A-113: Removal of Slave Cylinder check valve!!!
Old 08-26-2009, 06:46 PM
  #241
Green Machine
t0talacuratl's Avatar
Originally Posted by phee
forgot to mention i have a 1999 tl
243 at the wheels is pretty good for a 2g.
Old 08-26-2009, 07:12 PM
  #242
I got the Shifts
phee's Avatar
i think so too.
all i have are headers and an intake.
after pulley, exhaust, port and polished runners, and a tune. i should be somewhere nice
Old 08-26-2009, 07:19 PM
  #243
Green Machine
i think so too.
Nice! Too bad I can't get a too.
Old 08-29-2009, 11:19 AM
  #244
johnbot123's Avatar
im going to do this mod as well. i agree with opel. we should have a group mod weekend...but where? lol
Old 08-29-2009, 05:20 PM
  #245
Opel's Avatar
im in queens...i dont really care, as long as i dont have to drive half way across the country lol
Old 08-30-2009, 04:29 PM
  #246
9th Gear
Frankie Figs's Avatar
Originally Posted by Black_05_TL_6SP
Removing the Valve.
1. Remove unit from car or purchase replacement. Cost - $60-80 (If you are getting up there in mileage I would suggest purchasing a new one.)
2.Parts and tools needed - Mini hook set, DOT 3 fluid, Needle nose pliers, and something very thin to use to push the check valve out. I used a very small but long Allen wrench that I had.
3. Using the 90deg and the round hook I was able to remove the ring. I used the 90deg to hold the ring in place while I used the round hook to slide the ring from its locked position. The ring has a inward slope and an outward slope. Be careful not to let the ring shot off or do this some where you can find it easily.
Note - The ring removed
4. With the ring removed, I used the needle nose to remove the cap from the SC. It has to be worked out, so rock it a bit and it will come up and out.
Note- Ring and Cap
5. Removal of the check valve. I used a long Allen key that was very thin to fit into the hose feed side of the SC. As previously mentioned in another post, be careful not to hit the brass part of the fitting, it can damage it. This is why I used a very thin object.
6. With the check valve removed you can reassemble the SC. Start by putting the end cap back in and making sure it is fully seated back in the SC.
7. You will finally reinstall the ring. Install one side of it and use some needle nose to work the ring in. You may want to keep your finger over the ring so that if it slips it will not shot off.
I hope to get to install it on the car this weekend and will take pictures and write up the rest of the install.
I just did this to my 07 Civic Si and its amazing!!! Thanks to the OP for doing this mod and thanks to Black_05_TL_6SP for the more involved write up!!
Black_05_TL_6SP, I hope you dont mind, I posted your write up on www.8thcivic.com and I added some other things to it too. If you do mind, I'll remove it right away! Here's the link
http://www.8thcivic.com/forums/do-yo...er-damper.html
Old 08-30-2009, 04:40 PM
  #247
Opel's Avatar
^^^^i dont think he would mind , he seems like a nice fella
Old 08-30-2009, 04:42 PM
  #248
9th Gear
I hope so lol Im sure the Civic guys will like this mod!!
Old 08-30-2009, 04:44 PM
  #249
Opel's Avatar
i bet they will. so far it only had positive feedback
Old 08-30-2009, 04:45 PM
  #250
9th Gear
I only got to drive it about a mile but its awesome! My friend is bringing over his 05 TL later tonight so we can do it.
Old 08-31-2009, 08:26 AM
  #251
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
This mod is blowing up rapidly and turning our cars into the fun driving machines they were meant to be! Thanks again for turning us onto this Opel. Youdaman!
Old 08-31-2009, 09:52 AM
  #252
I got the Shifts
phee's Avatar
i this thread
Old 08-31-2009, 12:08 PM
  #253
devin1tl's Avatar
ok so i did this mod yesterday thinking it would keep my clutch from slipping at high rpm quick shifts, not that it always does it or anything but once in a while i can tell it slips. after driving it for a day i can honestly say ive noticed nothing, whats going on here guys i know i did it right it was so easy a caveman could do it.
