Power Steering Pump Replacement
Old 12-04-2011, 10:34 PM
djcobra316's Avatar
Hi guys i have a 2007 Acura TL that needs to get its power steering pump replaced. Has anyone here ever got this replaced and how much did it cost. My steering wheel is hard as hell which I cant even turn it when its parked. When my car is started up in the morning has loud whine noise and goes away after its warmed up, so please anyone who can help me with this would be a big help.
Old 12-04-2011, 11:12 PM
gwiffer's Avatar
Are you sure the rack hasn't failed also?
I think a failed rack can cause metallic bits to be pumped through pump, causing it to fail over time.
I would definitely examine some of the power steering fluid and do a complete flush before you replace any parts.
Old 12-05-2011, 12:42 AM
gatoferoz25's Avatar
My boy did that in his 07 base TL an bough it from a local junk yard for 125 included the pulley too so I did the rest
Old 12-05-2011, 05:32 PM
djcobra316's Avatar
I did check the power steering fluid and there is not bits of matallic bits in the fluid. gatoferoz25 if your close by we can set up a time to meet up i live in central jersey.
Old 12-05-2011, 05:35 PM
ArthurL's Avatar
The noise can be fixed by purchasing a brand new O-ring from the dealer.
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
Old 12-07-2011, 03:54 PM
My zip is 07047 get the part an we talk
Old 12-27-2011, 01:23 PM
Feenin on some 20's
ILLustriousUA6's Avatar
can anyone verify if this part can be bought at a Honda dealership??? My local Acura Dealership is about 30 mins. away.
Old 12-27-2011, 01:34 PM
Resident Dingo
TheDingo's Avatar
Yes, it can be bought at the dealer. Call them first to make sure they have it in stock before you go up there.
The dealer here (45 minutes from me) makes me pay for parts before they are ordered so I have to make the trip twice. Bastards.
ILLustriousUA6 (12-27-2011)
Old 12-27-2011, 02:19 PM
Mr. Detail
Scottwax's Avatar
My local Honda dealer had several in stock. Guess they order them right before it gets cold.
Old 12-27-2011, 04:50 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
https://acurazine.com/forums/showthread.php?t=754586
Usually.
Any of the seals going bad and letting air in could cause the issue. But the OP seems to have bigger issues than just the noise.
PS pump is easy to replace. There are Service Manual scans as noted below:
A-105: DIY: Power Steering Pump Rebuild
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/ - With Pics and Service Manual Scans
https://acurazine.com/forums/showthread.php?t=754586 - PS Whine Fix (O-Ring Replacement)
Old 12-30-2011, 04:59 PM
Fightin' Texas Aggie
AMIC's Avatar
Just had to have quite a bit of power steering work done. Had several leaks and the bad O-ring. Noise was terrible but never lost power steering.
TL-Rocket
04-29-2023 02:33 AM
02-25-2020 09:57 AM
spidermankb
03-05-2019 11:34 AM
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Power Steering Pump Replacement
