2006 overheating problem
Old 02-12-2020, 01:21 PM
J_7days's Avatar
Hey guys I have a 06 tsx , I experienced some overheating about a month ago. I've tried several fixes but none seems to be working.
I've replaced the thermostat
flushed the heater core
Replaced radiator cap and hose clamps
It still seems to be building up pressure in the system. I've checked plugs when replacing for signs of a gasket blown(no indication). Both fans activate when the a/c is on. Any help will be greatly appreciated. It seems to be losing coolant somewhere because it always takes a small amount of coolant(maybe 12oz every 3 or 4days)
Old 03-14-2021, 10:28 PM
ksu90's Avatar
I am sorry to hear, but it sounds like you have a blown head gasket. The coolant is likely being burned in your combustion chamber. Did your cylinders look super clean when you checked the spark plugs? If it does, then it sounds like it was steam cleaned with the coolant. There is a kit of some sort that you can use to test if your coolant has carbon dioxide. Also excessive smoke in your tail pipe would also indicate the coolant is being burned.
When did you first experience the over heating? Was it only at idle? Does your radiator fans ever come on when your at idle?
Old 03-17-2021, 09:33 PM
CL9oem's Avatar
Pressure test it and go from there.
J_7days (03-19-2021)
tl3097flnkr
04-18-2021 01:42 AM
FALLiiSTEENY
10-04-2019 02:06 PM
Andres Morejon
08-28-2019 09:31 PM
613CLS
2G CL Problems & Fixes
04-17-2018 07:48 AM
greydog
1G CL DIY & FAQ
10-19-2015 07:57 AM
Quick Reply: 2006 overheating problem
