Desert Mist TL Build
Old 05-31-2015, 05:28 PM
  #81
ct_ua6's Avatar
Nice update! I think the updated cluster style is much better than the 04-06s...
Old 05-31-2015, 06:56 PM
  #82
Jeff
Oh Sickest TL's Avatar
Originally Posted by DesertMistTL
Easy, 4 screws and it's out. But if you want the bezel with the rings you have to cut the MID buttons on the right out of the TL-S.
nice! if all my interior lights weren't blue id def hit this up. the type s cluster and the 07-08 cluster for that matter are 100 times better looking then the 04-06
Old 05-31-2015, 07:16 PM
  #83
DesertMistTL's Avatar
just get the 07-08 base cluster with the type-s bezel with the rings. the 07-8 cluster is blue
Old 05-31-2015, 07:28 PM
  #84
Jeff
^^ yea for sure. How much you think that mod would run?
Old 05-31-2015, 11:58 PM
  #85
EBay has clusters they usually go for 100, the bezel is 60 from Acura brand new but you don't have to get the bezel--only if you want the silver rings around the gauges
Old 06-01-2015, 05:10 PM
  #86
UA7X's Avatar
The mileage info is all saved in a separate computer/ in the PCM right? So swapping clusters doesn't require a trip to the dealer for mileage programming?
I probably wont ever do a type-s swap because I really like my 2008 cluster (I love the blue). I am just curious lol.
I love that you did both the cluster AND that separate display, it looks awesome!
Old 06-02-2015, 01:08 AM
  #87
unfortunately the mileage info is saved in the cluster. My stock cluster was at 135, this type-s cluster has 140. The oil life is saved separately so I assume the maintenance intervals is saved there as well.
If I were you I'd just pick up the TL-S outer bezel with the rings-- it's direct drop in!
Old 06-02-2015, 01:22 AM
  #88
ran into this car the other day. couldnt figure out why its color looked so off. it's not desert mist, but its not carbon bronze pearl
i'm thinking its a bad desert mist paint job?
Old 06-02-2015, 02:33 AM
  #89
UA7X's Avatar
I think that color is called Bold Beige Metallic, and was only offered on 2008 base models.
Personally I like the Desert Mist a lot better, though I'm not sure I've ever actually seen the bold beige in person lol.
Cool to see the two side by side like that!
Old 06-03-2015, 12:02 PM
  #90
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
I saw one BBM before an old guy left acura dealer for service he just can't keep staring at my MRP lol.
Old 06-03-2015, 06:08 PM
  #91
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Wow......still kinda cool.
Old 07-01-2015, 11:21 PM
  #92
well..i thought i was done with doing tl-s stuff but i found some TL-S headlights for a super cheap price and pulled the trigger. Just need to polish these babies, find 06-08 ballast and modify the socket on the tl-s corner light and good to go!
Old 07-01-2015, 11:42 PM
  #93
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
wow, it'll look full type-s!
looking forward to it being on the car
Old 07-11-2015, 09:37 PM
  #94
installed the TL-S Lights
04-05 use a bigger ballast that wont fit on the TL-S headlight, so I had to pick up (2) ballasts with the "W3T19371" part number. 06-08 use this slimmer ballast.
I used Silva95Teg's tip to convert my OEM parking light to fit inside the TL-S stripped out oem socket. Basically use the stock tl-s socket as a sleeve.
https://acurazine.com/forums/third-g...s-base-814655/
My DRLs arent wired, they just act as fogs like normal but I understand they melt the housing so I wont be using them as fogs but will make a DRL harness to run them at low wattage as usual.
silverTL6 (02-13-2020)
Old 07-12-2015, 01:07 AM
  #95
sockr1's Avatar
Received 1,158 Likes on 909 Posts
Car looks great!! How much was it to paint the each part of the lip kit if you don't mind me asking?
Old 07-12-2015, 01:19 AM
  #96
About 200, but if you paint all together I'm sure they can do $350
Old 07-12-2015, 05:30 PM
  #97
Redwood Original
RU_JELLY's Avatar
car is coming along awesome man! i personally like the color if the car is modded right. in stock form though not so much
Old 07-13-2015, 03:39 PM
  #98
truonghthe's Avatar
finish front end with the grill.
Old 07-13-2015, 08:20 PM
  #99
Styx17's Avatar
Picked up rear lip from Acura. Just dropped it off at paint shop. Such nice NHBP to be painted over.
I already have the mesh waiting
Where did you order the lip kit from?
Old 07-13-2015, 10:10 PM
  #100
i just goto my local acura dealership and the guy gives me a good deal on them. im sure if you goto any acura dealership you can get hooked up if you're nice about it. should run you about $280 or $320 full price no hook up.
Old 07-14-2015, 01:44 PM
  #101
Jeff
the full a spec kit for 320??
Old 07-14-2015, 02:54 PM
  #102
per part. It's cheaper to buy it all together from some of the vendors on here.
~780 shipped.
Old 07-15-2015, 02:20 PM
  #103
6th Gear
nightwing17's Avatar
good stuff man, TL is looking real clean keep up the work on it!! I thought about changing the cluster gauge but thought they only came in red for some weird reason lol and true every time i see this color way on the streets it's usually some old woman LOL. I've rarely seen the green lurking around too.
