DIY - Requests
Old 11-01-2005, 01:57 PM
  #41
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,414 Likes on 3,024 Posts
Originally Posted by paradigmsk8er
hey all, im new here. i drive a 97 acura 2.2cl an dabsolutely love it..i just recently got it as my second car.
anyways ive been installing stereo stuff for awhile but i like to kno wwhat im getting into before i dive into a project...CD player and HU wise...is it a difficult install? is it iso mounted? what exactly do i have to do to put a new HU in? remove the dash?
any guidance and help is much appreciated! ive got some big plans for my Cl and im exicted to be here!
You have to remove the center console(armrest) Then remove the trim under the steering wheel (pops right out) and remove the rubber stoppers from the glove box, there are screws behind both. The hu is mounted inside the console. It's bolted, so you have to get all that stuff out, then remove the headunit and pocket (they're attached) That's it. Not too hard, just figuring out how to get the console apart the first time is a bitch. After that, ripping your interior apart is simple, I do it all the time
Old 11-01-2005, 02:19 PM
  #42
4th Gear
paradigmsk8er's Avatar
so if the pocket is attached...i take it that means i have to get an adapter/dash kit to mount the HU huh?
http://www.cardomain.com/item/SCOHA1563B?vq_id=none
that work? anone know of a cheaper place? sounddomain just has a readily available stock...
also, is this an easy plug and play:
http://www.cardomain.com/item/SCOHA02B?vq_id=none
or does it require some fiddling to get it to work? ive used several that arent wired properly or marked...
thanks again for th ehelp!
Old 11-01-2005, 06:35 PM
  #43
klepto's Avatar
https://acurazine.com/forums/audio-video-electronics-navigation-22/tracing-option-not-there-navi-174721/
Old 11-01-2005, 11:27 PM
  #44
4th Gear
thanks, it wasnt working when i posted. appreciate it
Old 11-27-2005, 08:42 PM
  #45
Soon to be H22 turbo!
Bigpimpin18's Avatar
Hey klepto, would it be cool if I did a write up on installing an aftermarket alarm with remote start on my 97 2.2CL?
Old 11-27-2005, 11:12 PM
  #46
Miss th 3.0
wakeboardfusion's Avatar
when are you going to install it? and it would be helpfull to me
Old 11-28-2005, 12:24 AM
  #47
klepto's Avatar
sure, why not
Old 12-30-2005, 05:23 PM
  #48
StckUpKid's Avatar
www.ledautomotive.com will the kits for moonroof, sunroof, etc.. especially the CLIMATE CONTROL KIT work in the cl???? im so sick of the green!! all my other lights are done!! i just dont want to go about ordering tons of lights and shit if i can just get the kits for them u know!! does anybody know??
Old 12-30-2005, 09:27 PM
  #49
elserpien's Avatar
yes they work for our cars, but the "kits" are just led's and smt resistors which can be purchased at your local electronic store. If your no good with a soldering iron the pre-done stuff might be a good deal for you.
Old 12-31-2005, 10:22 AM
  #50
2.4 L iVtec
jumpmanbsktbll's Avatar
foglight installation and wiring...
diy for foglight installation and wiring woul be awesome
Old 01-13-2006, 04:17 AM
  #51
saiko_cl_duck's Avatar
while not for the 1st gen exactly, it's pretty straightforward
http://members.aol.com/agspeed/piaa.htm
Old 01-26-2006, 02:41 PM
  #52
infamouz trunkz's Avatar
how about replacing ur o2 sensors??
Old 02-23-2006, 12:24 AM
  #53
wundumphaker's Avatar
Anyone have a DIY for projectors? wat kind to buy, and how to install em?
Old 02-27-2006, 02:57 PM
  #54
ajbent86's Avatar
Request - DIY for changing the security LED to BLUE
Can anyone provide a step by step DIY on how to change the stock Red security LED to a BRIGHT BLUE? I would also like to know the size of the LED used and the correct voltage LED needed.
Old 03-19-2006, 10:08 AM
  #55
First EVER K24 Turbo CL
starboy2nv's Avatar
anyone wanna remove there dash board and tell me how to do it? lol
Old 03-31-2006, 08:02 PM
  #56
2.4 L iVtec
DIY on installing an intake on a 3.0 ( is it the same as the 2.2?)
