  #328
HeartTLs's Avatar
I spoke with rob a few weeks ago and he told me they're (CT), trying to put in a bigger blower in the very limited space available. And made no suggestion/hinted at the projected being scrapped or put on hold.
HeartTLs is offline
Old 07-19-2011, 12:10 PM
  #329
Oh Comptech....still barking up the wrong tree. Lop open the top of that motor and skip all the plumbing.
jnc2000 (07-19-2011)
Old 07-19-2011, 12:57 PM
  #330
HeartTLs's Avatar
Explain, not questioning you, I just want more info.
HeartTLs is offline
Old 07-19-2011, 12:59 PM
  #331
jnc2000's Avatar
Kinda like the Ridgeline's Blower mounted on the TL
jnc2000 is offline
Old 07-19-2011, 01:08 PM
  #332
HeartTLs's Avatar
You up to some sneaky stuff over there I see, who's TL is that? And what happened to your dyno results?!
HeartTLs is offline
Old 07-19-2011, 01:26 PM
  #333
jnc2000's Avatar
Couldn't make it down Monday -- We'll leave it at personal issues. (Don't worry I'll get back down ASAP) -- I have enough stuff I'm working on ATM.
The 12' WDP SH-AWD in the picture is Lynwood's.
Same unit you see here. It's the Twin Screw unit they've been working on for the Honda Ridgeline.
jnc2000 is offline
Old 07-19-2011, 02:14 PM
  #334
HeartTLs's Avatar
Try not to laugh, incase my questions are silly: if the blower is mounted on top of the engine doesn't that increase heat and ultimately decrease blower power? To SC it with this setup do you need a new hood?
HeartTLs is offline
Old 07-20-2011, 11:15 PM
  #335
You can build the upper and lower intake manifold around the blower, either cast or billet. The ridgeline setup is more strap it on and let it rip. A model specific roots intake manifold would be an easy installation, require much less tooling after the initial creation of the manifold, and would easily be good for a 40-50 whp increase on the 3.7. If there's enough clearance, you could even have it blow through an intercooler sandwiched between the outlet and the intake.
Old 07-20-2011, 11:27 PM
  #336
Don't get me wrong - as far as efficiency goes, it's less than ideal for sure; but given the layout of the engine and the bay, it would just work.
If there were anywhere with clearance in the serpentine path for a Rotrex unit, I could see that being ideal as well, but I just don't know where they would put it. The Rotrex powerband (like any supercharger, but even moreso) matches the linear power of a high revving variable VTEC engine very well.
On the other hand, the precat removal would give an easy to match flange for the hot side of a pair of 12g mitsubishi turbos with a special hot side for the pre-cat manifold, and then could run the cold side out through seperate small intercoolers or a central air/water exchanger and come up into the throttle body, with a 90" neck added to point it down.
400whp with no problem; and it would spool at like 2800.
Old 07-22-2011, 09:02 AM
  #337
HeartTLs's Avatar
Pseudo how much does that system cost? I'm curious not because I want it but because I'm having difficulties justifying CT 4G SC'er to gain 90whp for 5k+1k install, let alone for only 40-50whp.
HeartTLs is offline
Old 07-22-2011, 02:09 PM
  #338
maddogtheta's Avatar
Seeing as how you would need to have a custom build of the parts for the turbo setup, I'm betting it's going to be more than 6k. Not that it wouldn't be cool to have a twin turbo TL...
maddogtheta is offline
Old 07-22-2011, 02:55 PM
  #339
Oh - to do a twin turbo setup, you could buy a set of those PCDs (if they ever come out...AHEM..AHEM), lop them in half, and weld a turbo in the middle of them easily enough. Tap the oilpan and run lines to the turbos - easy enough. creative plumbing to the the air to the throttle body - would take a little time, but not mission impossible; espeically with the factory airbox removed and all that room for a side mount intercooler.
Tuning it to run on boost - and figuring out what your fuel delivery needs are; that's the bit$h of it....and where the pro's need to load up a non-dyno friendly AWD car on the rollers and watch the A/F, ignition timing, fuel pressue, and oil pressure while putting it under load.
Mitsu 12g / 15g / 16g turbos are a dime a dozen - the ball bearing ones will cost you some loot - but normal sleeve bearing units - maybe $300 a piece in stellar new condition. $200 intercooler - $60 in oil lines and taps - $200 in stainless steel plumbing and couplers. $1000 for proper fuel pump and new injectors / plugs / and a piggy back FMU. Probably $1500 in dyno/fab/tune work, plus the cost of the PCDS (hey are those out yet...cough cough)
This effectively kills anything resembling dependability on your vehicle as well. It would be fun though....
Old 07-22-2011, 03:00 PM
  #340
redskins804's Avatar
danggg.... that is pretty steep for some extra HP. Couldn't you just sell your TL and buy a slightly used Lexus IS-F which has 416 HP? I saw a used '09 for under $40K and it had 21K miles on it.... (of course I'ld never sell my TL!)
redskins804 is offline
Old 07-22-2011, 04:14 PM
  #341
HeartTLs's Avatar
I have a thing for acuras, in my price range its interior/exterior is my favorite; besides all the other niceties. Getting an IS-F, g37, etc doesnt fit my criteria besides that I plan on my TL eventually having more whp than a stock IS-F.
