aftermarket door speaker recommendations
Old 03-06-2014, 06:16 PM
skathe's Avatar
soo ive got everything as aftermarket audio including headunit in my car now.
Been running JL audio c3-650s in the front and rear but now that everything is aftermarket and clearly getting a clean signal the JL's seem pretty harsh at high volumes on the tweets and mids just generally lacking.
THought about getting some dynaudios like neibur is running but am not on a high enough budget for those speakers (budget being 400-500 per pair)
i wanted to hear from everyone else what they would suggest that wouldnt require to re-axis the tweets and just be a plug and play option. my 4 channel amp is jl audio 300/4v2
WHat do you guys recommend?
Old 03-06-2014, 09:01 PM
niebur3's Avatar
You may want to look into the Image Dynamics XS-65 set. I am a dealer if you need pricing. Should be well within your budget and they sound really good. You should look them up.
skathe (03-14-2014)
Old 03-14-2014, 10:13 AM
skathe's Avatar
just ordered a pair of the Image Dynamics from Neibur, thanks man!
Old 03-14-2014, 11:56 PM
vivianmarie's Avatar
I highly recommend installing a DSP also.
skathe (03-17-2014)
Old 03-15-2014, 07:28 PM
808CU2's Avatar
Yes..!! Niebur3 agree with you on ID speakers. Very nice sounding, and the subs are also very good highly recommend the IDMAX if your looking into getting a sub.!
Old 03-17-2014, 03:15 PM
skathe's Avatar
my HU has auto eq capabilities and an 8 band EQ already. its aftermarket not factory.
Old 03-20-2014, 12:19 AM
skathe's Avatar
they sound sooooooo much better. thanks niebur, one question though. there is a problem with one of the crossovers, just gotta get it replaced and should be good to go. some reason tweeter doesnt work on one of the xovers.
Old 03-20-2014, 07:43 AM
niebur3's Avatar
Did you make sure all the jumpers inside are the same between both crossovers? These crossovers have tons of options and little jumpers that make those options possible. Text/email me and let me know. If you need a replacement, we can get that out to you right away! Glad you like!
Old 03-20-2014, 07:58 AM
soupi's Avatar
what are the specs for all of the stock speakers?
I plan on changing my door speakers in due time!
Old 03-20-2014, 10:27 AM
skathe's Avatar
for the base non tech all four of mine were 6.5s and the tweets are .75 i believe
niebur i just emailed you
02-25-2020 09:57 AM
akbears15
15
11-05-2015 07:06 AM
Pegon95
09-15-2015 01:54 PM
christopher1
3G MDX (2014-2020)
09-10-2015 06:43 PM
trinikidcl
09-04-2015 12:56 AM
Quick Reply: aftermarket door speaker recommendations
