Clicking noise under steering wheel
Old 12-06-2014, 05:37 PM
kbb808tl's Avatar
So started my car today there was a loud clicking noise coming from under my dash on the driver side went away after 20 sec or so turned the car off an on again same thing anyone know what this could be
Old 12-06-2014, 06:27 PM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
Did the car start?
Sounds like under voltage going to the starter cut relay (driver's side kick panel) which results in the relay rapid cycling, hence the clicking sound. Probably a low/bad battery or loose/corroded connections, but could also be a bad ignition switch.
Old 12-06-2014, 10:26 PM
kbb808tl's Avatar
Car started drives everything even the ignition is strong
02-25-2020 09:57 AM
IIDXholic
09-19-2015 10:18 AM
PortlandRL
09-14-2015 12:01 PM
MyKids&Cars
09-02-2015 12:03 AM
Quick Reply: Clicking noise under steering wheel