HeartTLs is offline
Old 07-22-2011, 04:22 PM
  #342
Majofo's Avatar
The challenge is not getting more power out of it than an IS-F.. Making it faster / quicker will be the chore. The IS-F stock is in the mid-12's.
*ahem*
Skip to 5:05
http://www.youtube.com/watch?v=eMahk...eature=related
Majofo is offline
Old 07-22-2011, 04:58 PM
  #343
HeartTLs's Avatar
I said more whp because he mentioned 416 on the lexus; whp is the means, speed is my goal, not big numbers.
HeartTLs is offline
Old 07-22-2011, 05:03 PM
  #344
Majofo's Avatar
The Lexus is 400+ at the crank.. at the rear its in the mid 3's. The turbo 3G guys are 400/500+ at the front.. from a roll.. they might win, from a dig... probably not. Not a big fan of roll races though.
Majofo is offline
Old 07-22-2011, 05:58 PM
  #345
hatepotholez's Avatar
lol damn that GTR is no joke.
hatepotholez is offline
Old 07-22-2011, 07:29 PM
  #346
JM2010 SH-AWD's Avatar
"That was not a win, that was a demolition." LOL. Did they really believe the Jag had any chance against the GTR? What a butt-kicking! Cool video.
JM2010 SH-AWD is offline
Old 07-22-2011, 09:32 PM
  #347
lji
lji's Avatar
this video keeps me wondering what acura could have done with the now scrapped nsx project although the car was rumored to be fitted with a V10 .... the tl's got almost the same engine size (3.7L) as the gtr (3.8L) and all wheel drive... all the ingredients are there...
lji is offline
Old 07-22-2011, 09:53 PM
  #348
They built the V10 car actually; prototypes ended up finding a home- it's been running Super GT in Japan the past couple years. It's quick - sounds wicked - but not dominating.
Old 07-22-2011, 10:47 PM
  #349
COTM Coordinator
MurkyRiversTL's Avatar
This Thread
MurkyRiversTL is offline
Acc-Rite (12-31-2013)
Old 07-23-2011, 01:35 AM
  #350
I_m_TL's Avatar
so we not going to see this kit come out on the market any sooner!!
I_m_TL is offline
Old 07-23-2011, 07:22 AM
  #351
CT kind of screwed the pooch with the 3G kit, and then has closed/re-opened/changed ownership since then. I'm surprised to see them working on anything new at this point - though not unhappy. Any of their products I've purchased have been top notch - but I'll not be shopping for a kit on the 3G, or the 4G till someones put 20k on one and hasn't nuked anything.
Old 07-23-2011, 08:26 AM
  #352
HeartTLs's Avatar
Rob told me they've put over 15k last time we spoke and that it's driven hard.
HeartTLs is offline
Old 07-24-2011, 05:37 PM
  #353
COTM Coordinator
So where is the public information from the vendor rather than word of mouth from people who have heard of others saying that it works. Its like the vendor fell off the face of the earth and the only reason this thread is still alive is us bumping it for info.
Old 07-24-2011, 06:54 PM
  #354
Comptech was always bad with P/R. That much hasn't change at least...lol.
Old 07-24-2011, 06:59 PM
  #355
HeartTLs's Avatar
Give rob a call, he currently has the CT SC'er on his TSX. He's just not active on the TL boards.
HeartTLs is offline
Old 07-25-2011, 08:13 AM
  #356
A TSX? Bah. Still not a good test of how torque vectoring AWD is going to do with the additional strain. I know the engine will handle it with proper fuel tuning; it's Honda axles and differentials (of which I snapped more than a few stock ones on a 320hp S2000) that I'm worried about.
Old 08-05-2011, 12:44 AM
  #357
I_m_TL's Avatar
I just wondering what happen with the first blower that they put on the car?? It looks like a fully setup witht he pic that rob post in this thread. Then looks like plan change try to put the blower on top?? which will no space left for the hood.....so confusing.
I_m_TL is offline
Old 08-29-2011, 05:36 PM
  #358
Former Sponsor
rob_acuraoflynnwood's Avatar
Sorry I have not been around much. We have been very busy this summer between car meets and track days. We put over 7k miles on the car this summer with no problems. It drives just like a stock TL. I have taken out several people from A'zine in the car and everyone seems to love it. We just sent the car back down to CT-E so we can do some new stuff to it. (I will let you know more as I know) We are trying now to get the car in the Honda booth at SEMA.
I can answer any questions that you guys have.
rob_acuraoflynnwood is offline
Old 08-29-2011, 08:44 PM
  #359
I have car ADD
BLACKURA_NY's Avatar
^ only question i have is...
Will the Ice-Box ever be released? ETA?... then i'll worry about the SC'er
BLACKURA_NY is offline
Old 08-31-2011, 09:18 AM
  #360
Former Sponsor
I spoke with Nate at CT-E yesterday. They are getting the last pre-production mold this week if all goes well they should be ready in 8 weeks
Quick Reply: Supercharged 2010 TL-SH-AWD 6-speed
