DIY: Hidden windshield wipers
Old 09-16-2014, 10:10 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
Part Nos:
76620-T2F-A01 and 76630-T2F-A01
I finally got a chance to try the new 2013+ accord sedan wipers. They are the new design with the mount on the side instead of on top so the arm sits lower. Not to mention the whole wiper is pretty low profile.
Also, since the wiper arm sits lower, I was able to rotate the arm counterclockwise so it hides even more.
The end result is a wiper that is pretty much 100% hidden.
Results:
The following 14 users liked this post by paperboy42190:
blk 3g type s (11-22-2014), CaliBud916 (09-18-2014), corrado85 (09-21-2014), csmeance (04-13-2016), EL BAN (09-21-2014), EvilVirus (01-24-2017), guitarplayer16 (11-22-2014), Mondo375 (09-21-2014), Morrissey25 (10-02-2014), STL acura (11-23-2014), thoiboi (10-03-2014), THTL (09-22-2014), TLrascal (09-17-2014), Vlad_Type_S (02-13-2015) and 9 others liked this post. (Show less...)
Old 09-17-2014, 12:53 AM
rossv1's Avatar
Where's the DIY? lol
Old 09-17-2014, 01:17 AM
the DIY was when I told you to use the 2013+ accord sedan wipers and rotate the arms. Both steps are extremely easy, I dont see why you would need further clarification.
Old 09-17-2014, 02:09 AM
Previous Owner
Thorin78's Avatar
Is the drought in california causing this annoyance? You're pretty much never using the wipers anyways so they just sit there and taunt you as you drive? I know they taunt me whenever they squeak when I use them because I never use them down in San Diego.
I also don't understand what you mean by rotate the arms counterclockwise.
Old 09-17-2014, 02:47 AM
abracing's Avatar
part number + cost?
most newer cars have adapted this hidden wiper feature.
its not something most ppl notice at first glance but when someone tells you about it, you will start to notice it on more and more cars. For example, the 06-08 tsx got updated hidden wipers compared to the 04-05. makes the windshield look much cleaner. its one of those features that take awhile to appreciate, but once you do you will start to notice them on more cars.
I meant rotating them as in, remove the wiper arm cap, loosen the 17mm nut, pull the wiper arm a bit, and rotate it down 1 spline or so. its a similar concept to install a steering wheel, it must fit in certain grooves.
Old 09-17-2014, 02:50 AM
Originally Posted by abracing
part number + cost?
approx $20 each wiper. part number is really easy to find. quite frankly you wouldnt even really need it, you could just go into the dealership and they will know where the wipers are off the bat.
Or you can go on the 9th gen accord forums and get a pair of used ones for super cheap. Im sure there are ppl who get aftermarket wipers and have no use for the oem ones.
Old 09-17-2014, 05:08 AM
CoquiTSX's Avatar
Or you could try the Goodyear low profile that Costco sells for ~$5.00.
rawger (10-10-2014)
Old 09-17-2014, 09:28 AM
You could, but your wipers won't be hidden I have been looking for a long time to do this mod but wasn't sure which blades fit and now I finally found it.
I know this is not something that most ppl notice but I'm sure there's got to be someone else here that will appreciate this mod
Acura-OC (09-17-2014)
Old 09-17-2014, 11:06 AM
KJ TL-S's Avatar
I'll have to pay attention on the way home to see what they look like now. Then again, since I don't even know, maybe that's a sign I don't need to do this.
Old 09-17-2014, 11:22 AM
I know how you guys feel. At first I didnt really care either. Then I started to notice more and more cars with this feature. It makes the windshield look so clean. Once you are used to this mod, you will look at old cars that show the whole wiper and you will think its ugly.
Old 09-17-2014, 11:26 AM
2007 NBP TL Type S
Koreandude007's Avatar
I might have to give this a try soon.
Old 09-17-2014, 11:49 AM
The tsx guys do it too.
'04-'05 TSX Wiper Arm Upgrade - Page 2 - Acura TSX Forum
Before:
After:
The following 4 users liked this post by paperboy42190:
deematic (11-29-2014), KJ TL-S (09-17-2014), thoiboi (10-03-2014), TLrascal (09-17-2014)
Old 09-17-2014, 11:52 AM
Jackass's Avatar
Those are nice...especially for the price...but still not as good of a wiper as the Accord blades. I replaced the GY ones from Costco based on the previous threads on here about the Accord blades and am much happier overall. The GY blades tended to skip a bit on the lower part of the windshield.
Old 09-17-2014, 12:45 PM
blk 3g type s's Avatar
Wow very nice find!!
