My '07 TLS M/T dyno test with bolt ons.
Old 11-23-2011, 06:53 PM
dstah's Avatar
What's up acurazine, went in for a dyno testing today because I was curious to see what numbers I would put down after a couple of mods...
Mods are :
rv6 pcd,rv6 v3 j pipe, cai, custom 2.5 piping, mdx manifold spacer.
Dyno was done on a dyno jet.. Not sure if these numbers are a bit low or not.
274.37 whp - 256.35 torque.
Old 11-23-2011, 08:05 PM
GivatiTL's Avatar
6MT or 5AT ?
Old 11-23-2011, 08:15 PM
KN_TL's Avatar
I would say m/t in the title means 6MT
Old 11-23-2011, 08:54 PM
dstah's Avatar
6 speed mt.. Tuner said I need more fuel or a stand alone ecu.
Old 11-23-2011, 09:06 PM
GivatiTL's Avatar
My bad KN_TL, whats the stock WHP on the TL-S ?
Old 11-23-2011, 09:07 PM
18psi
libert69's Avatar
why? whats the a/f look like?
Old 11-23-2011, 09:12 PM
Received 16,260 Likes on 11,971 Posts
I'm jelly, i should have started out with a type-s 6MT
mszczep1 (12-27-2011)
Old 11-23-2011, 09:41 PM
anx1300c's Avatar
No chart?
Old 11-23-2011, 09:43 PM
Originally Posted by anx1300c
No chart?
+1
where is the chart?
Old 11-23-2011, 10:01 PM
dstah's Avatar
A/f graph is on the bottom
Old 11-23-2011, 10:09 PM
Chapter Leader (San Antonio)
TheChamp531's Avatar
Uncorrected.
Old 11-23-2011, 10:10 PM
dstah's Avatar
http://i380.photobucket.com/albums/o...8/b2dfb86b.mp4
Old 11-24-2011, 10:22 AM
maxpsi's Avatar
Yeah, an extra 10% fuel up until 4.5k wouldn't hurt. As usual, smoothing out that Honda vtec crossover would give you a nice, linear powerband. You might even benefit from taking out some fuel after 6k. It's dipping down close to low 12s a/f there. Also, who knows what a timing and vtec crossover change would do. As you're tuner said, all of the above would only be possible with some tuning software.
Old 11-24-2011, 10:43 AM
KN_TL's Avatar
Get your order in with Rodney. If your tuner knows how to tune an MS3 then you'll be golden.
Old 11-24-2011, 11:48 AM
anx1300c's Avatar
Being that it's uncorrected and the run conditions are blurry in the pics, it's impossible to say whether it's making good/bad numbers. If I could read the conditions I could get an idea, but since you paid for the dyno run, I'd go back and ask if they'll correct it to SAE J1349.
Old 11-24-2011, 12:50 PM
dstah's Avatar
I will be saving up for the j&r ecu and hopefully get it soon.. Here's a better pic of the conditions .
Old 11-24-2011, 05:30 PM
P1zzaman's Avatar
+1
where is the chart?
Dont be jelly, grab the s/c and proper accessories and have it tuned. Then you will be whistling tunes while driving
Old 11-24-2011, 10:39 PM
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
looks good....i would say numbers do look a tad bit low...
You do not need more fuel....just an ECU/tune should do....
Old 11-25-2011, 10:43 AM
awoc's Avatar
Your A/F ratio looks messed up. First the car starts at 14.5:1 (super lean for oem ecu) then it goes to 13:1 (again lean). OEM ecu's like to run slightly over stoichiometry cause it helps the catalytic converts due their job more efficiently.
Old 11-25-2011, 12:56 PM
All motor
Sonnick's Avatar
He doesn't have cats anymore.
Old 11-25-2011, 02:19 PM
maxpsi's Avatar
Bottom line: the only way to find out what a/f ratio makes power is to be able to make fuel and timing adjustments on the dyno. Jethro may have made 271 whp @ 13.5 a/f @ WOT, but your TL might make the most power @ 13.2 a/f. You'll never know till you try, and you know till you tune on the dyno and physically see those changes as they are made.
