Hood support rod location for servicing.
I guess you guys know about this, just a reminder, just took pictures. Now the rod will be out of my way when I change the spark plugs.
Only the elite ones
Curious, has anyone tried to install gas struts/dampeners on the 2013-2015? Is it doable? If so, anyone have a link to a spot to purchase? What about a DIY thread to follow? I might be down to do this if it's cheap.
I wouldn't worry about it having a rod for the hood if that was the only issue. Toyota and Nissan have used twin cams and timing chains in their 6 cylinders for more than 25 years but honda still uses a single overhead cam and a timing belt to this very day. I wouldn't get too upset about a rod for the hood even if many cars have not had for a long time.
I'm fairly certain that the base 14k Kia rio has gas struts as well. I really don't get it. I mean on the flip side with the RDX you are very unlikely to have to open the hood haha. Any idea if the ILX or TLX or MDX use a prop rod?
Yeah I did find it odd it was also SOHC. I've been out of the car game for a long time and back in the days I remembered that people made a big deal about DOHC. Honda obviously has made plenty of DOHC engines in the past so why the stop on these later models? TBH, I've read so many good things about this engine I didn't really think too much about it. If I'm not mistaken, the idea behind a DOHC was to have more valves per cylinder.. but this engine does have 24 valves which isn't bad right? Oh and the timing chain thing.. that's pretty lame. My old 2005 Mazda 6 used a timing chain. So I take it the RDX uses a belt right?
All Honda V6 engines are SOHC and all Honda 4 cylinder engines are DOHC. All Honda V6's use a belt and all Honda 4 cylinder engines use a chain. The SOHC does have certain limitations and I feel that Honda has pushed it to it's max at this point. They really can't push anymore ponies or torque through it at this point and efficiency has hit it's max too. So they need to make the jump to DOHC. There are wid rumours of a twin turbo 3.0 Honda engine with 400hp but I call bologna because SOHC doesn't play well with turbos especially not twin turbos.
saving tech that they could.
One thing about a good old mechanical hood prop rod....you'll never have to replace it.
I'll be cursing when my pneumatic hood struts no longer keep my hood open.
Nothing like simplicity.
I've had my Audi A4 for 11 years, car itself is 16 years old total now, and the gas struts still work fine. They are showing their age finally, but I'd be fine with replacing them maybe once in the life of the vehicle for the convenience of not having to worry about propping the hood up. There are many things that are missing from this supposedly "luxury" SUV that come in economy cars of the same era and most of them wouldn't have really done much to change the price of the vehicle either.
