Advice regarding replacement of rear calipers
Old 06-29-2015, 08:37 AM
EddieOnAZ's Avatar
Hi so as the title says, both my rear calipers need to be replaced. They are sticking and ate through brand new pads in under a year
Now my question is: My Haynes manual tells me to always change both at the same time, never only one. Would it be safe to rebuild the left one and replace the right one? I'm asking because the right one is completely screwed, the bleeder bolt is seized real good and the caliper is just in really poor shape. The left one doesnt look so bad. I bled it a couple months ago with no issue and it looks better. So what's your take on this, can I just rebuild the left one and replace the right one?
Old 06-29-2015, 08:39 AM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Sure thing. As long as its rebuilt properly it should operate as new.
Don't forget to check your rotors too if your pads went out in under a year. Too deep of a groove or too thin and it's no bueno.
EddieOnAZ (06-30-2015)
Old 06-29-2015, 11:12 AM
EddieOnAZ's Avatar
The discs look OK. I might change them though because they're shitty painted rotors and they already look bad after just 1 year.
Old 06-29-2015, 03:26 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
rebuilt one side and replace the other side that looks bad.
Old 06-29-2015, 03:40 PM
Turbonut's Avatar
If you know how to rebuild the caliber, clean up the bore, install new seal and boot, you'd be good to go, then just install the rebuilt caliper on the other side. Also, give the rubber hoses a good inspection.
Old 06-29-2015, 08:46 PM
EddieOnAZ's Avatar
Read a couple diy threads from people doing it on bmws Toyotas and Hondas. Couldn't find anything on our cars but I'm guessing if those 3 looked very similar then the 3g TL can't be too weird right? I mean it looks like the worst part is getting the piston back in place once everything is cleaned up which doesn't require specific tools.
I don't have a fluid leak as far as I know but I'll check the lines for sure.
Old 06-29-2015, 09:31 PM
truonghthe's Avatar
inside your piston there are two boot,one like the o-ring that is your seal and flex back once the pedal being release. The big one is dust boot, they are tricky to put back together, it took me 30 mins for the first side complete rebuilt and 5 mins for the other side.
Old 06-30-2015, 06:45 AM
Turbonut's Avatar
Check hoses to be certain they aren't collapsed/clogged. The lines have a tendency to have buildup where the metal braces reside and the result is a hose that is completely restricted.
Use fine crocus cloth to clean up the bore.
Old 06-30-2015, 06:52 AM
EddieOnAZ's Avatar
Thanks for the advice guys! I might take the time to take pictures and write a diy for it since there doesn't seem to be on for our cars anywhere.
mada51589
05-03-2022 08:54 PM
cobra10363
01-16-2021 08:12 PM
wilztlxs
12-01-2015 09:16 AM
Ny1718
09-11-2015 09:21 AM
brjones9
09-03-2015 07:30 PM
Quick Reply: Advice regarding replacement of rear calipers