Old 11-25-2011, 02:57 PM
dstah's Avatar
And to make fuel and timing adjustments I would need a stand alone ecu correct ?
Old 11-25-2011, 03:23 PM
J&r ecu!
Old 11-25-2011, 07:32 PM
swoosh's Avatar
You can make fuel adjustments using AEM FIC but for any timing adjustments you will need a standalone ECU (JnR)....
I think AEM can retard the timing but not advance em....JnR can do that...
Old 11-26-2011, 02:29 AM
anx1300c's Avatar
Looks like your numbers are pretty damn close to SAE, so you're making an honest ~25 whp over stock, which is pretty good. The inches of Mercury are a touch higher than SAE corrects to, but the 22-24% humidity cancels that out.
SAE:
Air Temperature: 77F
Absolute Pressure: 29.23 inches Hg
Relative Humidity: 0%
Relative Horsepower : 100%
Air Density: 1.157kg/m3
Relative Air Density: 94.4%
Density Altitude: 1952feet
Virtual Temperature: 77F
Vapor Pressure: 0 inches Hg
Dyno Correction Factor: 1
Old 11-26-2011, 10:43 AM
dstah's Avatar
SAE:
Thanks for the input.. I guess im saving up for the j&r ecu.. My next mod will be ur pulley and possibly ported manifolds.. Any other mods to help me reach my 300 whp ??
Old 11-26-2011, 09:34 PM
anx1300c's Avatar
Do the pulley, bored TB, manifold, runners, and the J&R stand alone. You should hit your goal.
Old 11-26-2011, 11:15 PM
awoc's Avatar
I have seen people make power with just a new fuel pressure regulator. It allows you to adjust fuel pressure and give the car more fuel without buying a new ecu setup. I say go for it. It's a cheap upgrade.
Old 11-27-2011, 10:10 AM
swoosh's Avatar
any links on the research and the install or the dyno's ?
Old 11-27-2011, 10:29 AM
awoc's Avatar
^ Just added a fuel pressure regulator http://honda-tech.com/showthread.php?t=2455377&page=7. There are more out there that I have seen, but I have to find them amongst other threads and sites.
It seems that the J-series run leaner from the factory. I wonder why?
Old 11-27-2011, 10:37 AM
swoosh's Avatar
^^^ emissions....fuel economy....i can go on LOL
thanks for the link...lemme read it up
Old 11-27-2011, 03:37 PM
dstah's Avatar
^ lmk if you find any diy installs on the fuel regulator. Any pros or cons doing this ?
Old 11-27-2011, 10:12 PM
swoosh's Avatar
^^^ nah bro...one dude who did a J series sway said his injectors were running at 100% and after the fuel regulator he was down to 70%....he could have just gone with bigger injectors
but either way I dont see any dyno proofs....gotta do some more reading and gotta ask IHC/Inaccurate about it since they have a lot more knowledge....
Old 11-29-2011, 07:37 PM
dstah's Avatar
Anyone know where to port manifolds and throttle body around Los Angeles area?
Old 12-15-2011, 10:33 PM
5th Gear
Dc5scorp's Avatar
That's not that bad
Old 12-16-2011, 11:44 PM
mY sLOW UA6's Avatar
Number are a tad low but still pretty good.
Old 12-21-2011, 04:23 PM
dstah's Avatar
Thanks all. I just installed heeltoes shifter package and I love how it feels now next is the j&r ecu !!
Old 12-21-2011, 04:29 PM
anx1300c's Avatar
LOL, and you're basing this opinion off what?
Old 02-23-2012, 07:02 PM
Dewalt09's Avatar
What is the whp for a stock '07 tl-s??
Old 02-23-2012, 08:30 PM
vp55's Avatar
^like 230 for the 5AT and 250 for 6MT.
The following 2 users liked this post by vp55:
Dewalt09 (02-23-2012), justnspace (02-23-2012)
Quick Reply: My '07 TLS M/T dyno test with bolt ons.
