Random misfire code and all 6 cylider misfire.~ cleaned exhaust manifold~ not fixed
Old 11-01-2016, 06:46 AM
Jason Deglman's Avatar
The title says it all.... Getting random and individuail misfire codes... Cleaned exhaust manifold and problem still persists... Any insite would b great.... Thanks for advice on my last thread...D4 works perfect but D5 not so much
Old 11-02-2016, 02:15 PM
5th Gear
readerp's Avatar
If EGR passages and clean and EGR valve is good as well as spark plugs/coils, I would look at valve adjustment if you are much over 100k miles.
I had the same issue on my CL and Pilot, valve adjustment fixed them both.
Old 11-02-2016, 04:47 PM
teh CL's Avatar
Clogged cat is usually a good start..
Old 11-03-2016, 10:02 AM
3.5 psi
gnuts's Avatar
does the car run rough? If so, leave the engine running and start unplugging coils one at a time. The one that makes the engine run smooth when disconnected is a bad coil.
Old 11-07-2016, 11:55 AM
joejsn's Avatar
Replace all 6 spark coils.
Old 11-09-2016, 11:44 AM
Eurotrash
Tosh's Avatar
Originally Posted by joejsn
replace all 6 spark coils.
+1
Old 11-09-2016, 01:12 PM
5th Gear
readerp's Avatar
Unlikely all six coils are bad.
Gnuts advice to try one coil at a time should show you if any coils are bad.
If you can do the work yourself, adjusting the valves is almost free, and is usually needed anyway much above 100k miles.
Solved random misfires codes on my CL and Pilot both below 150k in mileage, and the valves were way off.
