Best oil for TL
Old 09-06-2011, 06:28 PM
Hondacrx2's Avatar
Best oil for TL
What's the best oil for a tl? Have a 08 with 18k. Synthetic is good but takes longer to thin out and protect. Were regular oil thins out and protects quicker. But once hot synthetic protects better. So whats the best to go with? I plan to keep this car for awhile so I want to use the best. I usually use mobile 1.
Old 09-06-2011, 06:31 PM
Big plans not enough $$$
NIGHTEHAWK's Avatar
Mobil 1 Full synthethic, I have used it on all my cars, and it is amazing.
Old 09-06-2011, 06:42 PM
Hondacrx2's Avatar
So no problems in winter? And no bad reviews using in the tl's?
Old 09-06-2011, 06:44 PM
boomersooner02000's Avatar
If u use the search function you'll find plenty of info for your question. Been discussed many times.
Old 09-06-2011, 06:46 PM
Received 16,260 Likes on 11,971 Posts
I know you're new here, but if you take a little time to browse our previous oil threads, you could pick up a lot!
Check out some of these threads, I dug up. Take note of what I hate cars says.
Originally Posted by I hate cars
Another oil thread with no real direction....
I get tired of explaining it so here's a chart. cSt is the viscosity. 100 degrees celsius is 210F and it's the oil temp that most engines run at so it's the "hot" viscosity of the oil.
Chart won't post so here's the link:http://www.upmpg.com/tech_articles/motoroil_viscosity/
This also shows that the myth that the winter rating (w) is done at 32F. The temperature changes with the rating, it's not one set temp.
The red chart shows the viscosity range for each SAE viscosity designation.
For Atlanta even in the winter, a 10w-30 would work fine. You can see by the chart that a 10w is good to -20C. Personally I would stay away from any extreme ends of this chart. If it's getting down to -15 I would be running a 0w or 5w, not a 10w even though it's acceptable.
0w-20, 5w-20, and 5w-30 will all be fine in the winter too.
Oil pressure and flow appear just as quickly with a 10w-30 as with a 0w-20 because our oil pumps are a positive displacement pump. The exception to this is if it goes into bypass.
A synthetic 5w-30 will give you the best of all worlds in the TL and you won't have the need to switch oil weights from season to season. If you're using dino I would use a 10w-30 in the summer.
A 0w-20 will compromise HTHS which compromises hot engine protection. It's fine if you live in a very cold area and the oil never hits full temp.
A 5w-30 synthetic will usually have a higher HTHS rating than a dino oil in the same weight. This is one area besides very cold climates where a synthetic accels. When dealing with dino oils it's better to keep the low and high numbers as close together as possible. If you use a 5w-40 dino, it's going to have a ton of VIIs and shear like crazy.
Originally Posted by I hate cars with a passion!
I ended up going with the Redline over Amsoil for several reasons. Amsoil was great, I can only say good things about it. However, I figured if I was going to go with a synthetic I might as well go with the best. Redline offers a higher HTHS, thinner cold starting viscosity, it's an ester so it has a natural cleaning ability which means a cleaner engine and less detergents are needed. It has the stoutest additive package I've ever seen, tons of moly and ZDDP. Great HTHS retention meaning you can take it to track days and run it hard all day long and never worry about having to change it out early. It's a straight 30wt but flows like a 5w-30 so you get all the advantges of both a multi-weight and straight weigh oil. It's overkill no doubt but I figured why do it half ass. Even the Amsoil was overkill but that's my OCD getting the best of me.
https://acurazine.com/forums/3g-tl-2004-2008-93/amsoil-vs-royal-purple-oil-filters-726719/
http://wwtl.acurazine.com/forums/sho...d.php?t=808158
I am running M1 0w-40.
Timothy Lee (07-18-2016)
NIGHTEHAWK's Avatar
I have had no problems in the winter, none yet.
Old 09-06-2011, 07:27 PM
Hondacrx2's Avatar
So from what I read royal purple is the best oil filter? And what for oil mobile 1 is good?