Old 07-15-2015, 02:28 PM
  #104
6th Gear
picked up a tl-s cluster and clock, real simple install
since i have an 05 with no tpms, the TPMS error shows up on the MID when i start the car, but i just click out of it. The notification icon was always lit and the airbag sensor light is on when I did this so I opened up the cluster and taped off the notification icon and the airbag icon. I can live with the TPMS warning as this looks sick!
everything works!
this is the only thing that shows when i start the car. other than that, nothing different form my old stock cluster!
was the cluster gauge a perfect fit when you switched it out?
Old 07-15-2015, 10:59 PM
  #105
the cluster gauge was a perfect fit BUT you have to open the clear bezel and apply tape on the low pressure warning and the airbag warning light . Easy.
nightwing17 (07-16-2015)
Old 07-16-2015, 01:37 AM
  #106
6th Gear
awesome man, thanks for tip. definitely looking forward to switching the cluster gauge.
Keep up the mods, she's turning into a beauty! looking forward to seeing some more!
Old 11-11-2015, 11:47 PM
  #107
just picked up some 18x8 ASPEC wheels
going to save a little more to get the michelin pilot sport as/3 in 245/40/18 that I already have on my stock 17s--that's going to be about $800
Old 11-13-2015, 06:24 PM
  #108
^^^ Looks good!
Old 01-02-2016, 01:11 PM
  #109
Finally threw on the aspec wheels with 245/40/18 michelin pilot sport a/s 3s
last thing is to lower it I suppose on H&R Race.
Old 01-02-2016, 03:57 PM
  #110
Looks good-I've got the H&R Sports Springs and really like them.
Old 01-02-2016, 09:19 PM
  #111
UA6MT
numairh's Avatar
H&R race springs will give you a very nice drop
DesertMistTL (01-03-2016)
Old 01-03-2016, 02:48 AM
  #112
^^^ Nice, are you guys on stock shocks?
Old 01-03-2016, 02:33 PM
  #113
UA6MT
numairh's Avatar
nice are you guys on stock shocks?
I'm on Tokico blues
Old 03-13-2016, 07:09 PM
  #114
installed some DEPO fog lights with Nokya Yellow Bulbs. I've been using nokyas on my cars since 2007, never an issue and last quite a while.
Old 03-14-2016, 02:20 PM
  #115
Ruben T
Ruben Tahsoh's Avatar
everything works!
It you don't mind me asking, how where you able to clear that airbag sensor light? Is it dangerous if it stays on? (I really don't mind the sensor light being on I just want to know if it is safe)
Old 03-14-2016, 04:27 PM
  #116
Reading other threads it's just the cluster that is getting incorrect signals from the SRS, but the SRS unit is working.
Taken from another thread
"For and 04-06 TL (UA6), Of course you will need to replace the SRS unit with an 07/08 (UA7) SRS unit and move 3 pins, and you will need to replace the OPDS brain in the passenger seat. The UA6 HELM ETM calls the ODS brain the ODS unit. But the UA7 HELM ETM calls the brain OPDS unit. The UA6 and UA7 HELM ETM call the OPDS sensors by the same name. The sensors in the seat talks to the OPDS/ODS, and the OPDS/ODS talks to the SRS unit. And the SRS unit talks to everything. Which is why there are many pins on the SRS unit. So LABEL every wire before you cut! Be prepared, and by some cable labels from FRY’s or somewhere. I uses silver duct tape and scotch tape. That wasn’t the best choice. Frys has real cable labels. (And you definitely need some kind of labeling system for any splicing that I mention below. But you may not have to splice if you get a nice quality passenger seat to replace the one you have. Read on below.)
Old 01-21-2017, 09:38 PM
  #117
havent posted in a while
s4play rear diffuser from is250
Attachment 100880
Carbon fiber wrapped TL-S cluster bezel
metal petals
Type-s Honecomb grill + blacked out center grill piece
New power steering seals and clean
Fixed my splash guard since i ripped it off when i forgot a clip'
Last shot of her chilling + bought 07-08 blinking side mirrors color matched OEM--was fun to wire... just ordered chrome hood and V grill trim. Also got honeycomb lower mesh im going to fit behind my asepcs
Old 01-23-2017, 07:43 PM
  #118
^^^ Everything looks good, especially the Carbon Fiber (naturally)......
Old 01-28-2017, 01:26 PM
  #119
UA7X's Avatar
Nice updates!
Did you have to cut-to-fit the Type S front grille? I thought I read here on AZ the Type S is taller and has to be trimmed down or a section in the middle has to be cut out? Assuming I remembered that correctly, would that mean the dark chrome hood and front grille trims are going to require cutting too?
Can't wait to see the next updates! I love the progress, your TL is a one of a kind!
Old 01-28-2017, 08:16 PM
  #120
Nice updates!
the type-s is taller but only the middle section which can be cut. I followed this guide.
https://acurazine.com/forums/third-g...-06-tl-817615/
I didnt end up epoxying any of it together. Kind of just attached it to the bumper and called it a day.
The hood piece will fit but the V-grille can't since it's taller then the 04-06.
I just got chrome hood and v-grille off ebay to try it out.
im also playing around with this f1 rear brake light. not sure if i like it, just mocked it up
Quick Reply: Desert Mist TL Build
