Battery Draining Insanely Quick
Old 12-07-2016, 06:01 PM
Csakstar's Avatar
Hey guys,
I've been having issues with my battery lately. Since I've gotten back to school, my battery has drained completely three times in the span of 2-3 days between uses. My old battery was able to be jumped once, but when we tried again we couldn't get it to start. We figured it was just the battery had finally given out (I've only had the car for about a year now, but it looked pretty old), so I bought a new one and popped it in. Good to go. Fast forward two or three weeks from that point, and it's dead again. So dead this time, that the security alarm goes off whenever you try to jump it. I'm thinking it's one of two things: either the HFL (hopefully this) or the alternator. Alternator doesn't really make sense since I've had no issues electrically while driving the car. Just wanted to see if someone could confirm my suspicions for me. Thanks!
Old 12-07-2016, 06:04 PM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Disconnect HFL, it's like the primary cause. Then see.
NBP04TL4ME (12-07-2016)
Old 12-07-2016, 06:40 PM
eastcoastguy's Avatar
^^^^^^ this!!!
Old 12-07-2016, 07:36 PM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
More common than not...........
Old 12-07-2016, 08:26 PM
Aargh-ura's Avatar
Been there.
Old 12-07-2016, 08:40 PM
Csakstar's Avatar
Thanks guys I will check that out tomorrow. Is there anyway to stop my alarm from going off while recharging the battery? Also, do you know how much it costs to replace the HFL?
Old 12-07-2016, 08:47 PM
Csakstar's Avatar
Also, is it possible to put a different Bluetooth module up there that would allow for Bluetooth audio as well as calling?
Old 12-07-2016, 10:44 PM
Duronn's Avatar
Still wouldn't hurt to check you alternator as well. How often do you drive your car, daily? Do you have to jump it multiple times in a day? How long do you usually drive for? Maybe your alternator is not putting enough charge back into your battery.
Old 12-07-2016, 11:09 PM
To replace the HFL costs a couple hundred, its listed on acura parts site, be aware there is a core charge that will be refunded when you send the old one back.
There is not an option to put another bluetooth module up there unless you install an aftermarket one.
Old 12-08-2016, 06:14 AM
Received 8,584 Likes on 6,630 Posts
You're not keeping your terminals attached when charging are you??
Old 12-08-2016, 10:04 AM
Csakstar's Avatar
That could be. I only drive about a mile or two a day while I'm on campus. I'll start with the HFL and I'll have my shop check out the alternator for me next time I'm there.
Old 12-08-2016, 10:06 AM
Csakstar's Avatar
Gotcha. I've found Bluetooth modules that cost less and do more than the stock one so I'll probably just remove the HFL and put in one of the aftermarket ones.
Csakstar's Avatar
I honestly feel stupid now. Thank you
Old 12-08-2016, 10:08 AM
We all gotta learn one way or another
Also aftermarket > HFL
Old 12-08-2016, 11:06 AM
Check out the USA Spec BT45-Hon3 module, people have have said good things about it, I believe that model would be for your car.
Old 12-08-2016, 03:37 PM
Csakstar's Avatar
That was the one I was going to go with. I originally went with a GROM Audio module but that failed twice so I don't recommend it.
