Speaker settings?
Speaker settings?
I have a 2008 Tech and wondering if there are any recommended settings for the best ELS sound?
I've done a search and found lots of recommendations for the 2G RDX but can't seem to find any settings for 1G.
Music preferences range from light rock to new age and classical.
There is not much you can change within the settings...you have bass, treble and an independent subwoofer adjustment, and really it's all subjective. Play with it till you hear what you want to hear. I personally keep treble about 8/10 and bass around 6/10 (just over middle), and I keep the sub setting pretty high. What you REALLY want for best sound is the best possible input quality. If you can manage to find any DVD-audio discs, they sound amazing on this system. Unfortunately the format never really took off and what's out there tends to be a little pricey.
Example: https://www.amazon.com/Wagner-Overtu...udio+classical
https://www.amazon.com/Beethoven-9-S...in%3A387646011
https://www.amazon.com/Moving-Pictur...ures+dvd+audio
Agreed on the bass. The sound is super clean, and the sub control lets you add a good amount of bass at low overall volume, but as the rest of the speakers get loud the bass caps out quickly. On the positive side, the amp doesn't push the sub beyond its capabilities and you do not have to worry about that flappy distorted bass from an over-worked sub. If I were to do anything to this system, it would the sub and amp replacement that a few have done using a low-pro sub and the factory enclosure. A 200w or so sub will allow the bass to scale nicely with the rest of the system.
mrgold35
Another reason to keep our current Gen vehicles since they dropped DVD-A feature on the current Acura models.
It's basically a dead format, so it makes sense for them to drop it. But on the other hand blu-ray audio is definitely a thing, and it would be great if some of the newer high-end stereo options on the market could support it. Not sure how many actually do.
By treble in the middle, I meant the middle of the postive side, so about 5 clicks to the right from the middle I think.
Thanks for the suggestions. I found the base and sub boost especially helpful even on regular CDs. I have a couple of DVD-A's which sound great but the selection is of course so limited and some of the performances were never first rate. Is it my imagination or has XM sound gone downhill in recent years? When I first got the RDX I thought it was so much better than FM...not so sure now.
mrgold35
I'm back to (mono tone) XM since getting my RDX repaired.
