'08 TL hard shifting after changed the tranny fluid
Hi guys i changed tranny fluid 3x3 on my 08 TL first two fills with automatic castrol atf tranamission oil and then the last fill with ATFredline racing and today when I drive at 1st 2nd gear the car jerks when changing gears. Ps no tranny mount or leaking problem. If you guys have Any idea what could be that issue will be appriciated for any helps thanks
Stick with OEM ATF-DW1. Why did out out shitty Castrol oil in there..?
llllBULLSEYE (10-01-2016)
I have 150k miles, out of 180k, miles on a redline racing/light racing/D4 ATF mix in my 08 TL.
I am impressed.
Some people have complained of Redline forming gel bodies in the bottle, which you can filter out, but I have never had a problem in the car..
I am impressed.
My 05 Tl did the same thing. It wouldn't shift into certain gears... and rev up, and when i switched to manual the display wouldn't show up allowing me to see what gear i was in. Also, it got to the point where my drive wouldn't engage and i was left coasting down the road. Still have no clue what it is.
