wheel bearing
Old 02-25-2011, 01:55 PM
APROBLEM4's Avatar
wheel bearing
2002 acura tl type s 55 thousand miles...been hearing a humm from the wheels when i reach around 40 mph. Sounds like a 4x4. Took it to the shop they said it's my front passenger side wheel bearing. The mechanic said he recommends that I change both front bearings. Any advice.. Also should I be preparing myself for anything else to go wrong because of the wheel bearing problem. One more thing he's charging me 250 for parts and labor.. what you think
Old 02-25-2011, 02:03 PM
kidduce's Avatar
I think thats not a bad price, considering the bearings are pressed and you can damage other components if you dont know what your doing.
Old 02-25-2011, 07:27 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
I wouldnt worry about the other side till you get rid of the existing noise
while its good to replace things in pairs, its not always needed~
pretty low miles for that failure so Im guessing bad roads speeded it up
Old 02-25-2011, 07:57 PM
B A N N E D
friesm2000's Avatar
or curb hitting....
but yes quite early for a bearing failure, so yes i would worry about getting the noise gone first, then doing both sides
Old 02-25-2011, 10:06 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
id just do the one thats bad.
Old 03-02-2011, 06:16 PM
acuratech1's Avatar
i would only replace the ones that needed at this point....but i would def replace the other one....also that price is great for both parts and labor...hopefully the mechanic who looked at it is right becuase sound travels it could sound like a front and be a rear..sound like left but could be right ya know.....but replacing the one for now wont be a problem
Old 03-02-2011, 06:20 PM
kidduce's Avatar
Does anyone have any DIY on replacing the rear left bearing? I am getting some noise there.
Is it harder/easier than the front?
Old 03-02-2011, 06:57 PM
acuratech1's Avatar
the rear is simple....take the rear caliper and bracket off...take the rear rotor off....take off the hub nut....slide out(you might have to beat it a little) lol
Old 03-02-2011, 07:01 PM
kidduce's Avatar
Gotcha, ill have to tackle it one day. Just curious if its pain. I did the fronts so I should be ok.
Old 03-02-2011, 08:18 PM
B A N N E D
friesm2000's Avatar
a spindle nut actually iirc (does not spin with the hub, but stays stationary)
Old 03-22-2011, 11:30 PM
kidduce's Avatar
So im really thinking of doing my rear bearing since its making some weird noise humming, and some vibration when im slowing down, more so with more passangers.
So the bearing is in the hub, is it more feasable to replace the whole hub or try to pop the bearing out and replace that?
Old 03-23-2011, 09:43 AM
fsttyms1's Avatar
The rear is much different from the front. The rear it slides on the spindle. I have a mini DIY if you search for it (dont know if i added it to the DIY) It shows pictures. Its very easy to do on the rear.
Old 03-23-2011, 11:35 AM
kidduce's Avatar
Ill look for it. Thanks for the help. I guess im just trying to get a image in my head of the processes. Ill just take the wheel and take a peak.
KB1_EJ6
11-13-2016 09:51 PM
2012wagon
09-29-2015 04:21 PM
real_mckoy
4G TL Problems & Fixes
09-25-2015 10:49 PM
heyitsvic
09-04-2015 09:38 AM
Quick Reply: wheel bearing