Old 09-06-2011, 07:30 PM
any oil will do.
jhumbo (09-14-2011)
Old 09-06-2011, 07:42 PM
Hondacrx2's Avatar
So just use royal purple filter and I'll be good with almost any oil? That seems to be the most recommended
i use M1 0w-40.
with the M1 filter.
Old 09-06-2011, 07:49 PM
ggesq's Avatar
Received 2,181 Likes on 1,210 Posts
dino.
jhumbo (09-14-2011)
Old 09-06-2011, 07:58 PM
anx1300c's Avatar
I don't where you got this misinformation, but it's false. All things being equal, the synthetic will protect better, right from the start. I'm currently running the Royal Purple filter and Redline 0W20, but will likely switch back to 5w20 next change. And FYI, the only true synthetic M1 is the extended performance version.
Old 09-06-2011, 08:00 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
dealer oil 5W-20 and OEM filter...no problems.
synthetic vs dino has already been debated...its really hard to mess up motor oil unless you have no idea what the application of the oil is for (ie the varying weights and what conditions they are ideally used for in an engine). go with the ideal for your application or by the manual. regular maintenance is what will keep the car happy. oh and BTW follow your MID and not that silly 3k mi oil change rule.
Old 09-06-2011, 08:05 PM
Fearless DIY Guy
DeathMetal's Avatar
Amsoil 0-W30
Old 09-06-2011, 08:13 PM
cinobyte's Avatar
Here is a link to a place that has more info about oil than you can imagine.
Old 09-06-2011, 08:31 PM
Pat04TL's Avatar
Follow IHC's advice and you'll be fine. If you don't know what "HTHS" means(like me before reading IHC's oil threads), that's a good place to start real research. With 117k miles, I use most any name brand "high mileage" oil (i.e. synthetic blend) on sale. If no sales, then I go with Advance Auto Parts oil (supposedly supplied by Havoline). 5W-20 winter, 5W-30 summer...
EDIT. Forgot to say. I use Purolator PureONE oil filters. FWIW, there's a $3 rebate right now on each one up to 4 filters. Advance Auto Parts or Amazon usually have the best prices.
Old 09-06-2011, 09:14 PM
RaviNJCLs's Avatar
I have been using dino oil 5W20.
Old 09-06-2011, 09:40 PM
Land of 10,000 lakes
nate_0022's Avatar
Redline 5w-30 and royal purple oil filter.
Old 09-06-2011, 10:16 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Amsoil/Mobil 1 with Fram filters and 15k intervals. Never a issue. first motor (pulled out to do type-s motor and 6 speed swap had over 220k on it. Never a issue, type-s motor now has over 250k with same intervals. No issues.
Old 09-06-2011, 10:46 PM
SpiderX1016's Avatar
Their really is no best. Just use your favorite brand. Dino, Blend or Synthetic.
jhumbo (09-14-2011)
Old 09-07-2011, 12:27 AM
Hondacrx2's Avatar
220k on a tl?! And it still ran ok and didn't smoke or knock? WOW I only thought my crx's could do that ha.
Old 09-07-2011, 07:04 AM
Registered Member
SouthernBoy's Avatar
All of the major oils out there are fine to use. It really boils down to whether or not you are going to go with synthetic or dino, and which viscosity you prefer. Use a quality oil and filter and some good common sense and you'll be fine.
jhumbo (09-14-2011)
Old 09-07-2011, 08:43 AM
demarco5's Avatar
Oil
Just wanted to add a little something...
About 75% of all engine wear can be attributed to initial start ups where the oil has not lubricated the necessary parts yet. So for those of you (especially with bikes) who like to gun it right on start up, have fun with the inevitable engine lock coming your way. Ever have sex with a completely dry girl... lol.
Anyways, I just run full synthetic due to the intervals mobil 1 5W-20 every 7500 miles, it probably lasts longer but for peace of mind I swap it.
