! VSA Light Always On
Old 07-11-2022, 03:46 PM
leakingpinion's Avatar
Bought used 2007 TL-S Manual with 130K miles, was driving great until the triangle ! + VSA light came on a couple weeks later and I believe traction control is off. Light always turns on AFTER driving, startup is blank before. Common issue with simple fix possibly? Any help is appreciated, thank you.
Old 07-11-2022, 07:13 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
You'll need to get the code read to see what the issue could be. It could be a wheel speed sensor, being low on brake fluid or something else. Code will point us in right direction.
Old 07-12-2022, 01:09 AM
My horn and it’s fuse went out so I’ll try to replace that and read the code again, I didn’t read any on the OBD2 at first. Will update soon.
rmjames007
1G TSX Problems & Fixes
04-07-2008 09:27 AM
Carlito
07-10-2006 09:24 AM
AsianRage
11-02-2004 08:08 AM
enderwiggins
08-10-2001 10:44 PM
Quick Reply: ! VSA Light Always On
