'08 TL hard shifting after changed the tranny fluid
Old 09-29-2016, 02:16 AM
geceler7's Avatar
Hi guys i changed tranny fluid 3x3 on my 08 TL first two fills with automatic castrol atf tranamission oil and then the last fill with ATFredline racing and today when I drive at 1st 2nd gear the car jerks when changing gears. Ps no tranny mount or leaking problem. If you guys have Any idea what could be that issue will be appriciated for any helps thanks
Old 09-29-2016, 05:24 AM
Received 8,584 Likes on 6,630 Posts
Stick with OEM ATF-DW1. Why did out out shitty Castrol oil in there..?
llllBULLSEYE (10-01-2016)
Old 09-29-2016, 06:19 AM
NetGnome's Avatar
I have 150k miles, out of 180k, miles on a redline racing/light racing/D4 ATF mix in my 08 TL.
I am impressed.
Some people have complained of Redline forming gel bodies in the bottle, which you can filter out, but I have never had a problem in the car..
Old 10-01-2016, 10:25 AM
llllBULLSEYE's Avatar
Solved
Old 10-10-2016, 09:05 AM
bmcnally's Avatar
My 05 Tl did the same thing. It wouldn't shift into certain gears... and rev up, and when i switched to manual the display wouldn't show up allowing me to see what gear i was in. Also, it got to the point where my drive wouldn't engage and i was left coasting down the road. Still have no clue what it is.
Flipster23
Norcal
262
05-04-2023 02:47 PM
EE4Life
12-20-2022 05:16 PM
EE4Life
03-12-2020 07:30 PM
EE4Life
03-12-2020 07:29 PM
EE4Life
03-12-2020 07:29 PM
Quick Reply: '08 TL hard shifting after changed the tranny fluid