So most high mileage cars 200k+ with normal oil changes have less overall wear (on average) than those who make many short trips when the car can not reach its normal operating temp. I am sure most of you know this I just wanted to burn some time at work before the next meeting!
Old 09-07-2011, 10:22 AM
sleeper22's Avatar
I use Kendall semi-synthetic from a local tire store. Its hard to beat for less than $20 an oil change. I am not hard on my car and change it approx every 5000 miles.
Old 09-07-2011, 11:44 AM
#1 Super Guy!
94eg!'s Avatar
If you driver conservatively and enjoy good mileage all the time, get Mobil-1 0w20. You will save money.
If your not that concerned with fuel economy, but still drive normal-to-conservative, get Mobil-1 5w20
If you want a little extra protection for more spirited driving, use Mobil-1 0w30 (I'm using it now and lost 1mpg over 5w20)
If you drive hard all the time, then Mobil-1 or Redline 5w30.
If you race, you should be doing oil-pressure & temp testing to determine what weight of oil works best for the conditions.
0w oils will help a lot more in the winter months as well as these oils flow better and start lubricating sooner at startup.
BTW: Autozone has that $10-off coupon for the 5qt jugs of M1 again. You can take it to Walmart and have the customer service manager do an "ad-match" on it (just ask at the service desk). That's how you get 5qts of M1 for $14. Lots of the super walmarts are carrying the 0w20 & 0w30 in the 5qt jugs now...
http://www.autozone.com/autozone/lan...0829_sz_slot_2
The following 2 users liked this post by 94eg!:
borrowman (09-14-2011), Florida Wen (10-21-2023)
Old 09-07-2011, 01:32 PM
NSXCessive's Avatar
Running Amsoil 0W-20 synthetic + OEM Honda filter. Running ~10k (kms) intervals on my '05 Supercharged TL for 1 season. No issues to report at all so far.
http://www.amsoil.com/articlespr/2007/pr_asm.aspx
Old 09-07-2011, 03:41 PM
sourial84's Avatar
I use Castrol full synthetic 5-30 on all my cars and have a 99 civic with 270k with no problems (knock on wood) all orginal, I think if you stay on top maintenance and dont be to cheap you will be in good shape
mau108's Avatar
There is no "best oil". You will be fine with any oil that meets the requirements set forth in your owners manual.
My personal preference is Pennzoil, I use their oil in all 3 of my cars and haven't had any issues. The RDX which we've owned since new and now with 81K is spotless under the valve cover. The TL I bought used with 60K (kms) has a bit of varnish under the hood but it's not bad. I think the TL is extending the oil change interval out a lot further then the RDX is.
Hopefully overtime the Pennzoil Platinum cleans up the TL as well. Oh and the 96 Accord it surprisingly very very clean for the mileage and also it's on regular Pennzoil oil vs Synthetic.
Old 09-07-2011, 05:07 PM
MattB07TL's Avatar
I went with Royal Purple last oil change but think I'm going to switch to Amsoil next change, Always OEM filter
Old 09-07-2011, 06:57 PM
eduthesamurai's Avatar
Yep mobil 1 synthetic
Old 09-07-2011, 08:44 PM
Chapter Leader (Mid-Atlantic Region)
TWiSDiT's Avatar
+1 ive been running RP for 3-4 years now with no problems. I Just got me a gallon of AMSOIL 5w20 to see if its any "better". I also always used OEM filter. I will be doing it this weekend if weather holds up. Coupled with the Redline D4 3x3 change i did 3 weeks ago, my car should feel like the 1st day i got her
Old 09-07-2011, 09:27 PM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
BITOG has some very ignorant members that spout off misguided opinions as fact. Be very careful what you read over there. Edit: I just read a couple of the articles on the main page and it's just sad the direction that site has gone. There's a lot of misinformation in just the 3 pages I read.
Agreed.
