How to reset PIN on the Navigation system
Old 12-08-2007, 01:21 PM
MN Matt's Avatar
I picked up my RDX --2007 Tech-11,000miles. The previous owner used a PIN on the personal settings part of the Nav system. How do I reset this so I can use this feature.
BTW--Love the car.
Old 12-20-2007, 09:20 PM
MN Matt's Avatar
I found out if you put the anti theft code in as your PIN it will reset
Old 01-06-2008, 11:51 AM
Acura Technician
I didn't know that, but if you hold down menu,map guide, and cancel it will bring up the service screens and from there you can find the option to clear the memory.It will take a bit of snooping through the menus
Old 01-06-2008, 08:16 PM
MN Matt's Avatar
I may have to see explore that. Thanks
Old 12-22-2008, 04:18 PM
Mogulman's Avatar
Look on the inside of the glove box (left side) There could be some stickers with numbers. Use the 4 digit one. It worked for me.
Old 11-14-2019, 10:42 PM
nncy's Avatar
Thank you! This information is a life saver!
Old 08-01-2020, 09:39 AM
4th Gear
data's Avatar
Hi Sonomaa, I just bought a 2008 RDX for my daughters to drive and one of the things they need to do all the time after they start the car is to do what you just mentioned which is hold down the Menu, Map Guide, and Cancel. The service screens come up and then you just hit ok and then eventually you are brought to the Navigation screen and can use the Navigation as normal. Can you tell me why the car is needing this and if there is anything I can do to just have the Navigation come up on start up?
Old 08-04-2020, 06:36 PM
CSmoney28
CSmoney28's Avatar
Thanks for the information, you can also go in the Acura navigation site and order a new navigation code card.
Old 08-04-2020, 06:48 PM
4th Gear
data's Avatar
is the issue that I am having when I need to select Menu, Map Guide, and Cancel to get the Navigation screen activate and passed the diagnostic screen due to an invalid Navigation code?
Old 08-04-2020, 07:55 PM
CSmoney28
CSmoney28's Avatar
If you don’t have the code it will say locked
Rowdy
09-06-2017 01:55 PM
smite
29
03-12-2006 10:48 PM
kreate2
11-14-2005 08:53 PM
greyjhu
01-06-2004 02:01 AM
SC TL
04-04-2001 12:41 AM
Quick Reply: How to reset PIN on the Navigation system