Old 04-01-2006, 01:14 AM
  #57
teh CL's Avatar
Old 04-01-2006, 01:18 PM
  #58
2.4 L iVtec
Old 04-05-2006, 11:02 PM
  #59
2.2Clean's Avatar
DIY on dynomating the trunk and rear deck
Old 04-10-2006, 11:54 AM
  #60
tman89544's Avatar
Stock fog light install?
Old 04-10-2006, 07:58 PM
  #61
2.4 L iVtec
3.0 intake, anyone?
Old 04-13-2006, 08:24 AM
  #62
Gaujo's Avatar
I need help removing passenger side airbag (blown)
Old 05-01-2006, 11:47 AM
  #63
Bagel Bomber
Mach30SiR's Avatar
does anyone even check this anymore I can write the diy on the trunk and deck dynomat if its still needed. thinking about writing a diy on the clogged egr repair, anyone??
Old 05-02-2006, 10:16 AM
  #64
Gaujo's Avatar
i check, I'd be interested in reading about dynomatting too! Its expensive to have done at the audio shop.
Old 05-02-2006, 03:30 PM
  #65
Ahhhhhhhh
LLWesMan's Avatar
It's pretty straightforward, put the dynamat whereever you hear rattles. Lifting up the carpet is as easy as pulling pins.
Old 05-07-2006, 09:29 PM
  #66
RODDYS
roddymerritt's Avatar
I know that all of these have been covered seperatly but it would be nice if someone would do a full Black housing, HID, Projector retro fit DIY
Old 06-01-2006, 10:35 PM
  #67
ajbent86's Avatar
how about replacing a window regulator DIY
Old 06-02-2006, 01:34 AM
  #68
rawbeanz's Avatar
ahhhh i need a DIY on projector retro fitting. EEEK and uhh do you jsut heat the emblems off the back of your car? how do u get them back on?
Old 06-02-2006, 10:33 AM
  #69
ur as welcome as cancer
arstraub's Avatar
How about putting on neons???? (Yes, I know I'm about to be slaughtered for that)
Old 06-13-2006, 08:40 PM
  #70
where is....
AznX TL's Avatar
someone please do a step by step with pictures DIY on Seafoam for the 2.x
Old 06-14-2006, 08:59 PM
  #71
asianspec's Avatar
Received 1,097 Likes on 831 Posts
pm this guy. ajtcl
he has a web page about it.
Old 06-16-2006, 09:02 PM
  #72
Bagel Bomber
Mach30SiR's Avatar
3.0 automatic tranny rebuild. wishful thinking, but hey, worth a shot.
Old 06-22-2006, 03:35 PM
  #73
chips and smokes, lets go
herbalist's Avatar
anyone got a DIY for the cigarette lighter? my phone charger plug made it all loose from all the twisting and now it doesn't work. anyone???
Old 06-22-2006, 04:00 PM
  #74
teh CL's Avatar
mine dont work either...
check the fuse...if not take apart you center console to see if it got unpluged some how
Old 06-26-2006, 09:15 AM
  #75
Gaujo's Avatar
fyi i replaced one on an old car and it kept getting loose. Its one of those things that once u strip the housing its a pain in the ass to get it right again. I did it myself and it kept getting loose so i just took the factory part I ordered in the next time I needed something done at the dealer and they only charged me about $15 to put it in.
Old 07-25-2006, 12:21 PM
  #76
CBloc-CL's Avatar
Will this work on a 99 CL as well? not sure if theres really anny difference. Tryin to install my new alpine HU.
Old 10-19-2006, 08:09 AM
  #77
anyone want one for the windshield wipers? i'm gonna take mine off and paint them, they're looking nasty.
Old 11-20-2006, 08:03 AM
  #78
j8shua's Avatar
Failed Emmissions Test...Catalytic Converter Install
Hey Guys,
My CL failed the emmissions testing and I took it to a good friend who happens to be a high-end master mechanic. When he checked it out he said I needed a new cat. converter and it was going to cost $1400 installed. I don't have that kind of cash, so does anybody know if I can get an aftermarket catalytic converter online for cheap that would pass the tests? Also, should I try the install or should I take it somewhere? Also, does anybody have any clue how much coin I should expect to drop on this little repair if I let somebody else install it?
Old 12-13-2006, 12:17 PM
  #79
asianspec's Avatar
Originally Posted by j8shua
Hey Guys,
go get a magnaflow cat and call it a day.
Old 12-31-2006, 09:30 AM
  #80
BAMACL3.0's Avatar
DIY for a homemade grounding kit; 3.0 version.
Quick Reply: DIY - Requests