Old 09-17-2014, 01:12 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
damn definitely better!
Old 09-17-2014, 01:30 PM
TLrascal's Avatar
perfect timing, i need new wipers lol
Old 09-17-2014, 11:59 PM
Bruce Banner's Avatar
$20 is for both the wiper and the arm?
Old 09-18-2014, 12:36 AM
You don't need new arms, just the wiper. The arm wouldn't fit anyways.
Old 09-18-2014, 01:42 AM
CaliBud916's Avatar
That looks badass! So just the wiper blades from a 13+ accord? About to do this soon before rainy season starts
edit: does it matter what kind of accord, like v6, 2dr or sedan?
Old 09-18-2014, 07:32 PM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
How is the coverage, use, and noise of the new wipers once in action? We don't get much rain but it would be bad if these streaked, were streaky, or didn't have the coverage we needed
Old 09-18-2014, 11:40 PM
The 2013+ accords all have the same wiper, coupe or sedan, any trim.
The same coverage, they have the exact same specs (26"/19") as oem. It's a perfect match
I put a lot of research into finding the perfect wiper blades. I definitely wanted something OEM so wiper refills are cheap and accessible, has the exact same length as oem for maximum coverage, and low profile for a clean look. The 2013+ accord wipers are the answer.
CaliBud916 (09-21-2014)
Old 09-19-2014, 12:13 AM
sockr1's Avatar
Do they streak at all when you put on the wiper fluid and clean the windshield? I haven't found a pair yet that doesn't, including our oem ones
Old 09-19-2014, 01:17 AM
nope! These wipers are new though so they better not streak haha. 6 months down the road, who knows? But wipers are wearable items anyways so they should be replaced every year.
How was the condition of your wipers? The hot socal weather takes a beating on rubber parts so even if they are only a couple months old the rubber may start to degrade
Old 09-19-2014, 01:24 AM
sockr1's Avatar
they streak right out of the packaging haha. maybe my arms are the issue? i went oem, then tried some rain-x ones, then went back to oem. oem has been the best but i'm not satisfied. i usually replace them every year.
if you get a chance can you try to see if they streak? i may switch over
Old 09-19-2014, 04:10 AM
I tried them alrdy, I am perfectly satisfied with the wipe. I'll see if I can take a pic if you really need convincing lol
Old 09-19-2014, 07:07 AM
jdm_94-07TypeS's Avatar
http://www.ebay.com/itm/Genuine-OEM-Honda-Accord-Crosstour-Front-Windshield-Wiper-Blades-/110999277493?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d8128fb5&vxp=mtr
Old 09-19-2014, 09:18 AM
sockr1's Avatar
haha it's ok i believe you.
thanks!
and of course...it rained today on the way to work haha
Old 09-19-2014, 10:31 AM
JoshD_99EM1's Avatar
Coming from a guy that takes the wiper arms off his car for car shows for as long as I can remember, its def a big improvement. Wish I had seen this thread a little earlier though. I like having great blades on my car and just dropped the money on Bosch Icons. Bummer. Oh well. Next time
Old 09-19-2014, 10:38 AM
Crux's Avatar
When I first saw this thread the other day I just thought to myself you have crazy ADD...
Now.. all I do is stare at mine when I pull out of my garage... Damn you.
I just put new blades on, so maybe once they run their cycle I'll consider this.
Old 09-20-2014, 07:29 PM
crbnfbr's Avatar
Are the Honda blades the same 26" and 19" length that stock blades are?
Old 09-20-2014, 08:11 PM
But of course
Old 09-21-2014, 02:28 AM
Old 09-21-2014, 08:45 AM
Slayer-33's Avatar
Hahaha this mod is hot as hell.
Old 09-21-2014, 10:45 PM
mkster's Avatar
are these the correct ones ? 2013 Honda Accord 2 Door and 4 Door Wiper Blades (Set of 2)
Old 09-22-2014, 08:18 AM
-NoSuchThingAsTooLow-
StanCeD_J32's Avatar
i may do this - i'm in the market for new blades..winter is coming soon!
thanks for the "diy"
Old 09-22-2014, 09:32 AM
4th Gear
Boofer2fer's Avatar
noooooo!!!!
4th Gear
Boofer2fer's Avatar
My wipers are starting to streak - I think I'll give this a go soon. Thanks!
Old 09-22-2014, 11:33 AM
bp_spets's Avatar
I ordered these, I'll post up some pictures when I get them!
Old 09-22-2014, 10:09 PM
Post up before and after if you can
Quick Reply: DIY: Hidden windshield wipers
