Powerliftgate won't close with remote
Old 03-06-2017, 06:52 PM
2011acuramdx's Avatar
I have a 2011 Acura MDX wich started to have a problem with the powerliftgate today. It does everything normal to open but it will not close automatically you have to close it manually.
Old 03-06-2017, 10:27 PM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums.
Thread moved from the Second Generation RDX (2013+) Forum.
Old 03-07-2017, 01:22 AM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Did you disconnect the battery?
The only reason the lift gate has to re-learn the closing travel is when you disconnect the battery..
Do this: Open the Lift gate manually and close it manually 2 times, It should be enough to re-learn the travel and the power lift gate should work fine now.
If it doesn´t there is a problem with the power lift gate motor unit.
mdlesk
11-02-2012 11:56 PM
nadoacu
08-16-2012 03:56 PM
LuvMyTSX
06-27-2009 05:54 PM
sloojoe
04-29-2008 11:54 PM
93Miata
10-22-2005 05:25 PM
Quick Reply: Powerliftgate won't close with remote