It's not so much the dry start, it's the warm up cycle. When cold you have more piston to cylinder clearance and some of the ep oil additives are not active until the oil hits a minimum temp. It's more the fact that all clearances are loose than anything else.
I use Redline since it's an ester and very polar to eliminate dry starts even though an actual dry start is pretty much impossible. Oil sticks to cylinders and pistons, cam lobes usually are bathed in a little bucket of oil so lube is instant. Rod and main bearings have oil left in them and do not require instant pressure to get that hydrodynamic wedge to keep things separate. Oil pumps are positive displacement pumps so pressure and flow are instant.
You're literally talking miliseconds before you have full lube even on the first start in the morning. Many people have this idea that it takes seconds, even minutes to get lube but in reality it's under 1 second even in the winter with a thick oil.
Mobil One is not "full synthetic" it's a grpIII dino oil.
Again, flow and pressure are pretty much instant as long as you use the correct oil for the ambient temp and there's a ton of room for error. A 0w drastically lowers HTHS and hot protection. I would run Redline 5w-20 over Mobil One 0w-30 any day if I wanted the best protection plus they're about the same viscosity down to freezing. There's way too much emphasis put on cold flow. Think about the old days with grpI dino oils that were super thick during startup with carbureted engines that would usually bring the rpms way up immediately. The multi weights of today, even the thicker ones are far, far superior to the old oils and engine clearances have not changed over the years.
I would not use a 0w oil unless I was running the car in well below 0F temps. It's completely unnecessary for 90% of the US.
A change in fuel economy from a 0w-20 to a 5w-20 is not measurable. The people that have gone from a 5w-20 to a 0w-40 haven't seen a change in mpg. It would take going from a 0w-20 to a straight 60wt to even think about seeing a measurable difference.
A friend of mine just put a straight 60wt in his 350z (long story) and no measurable change in mpg. I don't recommend this but it goes to show that you will never ever see a change between a 0w-20 and 5w-20. They're the same viscosity at operating temp anyway.
Let's not forget, a 10w-40 is good to 0F. 10w-30 is easily good to 0F.
To the OP, a synthetic will not thicken as much when cold, won't thin as much when hot. This is what you want and it does it all with less VIIs.
Old 09-07-2011, 09:28 PM
I wouldn't limit yourself to the OEM filter. Very average at best.
Old 09-07-2011, 09:40 PM
Gonzilla's Avatar
5w30 synthetic mobile 1 my moms integra gs going almost 20 years strong!
Old 09-08-2011, 12:33 AM
#1 Super Guy!
94eg!'s Avatar
I'm surprised people still buy these Honda filters. OEM A02 filter is actually the bottom of the barrel filter. It's a cheap Fram (Honeywell) painted blue, with a silicon anti-drain-back valve. If you want OEM, then spend extra for the S2000 filter.
Discontinued Honda A01 (original small can filter) vs Fram cheapo:
Current Honda A02 (same as Fram above):
Old 09-08-2011, 12:39 AM
Hondacrx2's Avatar
So mobile 1 full synthetic really isn't? Cant I just run 5w30 all year round and be ok I am on Pa so it gets hot and cold. But I don't beat my car either.
Agreed.
Old 09-08-2011, 01:26 AM
Hondacrx2's Avatar
I basically just want what's best for the car. I am deff running a royal purple filter. Just got to pick a oil and weight. Redline seems very liked on this site. I just don't know any one who used it.
Old 09-08-2011, 01:28 AM
Hondacrx2's Avatar
P.s. You can laugh at this or say it's a waste of money buy I change my oil and filter every 3k no matter what. Yes even if its a royal filter for 16$ I will change every 3k.
Old 09-08-2011, 01:49 AM
I'd use Pennzoil Dino + Purolator PureONE filter if your gonna go 3k but that's just me.
Old 09-08-2011, 07:40 AM
GoldenShoes's Avatar
I live in PA too, and run Mobil 1 5W-30 EP with a K&N filter. works fine for me.
Quick Reply: Best oil for TL