Old 08-31-2009, 12:15 PM
  #254
9th Gear
Your clutch is probably worn out from slipping & now it just won't grip. My Si is doing great & drives normal now!!
Old 08-31-2009, 02:02 PM
  #255
Ryan Christopher
Black_05_TL_6SP's Avatar
Not a problem at all. Glad you are enjoying it the way it should have been!
Old 08-31-2009, 02:23 PM
  #256
I got the Shifts
phee's Avatar
if your clutch slips its because its already nearing the end of its service life. you cant reverse a slipping clutch. this mod helps prolong the life of the clutch, not resurrect it.
Old 08-31-2009, 05:01 PM
  #257
Opel's Avatar
Ok, just like I've said countless times, and I've explained the whole process of what happens from ur pedal to ur clutch disc...you cannot lose anything from doing this (removing the checkvalve) you can only gain..and if you don't, its due to a couple of reasons...
1-your clutch has been beat and abused beyond its tolerance. its very easy to glaze and heat spot the PP and FW, and once that happens, there's nothing u can do to fix it, (unless u change them out)
2-you didn't fully bleed your clutch
3-you're a beginner driving manual, (this is by no means to offend anyone, we were all beginners at one point)
Old 08-31-2009, 05:32 PM
  #258
Green Machine
Got over 100k on my clutch with no slippage at all. I do scrap the gears every now and again, because I get lazy some times. I guess that was one benefit for the check value. Other than that, lovin it!
Old 08-31-2009, 07:01 PM
  #259
devin1tl's Avatar
i really dont think improperly bleeding the clutch would have anything to do with it slipping at high rpm but hey what do i know. Opel, i know you have the Spec clutch but which stage and what kind of preasure plate, also i heard the spec clutches are just refurbished stockies with a higher performance surface, let me know whats up.
Old 08-31-2009, 07:57 PM
  #260
Opel's Avatar
dont bother with spec...im actually gonna call them and get on their fucking case...they promised me that the PP was modified and reenforced to a higher clamping force...my ass!!! so unless they've changed something...dont bother with them. i dont believe in a modified self adjusting PP...Hi-Per PP shouldn't be self adjust, not on our cars!
i got the stage 3+ which comes with a 6 puck unsprung ceramic dick and the PP... stock FW
yesterday i went to the track, i couldn't even run...slipping the whole way down the track...it was funny when id come around, ppl thought i wasn't catching traction lol....but eitehr way, pissed me the fuck off.
Old 08-31-2009, 10:31 PM
  #261
devin1tl's Avatar
so what are you looking at for a replacement, im not sure anyone else makes them for our cars. i've heard of some prototypes but nothing concrete.
Old 08-31-2009, 10:41 PM
  #262
One on the right for me
subinf's Avatar
got everything out of the slave cylinder and put back together. too dark now to reinstall, must wait until the morning.
Old 08-31-2009, 10:49 PM
  #263
Opel's Avatar
possibly ACT..they make them for v6 accords...same as our cars
Old 08-31-2009, 11:14 PM
  #264
Opel's Avatar
^^^^^^i meant Clutchmasters lol
Old 09-01-2009, 07:08 PM
  #265
johnbot123's Avatar
only one small, minor problem.....he lives in FL...and my clutch fluid might be alittle hot by the time i got there lol....i live in queens as well....do you have a shop or garage?
Old 09-01-2009, 07:46 PM
  #266
Opel's Avatar
What are you talking about? Lol
Old 09-01-2009, 11:33 PM
  #267
johnbot123's Avatar
scratch what i said.....im a lost cub scout with no flash light
Old 09-01-2009, 11:34 PM
  #268
subinf's Avatar
So I agree with everyone else, removing the valve is pretty awesome. Much better feel when pushing the car.
Old 09-03-2009, 01:20 PM
  #269
devin1tl's Avatar
thats what i was thinking but since the accord uses a different transmission wouldnt it use a different clutch as well?
Old 09-03-2009, 01:34 PM
  #270
Opel's Avatar
first i meant Clutchmasterts....2nd...03-06 accord...same crap as TL
Old 09-03-2009, 10:19 PM
  #271
PCM full of water, yummy
blokhead's Avatar
One of the best mods I've done. Thanks Opel, I've wondered where the stupid check valve was for a long time.
