Help with Starting Problem
Old 07-30-2003, 11:32 AM
I'm a newbie to this cite and as an acura owner. Bought my first used 1997 TL about two weeks ago. Overall, I think this car is solid. It has drives well and has enough power. Recently though I started to notice some minor problems. One of them being difficulty with starting the car. There have been several times now that the car would not start the first time I try. Like the engine kill is engaged. But when I switch of and then on again, then the engine would start...hmmm. There has also been an occassion where the engine would just not turn. Almost like the car is out of gas or the battery i drained. My TL has an Alpine alarm installed by the previous owner (engine kill is one of the options). Do you think the alarm is the problem? Is this a common problem for the TL?
Old 07-30-2003, 11:48 AM
praxiis's Avatar
Does the starter turn and not catch? When this happens, is your fuel below 1/4 tank? I find mine takes between 3 and 5 extra turns before it catches when the fuel is low. It usually turns about 5 times.
The symptoms for a dead battery are different from those of a car with no gas, so I'm not quite sure what you mean.
Craig
Old 07-30-2003, 11:56 AM
Aside from keeping the gas tank more than 1/4 full, are there any fix for this?
Old 07-30-2003, 03:54 PM
Sam5spd's Avatar
i had a similar problem a while back on my 97 3.2TL .. my car would have a hardtime starting but after a while it would eventually start ,, after about 2 months of this, i finally had enough,, and took it to a mechanic ,, the starter engine was going bad so i had it replaced luckly i had a warranty to cover the cost ..
Old 08-02-2003, 03:33 AM
demons rage's Avatar
how much would the starter engine cost?
my car chokes osmetimes when i start, and i have to actually turn the ignition twice sometimes...
Old 09-15-2003, 08:59 AM
i dont know if im late or not but i got mine fixed 3 months ago a refubished starter would cost you like 260 plus labor well that what it cost in cali
Old 09-15-2003, 09:15 PM
Ur ignition switch is going bad it happened to me and since u have a 97 i believe it is covered under a recal check it out
Old 09-16-2003, 03:46 AM
unx979's Avatar
you can always upgrade to a MSD starter.
Old 01-31-2017, 10:09 AM
dB_TSX's Avatar
I'm curious to know if an MSD starter and new main power cable will eleminate the slow starts on my 2009 TSX.
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
obert
12-14-2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
jordanboi
09-05-2015 01:33 AM
NSolace
09-03-2015 08:02 PM
Quick Reply: Help with Starting Problem