Everyone else, as far as getting the o-ring out... Get your wife/significant other to do it. I spent 10 minutes trying to get it out, got pissed, told the wife to get the dremel, and she actually brought it to me (surprisingly), she started bitching about cutting up her car again and asked what I was trying to do. I showed her and 30 seconds later she hands me the o-ring and says "is this what you wanted out?" I just hung my head in shame...
Clutch feels like it should. I don't need to turn off the VSA to drive smoothly now.
Old 09-03-2009, 10:21 PM
  #272
devin1tl's Avatar
so is that what your going to swap in?
Old 09-05-2009, 08:30 AM
  #273
Opel's Avatar
Clutchmaster stage 4.....hopefully soon lol
Old 09-08-2009, 08:34 PM
  #274
bb4_vtec's Avatar
i completed this mod 1 1/2 months ago.. this mod is worth every penny! but today when i was driving.. i shifted from 2nd to 3rd and pow! no clutch pressure. i pulled to the side and opened the hood. the cap is gone! the locking ring was in place correctly when i mounted the slave back in place initially. luckly i was just down the street from my house.. i hope this doesnt happen to anyone.. now i have to wait until tomorrow to get another slave cylinder from the dealer. and i will do this mod again..
Old 09-08-2009, 09:39 PM
  #275
I got the Shifts
phee's Avatar
i put jb weld on the end of the slave to keep it from popping open
Old 09-08-2009, 09:50 PM
  #276
blokhead's Avatar
I don't understand how this would happen. I don't think I would even need the locking ring.... when I put the cap back on, it was tighter than it was when my wife took it off. Are you sure it didn't get bent when you put it back on???
Old 09-09-2009, 12:06 AM
  #277
bb4_vtec's Avatar
i also set jb weld on the back of the cap and still no good.
Old 09-09-2009, 07:59 AM
  #278
Ryan Christopher
Did you grind down or cut the metal where the ring seats? I did the whole process without any cutting or grinding. Doing this degrades the integrity of the metal that is designed to hold the Hydraulic force that is generated by pushing the pedal. Most of the force is directed to the push rod, but some of this force is sent to the sealer cap and then to the ring. If the metal has been cut, it can allow for it to flex out releasing the ring thus allowing the cap to come out. I see more issue with cutting a grove into it as this will allow the metal to flex out.
For future installs, I would suggest everyone use a pick set (or something similar) to remove the ring without modifying the slave cylinder itself.
This is just my thoughts on this. I did the entire install without cutting into the SC. It took a bit more time (not really that much), but is well worth the piece of mind.
This is a great mod and I have been enjoying it every time I drive the car. I would love to see a 1/4 mile time from someone that has run in the past before the mod, and then again after the mod. I have a feeling this would shave 2-3 tenths of the time (.2-.3 sec). The delay in the shift is no longer there and you are putting full power to the ground as soon as you let the clutch out.
Old 09-09-2009, 04:59 PM
  #279
I tend to agree that it's better to do it without cutting the channel I did...but if you check the picture, the groove is so thin the ring isn't going to flex from it. If that was the case they would have to make the ring solid to avoid the ring itself from flexing and popping itself out.
Trust me...I tried patience, and even went and bought a new pick set, to no avail. If you can do it without...sweet...but I almost gave up on this mod because of that little ring.
Either way, I don't see why the thing would be pushing itself, or fluids out the back end. Maybe the person having trouble should just bite the bullet and buy a new one and start over! I even ended up hammering the hole inside the slave because I misunderstood being able to push the checkvalve out from the other side and I was able to just redrill the aluminum and even with that eff up I haven't had an issue since doing it.
Old 09-09-2009, 09:54 PM
  #280
bb4_vtec's Avatar
i cut a small portion to get access to the locking ring, and also put some jb weld on the end to ensure it would not pop out of place. but anyways i just got the new slave today and picked the locking ring out just fine.. been driving around for about 3 hours with no problems. one of the best cheapest mod's that i have done yet.. to the OP!
Quick Reply: A-113: Removal of Slave Cylinder check valve!!!
